Best HOCO pictures
Started Sep 22, 2018 | Questions
GreatDane10 New Member • Posts: 1
Best HOCO pictures
What is the best setting to capture Homecoming pictures?
I have an EOS Rebel t3i with the manufacturers lens.   Looking to take typical couple pictures with a fountain, gazebo, train and on the train tracks with full sun.
I usually stick to the standard settings. Had someone change my settings once and the could definitely see a difference in the quality.   TIA
Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
floating_stump Junior Member • Posts: 43
Re: Best HOCO pictures
For outdoor portraits, I suggest a large aperture, to give a slight blur to the background. F5 or as big (small number) as your lens will go.
R2D2 Forum Pro • Posts: 26,551
Since you have adequate light, I would actually suggest using a Smaller aperture (set the camera to Aperture Priority and select your aperture). This will help you get multiple subjects in focus, plus a smaller aperture (ie. f/8) will increase the sharpness of the kit lens.
Use a single AF point. Review images in-camera to check focus and exposure (and people’s expressions).
I like to shoot bursts to capture more expressions, and also in case people blink. You’ll be amazed how much people move in such a short period of time!
Happy shooting, and good luck!
R2
Stan in NH
Stan in NH Senior Member • Posts: 1,898
It sounds like you have no experience or training in how to use a DSLR.  You really need a basic understanding of all the factors that effect your images and their appearance.
The “standard” settings are, I assume, the default auto settings the camera uses.  This works, but does not allow you to use the full capabilities of your camera and/or lens.  My suggestion would be to get a book on photography basics, review your camera's user manual, and maybe even take a photography class in your area.  Then you'll understand what you can and can not do with your gear.
Whatever you decide to do, you really should just play around with your camera's settings before you go to your event.  Trying various settings that you don’t understand while at a shoot is a guarantee of failure.
 Stan in NH's gear list:Stan in NH's gear list
Sony a6400 Sony a7R IV
Good points Stan.
Here are some good online resources (that I keep handy) for the OP...
http://photography-on-the.net/forum/showthread.php?t=414088
http://www.shortcourses.com/use/
http://luminous-landscape.com/essays/learning-to-see.shtml
http://luminous-landscape.com/tutorials/
http://www.cs.duke.edu/~parr/photography/faq.html
Happy reading!
R2
guinness2
guinness2 Veteran Member • Posts: 4,617
Pardon my ignorance, what is homecoming aka HOCO?
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
Watty dp Junior Member • Posts: 49
In the US a homecoming dance is a high school dance in the fall that usually coincides with a football game that afternoon.   The dress is normally formal or semi-formal so pictures of the couples are often taken while they are dressed up.
One other thing you might do it to go to Youtube and search for "t3i portrait settings" and some variations of that to see some videos that might help you figure out what settings to use.
I would highly recommend that you have practice sessions as many days in advance as possible to try out what setting you might use.  Take lots of notes so you will remember what setting you used.   If you have a small whiteboard or scrap paper you can write down the settings and have that in the picture when you take the test photos.
Be sure to take extra batteries and memory cards.
mfait Contributing Member • Posts: 690
HOme COming.
 mfait's gear list:mfait's gear list
Canon PowerShot S100 Canon EOS 450D
Digirame Forum Pro • Posts: 41,857
Re: Best HOCO pictures - Don't Use Auto Mode
I would suggest taking pictures in Av mode.  Change the aperture to F9.  I assume your lens is the Canon 18-55mm kit lens.  Don't use auto mode.
With relatively shorter focal lengths and F9, most everything should be sharp.  This is advice for a beginner and is not intended to be followed for the advanced user (although the advanced user may do the same).
If you have sunny weather use ISO200.  If the weather is cloudy consider using ISO400.  This will give you a relatively fast shutter speed.  If you want a faster shutter speed, use ISO800.
Here is an example with a Canon T2i (550D) camera and a Canon 18-55mm kit lens.  We had cloudy weather so I used ISO400 to get 1/400th of a shutter speed.  If you want everything sharp far and near, keep the focal length near or at 18mm and get close to your subjects.  That's what I did here too.
There's other ways and approaches to this, but I hope that helps until you learn more about your DSLR camera.
