Bean bag or not on safari in East Africa
Started Sep 18, 2018 | Discussions
Chizuka
Chizuka Contributing Member • Posts: 967
Hello again,
for those of you who have been on a safari in East Africa, would you recommend a bean bag for a MFT camera (and PL 100-400)?  If so, which one would you recommend (with weight being an issue, even if it would be empty on the way to)?
Thank you in advance for all your valuable help.
“Make visible what, without you, might perhaps never have been seen.” -
Robert Bresson.
https://500px.com/blue_iris
https://www.flickr.com/photos/chizuka/
 Chizuka's gear list:Chizuka's gear list
Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Sony RX10 IV Olympus OM-D E-M10 II Panasonic Lumix DC-G9 +5 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Re: Bean bag or not on safari in East Africa
Chizuka wrote:
Hello again,
I only shoot UK wildlife - and the light is normally quite poor - but having used the PL100-400 for 2 years now, no longer even use a monopod, but a cheap lightweight monopod can be of benefit if you can't rest or brace yourself against something. I am not sure how a bean bag would be of help.
How do you anticipate using the bean bag?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Dave Bennett Senior Member • Posts: 1,655
Have you been on safari before? I was in South Africa on safari in July and can't say I ever felt the need for a bean bag (I was using my 40-150 plus MC14 and 75-300 (both Oly)). If it would be to steady the combo on one of the side rails on the 4x4 then you would most likely find that the rails are too low and you would have to sit lower in your seat. Not easy or comfortable. I would be worried that the bean bag would simply slip off the rail and fall into the bush where you wouldn't be permitted to retrieve it.
Far better to rely on IBIS for flexibility rather than the restrictions that trying to use a bean bag would bring.
Dave
Welsh Photographic Federation Judge
External Competition Secretary, Cwmbran Photographic Society
Chizuka
OP Chizuka Contributing Member • Posts: 967
Adrian Harris wrote:
Chizuka wrote:
Hello again,
It would be used against the window of the jeep or other post or support on the jeep.
Robert Bresson.
See my post. I think it would be more trouble than it's worth. The monopod idea is a good one. However, I didn't use mine much in July due to space on the 4x4.
Dave
Mariusbr Junior Member • Posts: 38
Hi, I used one on my last trip to the Krüger park, and found it quite benificial. The beanbag had a tripod screw, so there was no risk of losing it.
 Mariusbr's gear list:Mariusbr's gear list
Canon PowerShot S95 Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +8 more
MacroLunchtimes
MacroLunchtimes Regular Member • Posts: 283
I've been to Kruger and Sri Lanka safari's with lens, if you are lucky you won't have a full jeep, allowing space to move about and get a decent resting place. If normal/unlucky the jeep will be full, everyone will be moving about ,the resting positions in jeep will be limited.
I found with G9 and 100-400mm the IS is suitable and as its a lighter long lens it'll be fine handholding.
You can use rucksack/spare fleece to rest on rather than a specific bean bag.
Good luck
 MacroLunchtimes's gear list:MacroLunchtimes's gear list
Olympus E-M1 III Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +1 more
Albert Valentino Veteran Member • Posts: 9,762
Chizuka wrote:
Hello again,
You can always use a jacket or a towel in a pinch. Even some laundry in a pillow case will do. My point is there is little need to pack something extra
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
Chizuka
No I habpve not. But, I think that the jeeps used in Tanzania are different than those used in S.A. A bean bag could be used against the side of the jeep when standing for example. See picture.
Robert Bresson.
Chizuka
Albert Valentino wrote:
Chizuka wrote:
Hello again,
thanks Albert for your advice.
Robert Bresson.
Chizuka
we will be the lucky ones!!!
I too hand hold the G9 and 100-400mm for a while but I thought that a bean bag would allow me to rest my arm and probably add stability.
Good luck
Robert Bresson.
C Sean Veteran Member • Posts: 3,423
Can I ask you how many safaris you been on?
The reason why I'm asking you this because I do believe you're over complicating what could be a once in a life time trip. All you need for your trip is a few camera bodies, binoculars, a hat and sun glasses. Then there's the factor 50 suncream, bug spray etc.
To answer your question, you don't need sand bags and most people can get along without them. You can rest your elbows on your thighs and there's your tripod. You don't need all this support unless you're shooting with something like the 600mm 4.0 and my advice for you is good luck. Luckily most safari vehicles in East Africa often supply sand bags if anyone need them so you don't need to bring your own.
BTW sands bags don't effect your sightings and it doesn't effect how many people in your vehicle. Your main goal on day one is to find the right people to share the vehicle with or there will be tensions like in your typical Big Brother house. Here is an example, my last safari, the sightings of big cats were low and we had a lot of birders in our group. The birders stuck together in one vehicle and I made sure I stayed in the other.
A friend knows some people who went to Kruger for four days and they didn't see a single lion. It does happen and nothing is guaranteed except for your common herbivores. You might have some exciting sightings and you might have some animals eating grass.
Algreen345 Contributing Member • Posts: 746
If you are self-driving, a bean bag can be convenient - especially the kind that is designed to drape over the car door when the window is rolled down.  You can buy them on ebay and fill them with rice and beans when you arrive.  If you plan to bump around the back of a safari wagon, you won't use the beanbag.
HRC2016 Veteran Member • Posts: 6,874
No
Just bring a sock and fill it with beans or something when you arrive. Then you can wash it and wear it. Beanbags are not very helpful in most situations.
Rather then using sunscreen get a good sunshirt and wide brimmed hat. That will mean fewer chemicals on your skin and less chance of getting lotion on your gear.
I'd recommend a natural bug repellent, too.  Something like Herbal Armor.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
Chizuka
Thank you for your comment C. This will be my first safari. I probably would not have any questions if it was my 2nd or 3rd, but I doubt that will happen.
Robert Bresson.
northlondon43
northlondon43 Senior Member • Posts: 1,941
+1 NT
Adrian
An amateur, atheist, alliterationist
 northlondon43's gear list:northlondon43's gear list
Fujifilm X100V Panasonic Lumix DC-G9 Panasonic Lumix G 25mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +4 more
northlondon43
I've also been on several safaris which have either been self drive or open jeep. I really do hope this isn't the kind of vehicle you'll be in as they're very restrictive in terms of moving around (I've observed plenty of them in national parks.. private reserves don't use them where I've been). Bean bags are not going to help anyway  even if you could elbow everyone out of the way 😊
Adrian
absoluutbeginner
absoluutbeginner Contributing Member • Posts: 660
I use the blanket that you get during the flight instead of a bean bag .
You roll it up ..and it works fine and is soo much lighter in weight .
And on the flight back you leave it again in the aircraft ..... eco friendly too
Chizuka
Robert Bresson.
There's nothing wrong with asking questions and it's great to have people here who been on safari who can give advice. What you don't want to do is over complicate things and when it comes to big animal sightings, you need to get the camera ready.
What you should be looking at is Back Button Focus and set different custom settings for your camera for different scenarios. So you have a custom setting for good light, setting for low light and shutter speed setting. This way you don't have to tweak so much of the settings to get the expose correct and after you done the camera revert the settings back to how they were before the minor adjustments. This way you don't have to manually input the camera setting from good light to low light and to good light again. All you have to do is adjust the dial, tweak the exposure triangle and you're done.
