T6i bad color
Started Sep 23, 2018 | Discussions
floating_stump Junior Member • Posts: 43
T6i bad color
My wife and I were out for a day of shooting, and halfway through the day, her camera started coming up with bad color.
We tried everything. We shot a custom white balance. I pored over the menus for anything that might have altered it. Couldn't find anything. She was shooting RAW, so I assumed we'd be able to correct it when we got home, but I was wrong. The files are just bad. And she can't even convert them to b/w since the bad color affected the resolution. It's similar to when you push the saturation way up and everything looks wonky.
We tried "Clear settings" to reset to factory. We tried a different card, so it's not the card.
There weren't a whole lot of answers to be had online, but it sounds like we're going to have to send it in to the shop.
Has anyone experienced this and have any other suggestions?
Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
Stan in NH
Stan in NH Senior Member • Posts: 1,898
Re: T6i bad color
Why is there no EXIF data with this photo?  That usually means an editing program was used and stripped the data.  Is this an out of camera image?  Do the images look like this on the camera's LCD, or after they've been transferred to another device?
 Stan in NH's gear list:Stan in NH's gear list
Sony a6400 Sony a7R IV
OP floating_stump Junior Member • Posts: 43
Re: T6i bad color
This is a screencap out of Photoshop. I messed with it quite a bit in Photoshop and RAW editor. I can't change the hue significantly or anything.
Stan in NH
Re: T6i bad color
Can you post any original image before processing?
J A C S
J A C S Forum Pro • Posts: 20,545
Re: T6i bad color
It seems that one of the channels is dead. Would you post a RAW file?
Stan in NH
Re: T6i bad color
Pretty sure this board only accepts jpeg images.  I've never been able to post a RAW file here.
5DIV Junior Member • Posts: 40
Re: T6i bad color
J A C S
Re: T6i bad color
You can place it on Google Drive or OneDrive, etc., and post a link.
R2D2 Forum Pro • Posts: 26,551
Re: T6i bad color
Yikes. Looks like someone shot that through a 700-800nm infrared filter!
As others have mentioned, it's likely a camera problem. However check the Picture Style settings and any filter settings. Maybe something got mucked up (and perhaps still persisted through your reset?).
Probably will require a trip to Canon unfortunately...
Best of luck to you!
R2
