Panasonic G7 and Mecablitz 30BTC4 (150Volts :O)
Started Sep 24, 2018 | Discussions
AlesCZX New Member • Posts: 2
Hello folks,
I got the old flash. Mecablitz 30 BCT 4. I tried it on the Panasonic G7 but I did not know there was any safe electrical voltage. On the Internet, I read that the trigger voltage of this flash is more than 150V Damn it!
https://adapting-camera.blogspot.com/2013/04/beware-of-flash-trigger-voltage.html
Did I damage my camera?
Thank you!
Ales
Panasonic Lumix DMC-G7
hindesite Veteran Member • Posts: 4,893
Re: Panasonic G7 and Mecablitz 30BTC4 (150Volts :O)
AlesCZX wrote:
Hello folks,
Very likely - what are you noticing?
There are safe ways to use old flashes with modern cameras, and slave adapters are only a couple of dollars. That allows you to use old flashes off camera.
When you think about it, it was crazy to keep the same connector when the voltage spec changed so much. Imagine of USB worked at 5v and 150v.
Danielvr Veteran Member • Posts: 6,863
fyi: Trigger Voltages of Old Flash Units
Reinhard Wagner has published a long list of trigger voltages used by older flashes. It's in issue 2/2018 of his (German) Oly e-Paper which can be downloaded here. Some background, again in German, was published here.
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
OP AlesCZX New Member • Posts: 2
Thanks. I think the camera is all right. I was thinking about it. There is no 150 volts, like 150 volts. This has very little ampere(i thing). I think it would not have to damage the camera.
It's just my theory.
