Canon 10-18MM EFS on SONY A7 III, DONE.
Started Sep 22, 2018 | Discussions
dwill23 Senior Member • Posts: 1,226
I was playing around with my new Sony A7 III with sigma MC-11 adapter (cause the metabones didn't work nearly as well) and found that an EF-s should physically mount on any EF mount, except for the back part that sticks out (for no reason) on all EF-S lenses. Ok I reckon this is old news to people.
There's also videos on youtube on what you'll need to do if you can't simply pop out the plastic insert (if it has a metal mount) or saw off this same piece if it's a fully plastic mount as it's all one piece.
I used my $30 Roybi bench grinder to sand off the back part of the lens...the only thing stopping it from mounting onto a canon full frame, and sigma MC-11 adapter.
I'D LIKE TO POINT OUT....that SIGMA...could have easily made the MC-11 adapter capable of accepting EF-s lenses.....but they didn't. WHY??
Anyway, after removing 4 screws then two smaller screws I removed the back mount, grinded it off in about 2-3 mins, rinsed it in the sink to get all the plastic 'dust' off, dried it, and screwed it back onto my 10-18 EFS lens. Or should I now say EF lens? Not quite...
When mounted on my Sony A73 via Sigma MC-11 adapter, I do have to zoom to about 14mm to get rid of 100% black vignetting on the corners. The images do say 10mm-18mm...whatever I shot it at. I compared the angle of view from my Canon 16-35 F4 IS (amazing lens by the way) at 16mm, it was EXACTLY the same. And 14mm was wider than I could have gotten with my 16-35L.
Is 2mm worth the work and maybe less resale value on that lens? (or maybe more now that it will fit a canon full frame?) actually, 2mm is a big difference when you're getting down so low in focal length. Sure 200mm vs 202mm isn't even noticeable, but 14mm vs 16mm is.
That that's STILL not why I did this.
I just wanted a lighter option for traveling to Italy this past week, and wanted less dollar amount in my camera bag. I need the sharpness of my 16-35MM L for weddings so I can't afford to lose that. (Altho the 10-18mm is decently sharp). At the usable 14-18mm range it is F5-5.6 but being SO WIDE and having image stabilization, I was easily able to shoot at 1/10th of a second all day long. EASILY! The camera also has in-body stabilization, but at 14mm with lens IS, that doesn't really matter, but I assume helped some.
I was shooting priceless art works, and painted ceilings, and what looks like 180 degree, floor to super high church ceilings all with ease. NO ONE had this ability. Widest angle I saw was a 24mm, altho I'm sure there were some 16-35's out there, but I didn't see any.
Most people had the kit 18-55 EFS on a cropped sensor camera, giving it a 28.8 - 88mm.
But that's the interesting part, this lens was supposed to give the user an equivalent focal lenth of 16-28.8mm on a cropped sensor camera...never intended to give true 10-18mm performance (again 10-13mm has a 100% black out corner vignette).
I got the shots NO ONE else could, out of a $300 lens I only used on my photobooth.
I know everyone (including myself) on here is obsessed with quality, but it's not always about that...        Are my shots distorted at such a wide MM, yes, any lens would do this. Are they crystal clear like my 16-35L, nope. Are they grainy because of high auto ISO, yes. But again, at least I got the shot, which would have been otherwise impossible. I'd WAY rather have what I took than sharper 24mm pics, ... not being able to get most of the artwork in a single frame. In other words, I wouldn't have changed a thing. I also did this 8 days ago, 1 day before my 7 day trip, so I was surprised and nervous about taking this vs the L lens.
Pics...
10mm
14mm 1/15th F5.0
18mm 1/125th F5.6
I hope you've enjoyed this post!
Dave
Michigan
lenses make the image, the camera only records it.
 dwill23's gear list:dwill23's gear list
Panasonic ZS100 Sony a7 III Canon EOS M6 II Canon EF 70-200mm F4L IS USM Canon EF-S 18-135mm F3.5-5.6 IS STM +4 more
Canon EF 16-35mm F4L IS USM Canon EF-S 10-18mm F4.5–5.6 IS STM Sony a7 III
brightcolours Forum Pro • Posts: 15,885
Not quite
Not quite "no reason". Canon APS-C DSLRs after the EOS 10D have a smaller mirror than Canon FF DSLRs. Canon has made use of the extra room to make it possible for EF-S lenses to get closer to the sensor, giving lens designers a bit more freedom (akin to a shorter flange distance).
The back lens assembly of many EF-S lenses will hit the FF mirror, hence the "back part that sticks out" which ensures you can not by accident mount EF-S lenses on FF DSLRs. In short: the back part has a real reason.
I think I was the very first person to modify the EF-S 10-18mm f4.5-5.6 IS STM by sawing off part of the back plate, to mount it on my 6D, shortly after the lens was released. I posted about it on DPReview.
On Canon FF DSLRs, at 10mm the mirror will hit the back of the lens.
Good question.
Have you noticed the very soft corners at 14mm? And still very soft corners at 18mm (albeit not that big a corner that is blurry)?
It is a big downside which makes the lens not really usable for good-ish quality FF work. But when you use it for video, most of the blurry corners gets cropped, and with STM and IS it makes for a nice UWA video lens.
Pics...
10mm
14mm 1/15th F5.0
18mm 1/125th F5.6
Dave
Michigan
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
Good job!
But any reason you could not have modified the adapter to accept any unmodified EF-S lens?
Here is another mount modification project of mine
http://www.acapixus.dk/photography/Samyang_7.5mm_EFM/
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
