olympus 75-300mm image shake at 300mm
Started Sep 24, 2018 | Discussions
sergiodaguru
sergiodaguru New Member • Posts: 20
I have an olympus 75-300mm image shake at 300mm and I can't get a decent shot at 300mm, at 75-200mm pictures are ok but at 300mm even on a tripod images are shaky, see attached samples.
I thought the lens is defective but if that were the case it'd probably show at other ranges.
All images shot on a tripod, OMD-E-M5-II. The results are the same shot on an OMD-E-M10-III.
Am I doing something wrong? Or time to send it to Olympus for repair?
1/400 sec, f/9.0,ISO 200 - minimal processing, (anti-shock 0s)
1/400 sec, f/9.0,ISO 200 - minimal processing, cropped (anti-shock 0s)
1/400 sec, f/9.0,ISO 200, 208mm - minimal processing, (anti-shock 0s)
1/400 sec, f/9.0,ISO 200, 208mm - minimal processing, cropped (anti-shock 0s)
1/200 sec, f/11.0,ISO 200, 300mm - minimal processing, cropped (anti-shock 0s) - notice halo on moon top
 sergiodaguru's gear list:sergiodaguru's gear list
Nikon D80 Leica M-E Typ 220 Olympus E-M5 II Fujifilm X-T2 Olympus E-M1 II +1 more
TomFid Veteran Member • Posts: 3,999
Re: olympus 75-300mm image shake at 300mm
It's hard for me to imagine what you could do that would be that wrong.
A tripod can interact poorly with stabilization, but in my tests of the Oly IS, it seems smart enough to avoid that. Very doubtful.
Shutter shock can produce double images, but only of a few pixels width - this is way beyond that.
I'd say it has to be a lens problem (or maybe a really bad filter, if you have one).
john isaacs Veteran Member • Posts: 8,440
5
First, I see similar halos with your 200mm shots.  Just not as extreme.
If you used any filters, remove them and try again.
Try shooting with electronic shutter and compare results.
Try shooting with wider aperture.  F/9 and f/11 are going to pick up effects on the front lens, or especially with filters.  Diffraction is going to be reducing image quality beyond f/8, so there's no reason to shoot at smaller apertures with these subjects.
drj3 Forum Pro • Posts: 12,632
I would add to your suggestions, set a delay for shutter release to be certain that it was not caused by camera movement.  This looks similar to up/down movement with shutter press and release.  Not as likely with a tripod, but the 75-300 doesn't have a tripod mount, so maybe the camera moved slightly with shutter press and release.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Astrotripper Veteran Member • Posts: 8,676
bad news
This looks like a serious fault with the lens. The image at 200mm is not fine at all. This is way too much for shutter shock as well, not to mention some of your examples are outside the usual shutter shock range.
Something is seriously wrong with that lens. Does it rattle when you shake it?
If it's still under warranty, send it for repair.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
Re: bad news
Bad filter is my guess.
Also use no smaller than f8... f11-16 makes images softer. F11 in great light might be better if DOF is a priority.
Also 1/400 with IBIS often works worse than 1/250 with IBIS. 1/400 - 1/1000 was a range that always gave me issues with this lens. Try either 1/125 - 1/250 with IBIS on or 1/1600 and faster with IBIS off.
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me. Make the best you can of every day!
sergiodaguru
OP sergiodaguru New Member • Posts: 20
The filter is  a BW, I removed it, no luck.
I took some pictures of the front element, looks good to me.
If I shake the lens I hear no rattle either.
Out of warranty.
katastrofa Senior Member • Posts: 1,034
Turn off all IS, set the shutter speed to 1/1600 or faster, switch to electronic shutter an take a photo of something close by (to eliminate atmospheric distortion). Can be hand-held - at that shutter speed it shouldn't matter.
Do you still get the halo?
 katastrofa's gear list:katastrofa's gear list
PowerShot SX700 Olympus E-M1 II OM-1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +4 more
bluehighwayman Contributing Member • Posts: 826
Is your tripod stable and of good quality?  Also when mounted on a tripod the lens itself must be supported and this is even more important if you extend the lens.  Use a remote or use a time delay of at least 5 seconds to trigger the shutter.  It is very hard to handhold this lens at the longer telephoto ranges and get a decently sharp photo. Turn off the IS when using a tripod as per Olympus's instructions.  If you still can't get an acceptable photo send the lens in and have Olympus check it.
 bluehighwayman's gear list:bluehighwayman's gear list
Olympus E-M1 III Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Tokina AT-X Pro 11-16mm f/2.8 DX Tamron SP AF 90mm F/2.8 Di Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
Gato Amarillo Veteran Member • Posts: 9,353
This was my first thought as well -- given the direction and amount of movement. This to me looks typical of a cheap or light-weight tripod when using the camera shutter release.
I am suspicious of your tripod, given the amount and direction of the double image. This kind of focal length is tricky by any standard and calls for very solid support.
Try with a remote release, if you are not already using one. Allow a couple of seconds for the tripod to "settle" between the time you last touch the camera or lens and your shot. Be aware of wind or breeze.
Check your tripod and head for any flex - does it let the lens and camera bob up and down? Does anything vibrate if you touch or tap the lens or camera? For this kind of focal length you need a very solid support. It may be time for an upgrade.
Be sure your stabilization is set correctly -- what does Olympus recommend for tripod use?
Once you rule out movement they you can worry about if the lens has a problem.
Gato
Oh, and use the highest shutter speed practical. To me 1/400 is marginal for a 600mm equivalent focal length. F9 may be the widest you want to go with that lens, so consider bumping the ISO -- 400 or even 800 should work with your cameras.
glassoholic
+1
This lens has no OIS, it relies on IBIS. IBIS is less effective at long focal lengths. Also, this lens is quite light, it may have little inertia to absorb vibrations.
https://www.amateurphotographer.co.uk/technique/camera_skills/master-your-camera-getting-the-most-out-of-image-stabilisation-on-the-olympus-om-d-e-m5-52373 recommends turning IBIS off when using a tripod.
Out of warranty.
Now I think it is not your lens, or your camera.  Look at these pictures, apparently taken with a Nikon D80, and notice the double image of the print.   Same problem as with the bird photos.
Smith-64 Regular Member • Posts: 364
Good night I had less blur hand holding my ZD 70-300mm at similar shutter speeds/f stops last week shooting grandson's football game. Maybe you should experiment with a sandbag. I'd like to post some samples but I'm recovering from knee replacement and can't sit at that computer.
All your blur images are in a vertical direction which suggests something to do with the shutter release or a yank on a remote release. Can't see any camera/lens failure that would cause that pattern of blur.
A. C.
 Smith-64's gear list:Smith-64's gear list
Olympus E-M1 II Olympus 14-150 F4-5.6 II +1 more
sergiodaguru
Bravo! Worked great for handhelp, I think IS was the culprit here.
sergiodaguru
Yeah I notice that too the problem is the only Macro lens I had was a Tamron Nikon F mount with no IS, that is why I shot with the D80:-)
sergiodaguru
I shot with is OFF and ON on the tripod made no difference. Hand-held I had to use a high speed and shut IS off (see my other post forr pictures).
sergiodaguru
Gato
It surprised me, my tripod is a sturdy MANFROTTO 290 MT294A3 WITH MANFROTTO 808RC4 3.
I used a 12 sec timer (tried ant-ishock and silent).
No luck.
I then went to Best Buy and got one of the cheapest and very light tripod ($34.99), I'll be damned! see below
