Cheese market Alkmaar - K-70
Started Sep 18, 2018 | Discussions
newmikey Veteran Member • Posts: 5,203
11
I took my K-70 with the 16-85mm lens out on a little bicycle ride into the centre of the Dutch town of Alkmaar where the faous cheese market is located. Due to the limitations of bicycle travel, I brought an ultralight 4-section tripod (Redged TST-423K) with me for some longish exposures towards the end of the blue hour.
This is the famous spire of the "Weighing Tower" or "Waagtoren" as it's called in Dutch. There's a mess of different kinds of illumination going on both in the foreground as well as in the floodlighting on the tower itself. I took 3 bracketed exposures but I ended up using the middle of the -2, 0, +2 series and pulled up the shadows in Darktable during raw conversion a bit (apart from some geometric corrections) after which the image transferred into Gimp for a bit of sharpening.
I duplicated the whole image into a new layer for sharpening with GMIC's "Freaky details" filter at 40% opacity and then proceeded to select and remove the evenly-colored portions of the top layer to avoid excessive noise in the sky due to the sharpening.
What continues to excite me about the K-70 is the ease and flexibility of the articulated screen, used here in live-view with the focusing square moved onto the tower itself. Of course, as I will show in following posts, the performance of the K-70 hand-held at higher ISO ranges is also something which, coming from the K-5 series, continues to amaze me.
 newmikey's gear list:newmikey's gear list
Pentax KP Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 85mm F1.4 EX DG HSM Pentax 16-85mm F3.5-5.6 WR +2 more
Pentax 16-85mm F3.5-5.6 WR Pentax K-70
OP newmikey Veteran Member • Posts: 5,203
Same subject, different angle, handheld ISO5000
The difference is clearly visible. Processing of the PEF raw file is as with the previous example.
ozdean
ozdean Forum Pro • Posts: 28,665
Re: Same subject, different angle, handheld ISO5000
Nice work Mike.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
