olympus 75-300mm image shake at 300mm
Started Sep 24, 2018 | Discussions
sergiodaguru
OP sergiodaguru New Member • Posts: 20
Re: olympus 75-300mm image shake at 300mm
Moral of the story: use a lighter tripod!
Hand-held, turn IS/IBIS OFF and use very g=high speeds.
Unexpected but it worked for me!
Very happy with the lens now!
 sergiodaguru's gear list:sergiodaguru's gear list
Nikon D80 Leica M-E Typ 220 Olympus E-M5 II Fujifilm X-T2 Olympus E-M1 II +1 more
photofan1986
photofan1986 Veteran Member • Posts: 3,841
Still, that's not a normal behavior. I never shut the Ibis off and never had such a problem.
I think your camera is faulty.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
katastrofa Senior Member • Posts: 1,034
The 1st looks OK-ish: the bird is slightly out of focus, but the tree is sharp. No shake.
The 2nd one is blurred again, shake + the bird is out of focus.
 katastrofa's gear list:katastrofa's gear list
PowerShot SX700 Olympus E-M1 II OM-1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +4 more
sergiodaguru
The 2nd the bird was very far and it is tiny, the focus is more a MFT focus fault than anything else, I do not see the “halo” effect though.
sergiodaguru
The problem is the same on another camera so don’t think that is the cause.
DickyAus Veteran Member • Posts: 4,563
Don't despair!
I had exactly the same problems when I first got that lens; it took me a while to learn how to use it.
In your second photo you have simply missed focus.
As others have said - open - up the aperture wind up the ISO and hold it still.
The thing that helped me most was to use AF + MF with 3X magnification, tweak focus with the MF ring and see the difference.
Low light isn't a problem if you hold still.
I took this while leaning against a wall.
Enjoy,
Dicky.
 DickyAus's gear list:DickyAus's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko 300mm F4 IS Pro +1 more
Gato Amarillo Veteran Member • Posts: 9,353
sergiodaguru wrote:
I then went to Best Buy and got one of the cheapest and very light tripod ($34.99), I'll be damned! see below
Like you said, I'll be damned.
I have no explanation, but from this and your other posts it seems like you're getting things worked out. Good to hear things are looking better.
Gato
glassoholic
glassoholic Veteran Member • Posts: 7,641
sergiodaguru wrote:
katastrofa wrote:
Turn off all IS, set the shutter speed to 1/1600 or faster, switch to electronic shutter an take a photo of something close by (to eliminate atmospheric distortion). Can be hand-held - at that shutter speed it shouldn't matter.
Do you still get the halo?
Bravo! Worked great for handhelp, I think IS was the culprit here.
Yep... another example of IBIS and high shutter speeds in the range of 1/800 (or sometimes 1/500) to 1/1600 not working well together.
As I suggested, try 1/125 -1/250 with IBIS and you should be happy as well ( with a steady hand and still subject of course). But for BIF, use 1/2500 (sometimes 1/1600-2000 also works) and no IBIS. For still subjects use around 1/250 with IBIS On and even try 1/125 and this also gets your ISO down this way and aperture to f8-f9 where the lens performs best.
Olympus went DUAL IS for a reason with the 300 Pro and it wasn't just to get another stop of stabilisation.... that was for the 12-100. Super teles and IBIS have some issues.
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me. Make the best you can of every day!
