New Canon...
Started Sep 18, 2018 | Discussions
SheilaO New Member • Posts: 8
New Canon...
Would any Canon afficionado be able to assist me? I need to update my camera, and I will be staying with Canon as my lenses are all that make (28-135 mm, 50 mm and 18-55 mm). My present camera is a Canon DSLR 300D, and it’s twelve years old. I would appreciate some advice on the best model to get, and whether it would be a good idea to buy secondhand.
Many thanks,Sheila
Canon EOS 300D (EOS Digital Rebel / EOS Kiss Digital)
whakapu Senior Member • Posts: 1,051
Re: New Canon...
Well, Canon now have a ridiculous number of models. Which is best for you would depend on what you like to photograph and your budget. You could also consider whether you want to stck with DSLR or go mirrorless (with the adapter for those lenses). The 200D is a very compact and good value option in the Rebel line, and an M50 a mirrorless version of that with a couple of extra twists (like limited 4K video).
Jonsi
Jonsi Veteran Member • Posts: 6,285
Re: New Canon...
Just FYI....
There are some Canon-specific forums here, full of people who shoot Canon and many have upgraded from the 300D like you.
You will probably get more, and better advice there.
crashpc Veteran Member • Posts: 7,240
Re: New Canon...
Many thanks,Sheila
Hey there.
Between Canon EOS SL2 / 200D, EOS M50, 800D, 77D and 80D worth mentioning, I would think twice about your lenses.
The sensor technology moved on quite a bit, and some of your lenses might not be able to support the image quality which this sensor can achieve.
Especially original 18-55 is pathetic by todays measures. You would really appreciate getting newest, or second-newest 18-55, Not only it is stabilized, it is much sharper.
The 50mm f/1.8 also got "a bump", and I don´t know personally about 28-135.
Yes, it might get expensive, but good compromise needs to be done.
For EOS M50 - normal EF-S lenses will not fit without adapter, and I highly recommend use equivalent native lenses if these exist (depends on lens model).
For any choice you do (from mentioned camera models), the jump will be quite significant.
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
Rexgig0
Rexgig0 Veteran Member • Posts: 7,399
Welcome!
Many thanks,Sheila
Welcome to the forums!
Open Talk is not necessarily the best place to ask a Canon-specific question, but perhaps we can help steer you to the correct section of the forum. If you wish to stay in the “consumer” model series, the Canon Rebel (200D-800D) Talk will be your “home.” If you wish to upgrade to an enthusiast-level camera, which facilitates your taking more-direct control of your shooting, and offers such features as the ability to micro-adjust your camera’s AF with individual lenses, the Canon EOS 7D/10D-80D Talk section is the place to look. EOS M Talk is the place for the more-compact mirror-less system cameras, which can use your lenses, with an adapter.
I started with a second-hand XTi, a.k.a. 400D, which my wife had bought from a colleague, to try digital shooting. (She had subsequently become a dedicated Nikon fan, when her employer issued her a Nikon D300s.) I appreciated a camera with more-direct control, better ergonomics for my hands, and better weather-sealing, so bought a second-hand 40D.
My next step was a new 7D, in late 2010, for even better performance, for some of the shooting I planned to do, and even better weather-sealing. I soon added a second, pre-owned 7D, because I was using my cameras while on duty, as a public servant, and felt compelled to exercise a professional level of care and diligence. In 2014, I upgraded to 7D Mark II cameras. So, other than the 40D, I cannot be helpful with specific information on Rebels, EOS 100D-800D, and EOS 10D-80D cameras, though they are very good cameras, depending upon one’s preferences.
The EOS M system is nicely compact, with its own EF-M lenses, and an available adapter which allows using your EF and EF-S lenses. I really liked my M3, which I used with the adapter. I would still have it, but Hurricane Harvey decided otherwise. (Fortunately, most of my things, including the rest of my Canon gear, survived.)
Buying pre-owned/second-hand cameras can be a very good idea. Buy smart, from reputable sellers, for best results. I live near Houston Camera Exchange, in Texas, which are reputable, and honor a 30-day warranty. That is where I bought my pre-owned 7D in early 2011, and my pre-owned 1Ds Mark III, in 2018, plus most of my pre-owned lenses.
I wore a police badge and pistol, and made evidentiary images at night, incorporating elements of portrait, macro, still life, landscape, architecture, and PJ. (Retired January 2018.) I enjoy using Canon and Nikon gear.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +54 more
Rexgig0
Re: Lenses
Many thanks,Sheila
Your 18-55mm kit lens may be getting a bit tired. As it is so economical to buy a new camera with an included kit lens, I recommend doing so when you upgrade, if you buy a new camera.
Your 50mm lens may be getting tired, too, if heavily-used, but it may well continue to provide good service for many more years. There is probably no need to replace/upgrade this one, yet. My EF 50mm f/1.8 is probably actually older than yours, with the somewhat-collectible “metal mount” feature, but optically identical to its successor, which was in production at the time of the 300D camera.
Your 28-135mm lens, if kept in a clean, dry place, may continue to serve well. This is a quite useful lens. This is the lens packed as a kit lens with my first 7D camera, and remained quite useful until I upgraded to an EF 24-105mm f/4L IS lens, in 2014. Its only “fault” was that 28mm is not very wide-angle when used on a “cropped-sensor” APS-C camera. I simply bought a nicely wide-angle EF-S 10-22mm lens, to complement the 28-135mm lens, soon after I bought my first 7D. Canon now makes a more-economical EF-S 10-18mm lens, though that will leave a larger gap, from 19mm to 27mm, if you choose this one to complement your 28-135mm lens.
Personally, I tended to use my EF-S 10-22mm lens at 14mm and 22mm. (Others’ preferences may vary.) After my EF-S 10-22mm lens suffered structural failure, after more than six years of hard use, which included more than one impact against vehicle doors and door frames, one tumble from a vehicle seat onto pavement, and unknown knocks while being loaned to a colleague, after which I found the filter to have been badly chipped, I would buy a replacement EF-S 10-22mm lens, if I still shot only with APS-C-sensor cameras.
I should emphasize that ultra-wide angles are an acquired taste, and you may never desire to own a zoom lens that starts at 10mm.
OP SheilaO New Member • Posts: 8
Re: New Canon...
Thanks Jonsi, I'll look at them
Sheila
Re: New Canon...
Thanks so much for the advice, I hadn't thought of it like that - in my innocence I thought lenses stayed the same, but of course they also move on with the improvements in technology.  Maybe I will just have to begin again... Tell me one more thing, is it safe to buy secondhand, and how can you know if you are getting good equipment?
Thanks again,
Sheila
Re: New Canon...
Cann you tell me what is the advantage of mirrorless?
Thanks,
Sheila
Re: Welcome!
Thank you so much for your very helpful reply. I'm learning a lot from all your answers,
Sheila
Re: Lenses
Thanks very much for your advice, especially regarding the continuing value of my old lenses, as I thought that I might not be of any use.
Many thanks,
Sheila
Re: New Canon...
Thanks again,
Sheila
It might be too much information from so many people, but hope you manage.
For the second hand things, only thing you can do is: Check for bumps and scratches (especially on the lens elements), cleanliness of the inner lens elements - no dust, not weird stuff, fungus and such..., clean smooth movement of focus ring and zoom ring, if lens barrel is supposed to move during focusing or zooming, it should go about smooth. No crackling sounds or scratching. No big wiggle to the side, but little is allowed.
Check if no "maps" are visible on the device, which might be caused by liquid intrusion.
Check if ellectrical contacts are clean and look "gold", no oxidation....
Test it on the camera, check it if doesn´t make weird noises during focusing and if image stabilization works (it´s relatively subtle, but you should spot it at longer focal lenghts when zoomed in). Especially when you compare it on/off...
Then you should take some image of a "straight thing" like a wall, from a good distance (10-20 feet) and check for general sharpness and corner sharpness. Might not be stellar, but should be EVEN across the frame, especially when stopped down to larger aperture numbers like f/8 or more.
And that´s it. After you checked this (takes like four minutes when experienced) you have to rely on your luck. I bought a lot of used stuff and not a single thing was bad, broke on me, or anything like that.
Wish you good luck!
About mirrorless: It usually is smaller, it´s build more around responsive "digital" UI. So ellectronics viewfinder and LCD. The focusing is "super precise" because it works directly from the image sensor. Yet can be little slower. Also it needs different set of lenses, or it needs the adapter to adapt normal DSLR lenses.
DSLR has usually better ergonomy, more hardware controls, and of course, optical viewfinder - You do not see what you´re going to get before you shoot. You have to shoot and then check. But the viewfinder is nice and "real time" while mirrorless cameras can bring delays, lag and noise to the viewfinder.
DSLRs have dedicated focusing system. generally better and faster, but it might be a draw sooner than later.
mirrorless can be made smaller, but not all setups are smaller. Some are as big as with DSLRs. So it is matter of ones preferences.
Re: New Canon...
This is a point of great debate but removing the mirror means the body can be smaller, lenses can be smaller, mirrorless bodies (with the right adapter) can attach almost any lens but sometimes only in manual focus. You generally get an electronic viewfinder with mirrorless which means that you're always seeing your actual exposure. Because there is no mirror to move you can have faster frame rates and sometimes silent shooting. Downsides include shorter battery life, more exposure to dust. In the past they haven't focused as well on moving subjects but that is changing.
Someone made a good point about lenses. They'll work at least as well on a newer body but won't give you the full performance of a new body. If you do replace lenses I can recommend any of Canon's STM range. They're light, cheap and sharp. The only negative is that focus is all electronic so manual focus is tricky. Also, looking at the lenses you currently have, you don't seem to require extreme focal lengths so a bundle with an 18-135 STM might meet all your needs. Also Canon's new G1X-III is essentially the same camera as their current Rebel and mirrorless series but with a fixed zoom lens. It's not cheap though.
dmi
dmi Regular Member • Posts: 157
Re: New Canon...
Many thanks,Sheila
Hi Sheila,
I just ordered a refurbished SL2 (200D) directly from Canon:
https://shop.usa.canon.com/shop/en/catalog/cameras/refurbished-eos-interchangeable-lens-cameras
I have not yet received it, so I can't say anything about the condition of the camera, but I have seen multiple people on this forum recommend the refurbished store, so I feel optimistic. The savings are pretty good, and they have just about every current model of Canon camera available.
The big retailers, (B&H, Adorama, etc.) have used departments, so you might also check there.
Best of luck with your search!
Danny
Lepewhi Senior Member • Posts: 2,105
Re: New Canon...
I would also suggest the Canon refurbished online store.  They also have lenses.  Try looking at a Sl2.  It's small, about the same size as a mirrorless, but you won't need an adaptor for your existing lenses.  But, if video is your thing, you might consider mirrorless, but would go Sony.
Slippery when wet.
 Lepewhi's gear list:Lepewhi's gear list
Panasonic Lumix DC-GX9 Panasonic Lumix DC-G100
Rock and Rollei Senior Member • Posts: 2,916
Re: New Canon...
dmi wrote:
Many thanks,Sheila
Hi Sheila,
Danny
Given Sheila is talking about the 300D rather than a Rebel, it looks likely she's not in the US, which rules out the Canon refurbs and rather limits NYC retailers.
Sheila, where in the world are you so we can make tailored suggestions?
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
Re: New Canon...
Isn't the 300d a Rebel?  They didn't go to the T series Rebel title in the States until later.  I could be wrong.
Slippery when wet.
Re: New Canon...
It was the Digital Rebel in the US.
Helen
Helen Veteran Member • Posts: 7,606
Re: New Canon...
Elsewhere in the world the Rebel title wasn't used - instead, numbers, starting with the original EOS 300D which the OP has.  Only Japan also used a name, and still does - EOS Kiss.
Helen
Re: New Canon...
Thanks,
Sheila
If you like interchangeable lenses, but also like the fact that on smaller digital cameras with non-interchangeable lenses you can look at the scene as it appears to the sensor on the rear screen before shooting, with all the effects visible and the shooting data superimposed if you wish (which is called live view), mirrorless combines both seamlessly.  Mirrorless cameras with built in viewfinders - electronic viewfinders, EVF for short - also allow this at eye level and almost all will automatically switch between EVF and LCD using an eye sensor.  All modern cameras, whether DSLR or mirrorless, can shoot good video these days - mirrorless allows eye level shooting and reviewing if it has an EVF (both types can also do these on the LCD rear screen, of course).
DSLRs newer than yours can also do this on the LCD only - you switch them into this mode as it is not their standard mode of operation.
Mirrorless cameras allow the body, lens mount and lenses to be smaller, and the majority have lenses that focus silently, without extending or causing the focus ring to spin as they autofocus - though Canon's new STM lenses for the EOS DSLRs also autofocus this way.
Finally, many mirrorless cameras have the option to shoot in silence, without any mirror noise (since they don't have one) or shutter noise (most DO still have the same type of shutter as your DSLR).  However, Canon has so far only included this feature on its latest EOS M50, in a slightly limited, program-only special mode.  Other brands often have more flexible silent shooting options.
Downsides of mirrorless: because they are always in live view, the battery needs recharging more often, and they don't always focus quite as fast as the fastest modern DSLRs (this is usually only noticeable in continuous AF and they will be faster than your elderly DSLR by quite a margin anyway) and they have a different lens mount - in the case of Canon's EOS M mirrorless line, a compact adapter allows you to fit EOS DSLR lenses to them and carry on using them as normal in most cases.
Despite using film SLRs for many years previously, I find I enjoy mirrorless most of all.
