10 Stop ND Filter Haze
Started Sep 24, 2018 | Discussions
jackreynolds New Member • Posts: 1
Hello!
I have a quick question on a recent purchase. I recently purchased this:
Link to Product on B&H
I went out on the street where I live to try it out. I noticed on these images the green and magenta haze. It was fairly sunny on this day.
Nikon D7100
Nikon AF-S DX Zoom-NIKKOR 18-55mm f/3.5-5.6G ED II
Exposure time: 30 seconds
Aperture f/25
ISO 100
Is this result normal? Am I doing something wrong?
Thank you,
Jack
Nikon D7100
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: 10 Stop ND Filter Haze
jackreynolds wrote:
Hello!
Nikon D7100
Aperture f/25
ISO 100
My guess would be a light leak possibly involving a sensor or other reflection that could separate the colors; it's also possible that it's electronic leakage, but I doubt that.
Try shooting with the camera lens out of direct sunlight (maybe even covered with something) while looking into the full sunlit scene; this is always the recommended protocol for using heavy ND filters in daylight. You might try making the same exposure with the lens cap on and see what you get, just to confirm it isn't a defective filter.
PS: Such light leaks are generally NOT considered a defect for a camera or lens, but simply a limitation exposed by your extreme use of the camera. If you think about it, dropping the light by 10 stops is dropping the light by pretty much the entire dynamic range of many cameras -- thus, the leaks you see would literally be below sensor noise if you weren't using this ND filter.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
jannefoo Regular Member • Posts: 310
Your viewfinder is leaking light, use a cover on it - one came with your camera.
 jannefoo's gear list:jannefoo's gear list
Sigma APO Macro 180mm F2.8 EX DG OS HSM Sigma 14mm F1.8 Art Nikon D800 Nikon 1 J5 Samyang 85mm F1.4 Aspherical IF +9 more
ProfHankD
Excellent possibility.  I keep forgetting some people still use SLRs....
Entropy512 Veteran Member • Posts: 6,016
A potential alternative approach:
Rather than drop the light incoming by 10 stops, drop it by somewhere around 3 to get long enough exposure times that:
1)  The shot rate is slow enough that you can clear the buffer in continuous drive mode
2) The dead time in between shots in continuous drive mode is negligible compared to the shot time
Then take a series of images in continuous drive mode and stack in post.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
