Is the 23mm F2 a bad lens?
Started Sep 26, 2018 | Discussions
jor23 Senior Member • Posts: 1,555
My main system is Sony.
I have tried Fuji a few times - XE1, XT10, X100 and X100T are the bodies that I used in the past. All for a brief period of time though.
Got an XT20 with 18-55mm and want to try using it along side my Sony. Just for fun.
For family photos, I am considering the 23mm F2. The only Fuji lens that I used were the 18-55mm, if you don't count the 23mm in the X100/T.
Is the XF 23mm F2 a bad lens? I read that it's the same as X100 series where pictures are blurry when the objects are close.
The 23mm F1.4 looks nice, but it costs more than I can spare.
Should I consider the 35mm? On my Sony, I find the 55mm f1.8 too long.
Fujifilm FinePix X100 Fujifilm X100T Fujifilm X-E1 Fujifilm X-T10 Fujifilm X-T20
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
No.
8
If you shoot subjects at about 12" or closer, you get the softness that the lens was designed to provide.
...Bob, NYC
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
ioh Junior Member • Posts: 49
Re: Is the 23mm F2 a bad lens?
9
No, it's an excellent lens. Also, the lens in the X100 series is not the same lens as the XF 23mm f2 R WR.
The 23/1.4 has MFD 28cm, and the 23/2 has MFD 22cm. So if you're focusing on a subject at 22-28cm, the 23/1.4 would not help with sharpness at that distance.
 ioh's gear list:ioh's gear list
Fujifilm X-E3 Fujifilm XF 27mm F2.8 Rokinon 12mm F2.0 NCS CS Rokinon 50mm F1.2 AS UMC Fujifilm XF 23mm F2 R WR
Len-O Senior Member • Posts: 1,637
For working within a budget, the 23mm f/2.0 is a great compact lens which performs very well.
 Len-O's gear list:Len-O's gear list
Fujifilm X-E2 Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R +8 more
jonikon Veteran Member • Posts: 7,432
Hey, your cat looks softer than mine!
Best regards,
Jon
thomega
thomega Regular Member • Posts: 131
No;-)
 thomega's gear list:thomega's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm X-Pro3 Fujifilm XF 14mm F2.8 R Fujifilm XF 56mm F1.2 R +17 more
John Gellings
John Gellings Veteran Member • Posts: 9,742
8
Bad if you are a pixel peeper, fine if you are into photography.
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
Xe11ent Regular Member • Posts: 224
absolutely not. As already stated, when focusing close f2 will be a little soft. But same with the x100 lens and the 23 1.4 can not focus that close. Having said that, the 23f2 is beautifully built and a pleasure to use. The AF is fast and it's quiet. IQ is good!
 Xe11ent's gear list:Xe11ent's gear list
Fujifilm X-T3 Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R Phase One Capture One Pro
OP jor23 Senior Member • Posts: 1,555
seems to be unanimous ...
My 35mm on Sony is the 35mm f1.4. I thought about XF 23 f1.4, but it's just a bit more than I want to spend on a secondary system.
razorfish Contributing Member • Posts: 855
I’d get the 23mm. I find it to be almost as sharp as my 56 APD wide open, and that’s saying something for such a small and fast-focusing lens. Don’t really see any difference between near and far subjects.
 razorfish's gear list:razorfish's gear list
Sony a7R III Sigma 35mm F1.2 DG DN Sony FE 20mm F1.8G Tamron 150-500mm F5-6.7 Di III VC VXD Phase One Capture One Pro
You meant the XF 23mm F2?
That's good to know. There are a lot of discussion on the internet about how soft it is wide open or focused close.
acktown
acktown Contributing Member • Posts: 513
10
Spectacular lens! I enjoy the focal length for many different aspects of shooting. The weather sealing is an added bonus, it's well built, small, and has a great look about it.
 acktown's gear list:acktown's gear list
Sony a7 II Sony FE 28-70mm F3.5-5.6 OSS Tamron 17-28mm F2.8 Di III RXD Samsung Galaxy S10 +3 more
rokphish
rokphish Contributing Member • Posts: 501
Lovely!
 rokphish's gear list:rokphish's gear list
Fujifilm FinePix X100 Ricoh GR Digital IV Fujifilm X30 Ricoh GR II Fujifilm X-Pro1 +2 more
Doug MacMillan Veteran Member • Posts: 3,695
I’ve rented both 23mm.  They are both great lenses.  The f2 is a little quicker focusing.  Tha 1.4 has more “magic” IQ.  Don’t feel like you’re giving up much if you don’t want to pay the extra for the 1.4.
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
Greg7579
Greg7579 Forum Pro • Posts: 14,044
Fuji makes no bad lenses.
Very badly worded question but I'll give you the benefit of the doubt and answer it.  The answer is no, absoltely not.  Its a very fine lens.  The 23/35/50 F2s are all great little lenses.
Oh, and what are you talking about on that "blurry" comment?  The X100F has a great F2 prime and there is nothing even remotely blurry about it.  There are no blurry Fuji lenses.  There are no "bad" Fuji lenses.  Fuji makes some of the best, or perhaps the best, glass in the world.
Greg Johnson, San Antonio, Texas
https://www.flickr.com/photos/139148982@N02/albums
 Greg7579's gear list:Greg7579's gear list
Leica Q2 Fujifilm GFX 50R Fujifilm GFX 100 Fujifilm GF 32-64mm F4 Fujifilm 120mm F4 Macro +8 more
Re: Fuji makes no bad lenses.
I had an X100 and and an X100T. If you focus close and shoot at f2, the pictures are blurry ... I don't think this needs to be argued.
Greg7579
Hmmmm.  Hadn't heard that.  The X100F is a pro camera body with a pro 23 F2 lens permanently attached, so that surprises me.
Well then.  I am currently shooting in Rome and I brought 7 tac-sharp Fuji lenses with me (but I left the 23 F2 at home).
I also have the X100F with me but haven't gone out with it yet.  I'll go give it a try.  Close at F2.  I don't ever shoot close at F2 but I will go out today and see if it is blurry close at F2.
OK guys... Thread derailment time.  Is the X100F "blurry" close at F2 like the OP says?  I dont recall ever reading that when you guys made me buy that camera a few months ago on that X100F thread.
Peter Jonas Veteran Member • Posts: 4,053
Re: Not the same lens: X100T and XF 23mm F2
It's almost unanimously held by all users that the XF23mm f2.0 is an excellent lens.
This review is just one of the many out there you may like to read.
You need to be more careful about what you believe of what you read on the internet.
It is definitely not the same lens. In fact as per this statement from Fuji, it could hardly be more different.
You could have just asked what people thought about the lens, instead of asking what you did.
In my view, the way you put it reflects on you quite negatively. It tells people that you have very little idea, but plenty of prejudice. It makes me think you have made up your mind without knowing anything about the lens, and never bothered to check if the little you thought you knew was actually correct.
I am not sure this is the case, but admittedly, I have never had an X100T.
Peter Jonas
 Peter Jonas's gear list:Peter Jonas's gear list
Fujifilm X-E2 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +1 more
It's quite correct, that does not need to be argued. At least not in relation to the performance of the XF23mm f/2.0 lens
As I stated in my earlier post the XF23mm f/2.0 and the lens on the X100T are not the same lens.
Accordingly, it is totally irrelevant to this discussion how the lens of the X100T performs under the conditions you describe.
Peter Jonas
Greg,
If you are so inclined, you can do lots of testing  with the X100F or the X100T. However, as far as the performance of the XF23mm f2.0 is concerned it will have very little relevance.
They are not the same lenses. Please see my earlier post in relation to that.
Peter Jonas
