No more shooting with hood in reverse position?
Started Sep 17, 2018 | Polls
voronspb
OP voronspb Senior Member • Posts: 1,999
Re: No more shooting with hood in reverse position?
Oh, and probably one fact may clarify my shooting style for you: I replaced the camera neck strap to 3-mm cord to save space inside the bag and simplify the placement.
Vladimir Gorbunov
«What's the size of your mount, is it wide enough?»
 voronspb's gear list:voronspb's gear list
Sony a6500 Sony a7 III Tamron 17-28mm F2.8 Di III RXD Sony FE 35mm F1.8 Tamron 70-180mm F2.8 Di III VXD +8 more
RedFox88 Forum Pro • Posts: 30,738
Re: What is the benefit of shooting...
voronspb wrote:
Silvex wrote:
...with the hood reversed? Why not just leave the hood in the bag or in the closet? Is there something I'm missing out on?
The camera bag or lens pouch may appear too small for the lens with hood in shooting position. I normally store the hoods on my lenses, so when I take the camera or lens from the closet, the hood is always there, attached in reverse position.
Then take the 5 seconds to put the lens hood on so it functions as a hood! Doh! 🤔🙄🤦‍♂️
I never leave the lens hood at home since my '2011 Iceland trip, when I had lots of images ruined with water drops on filter. For that trip, I left the hood at home, because on old EF 24-70/2.8L it was really enormous in size.
Vladimir Gorbunov
voronspb
Why would I need it unless there's a risk to contaminate or damage the filter in front of lens? Many people completely disregard the use of hood, and they're pretty happy.
Vladimir Gorbunov
Steve Balcombe Forum Pro • Posts: 15,571
Ignorance is bliss.
voronspb
Steve Balcombe wrote:
Ignorance is bliss.
Tell it to Mr. Ken Rockwell, not me. https://kenrockwell.com/nikon/18200/18200-hood.htm
Vladimir Gorbunov
Ignorance is bliss.
Good old Ken, the world would be a duller place without him
Mike CH Veteran Member • Posts: 9,631
Hood itself as protection
Many people actually use the hood instead of a protective filter. It depends on what, exactly, you are protecting against. And it’s a very common discussion that hasn’t been agreed yet 😜
Regards, Mike
Wait and see...
I hardly ever speak for anybody but myself. In the cases where I do mean to speak generally the statements are likely to be marked as such.
 Mike CH's gear list:Mike CH's gear list
Canon G7 X II Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 16-35mm F2.8L II USM Canon EF 100mm F2.8L Macro IS USM +14 more
GreatWhiteWing Senior Member • Posts: 1,675
voronspb wrote:
I've just took note of the fact that the control ring on genuine RF lenses is always located at the foremost part of the lens:
Before this moment, the hood in reverse position usually blocked only manual focusing. I like shooting with reverse hood, and I hated the foremost placement of zoom ring in my Tamron 70-300 mm lens, so I had to employ the push-pull zoom technique with that lens.
But now, with RF lenses you'll simply lose access to a certain camera setting until you remove the hood. Alternatively, you'll need to have two dials assigned to the same setting, or simply set the Lens Control Ring to OFF.
I wonder, if other people value shooting with stored hood as much as me, or it's just a minor inconvenience, doesn't worth mentioning?
Is there a reason to deliberately shoot with hood mounted reversed? I only reverse mine for storage in the bag. Just curious
 GreatWhiteWing's gear list:GreatWhiteWing's gear list
Canon EOS 5D Mark IV Canon EF 24-70mm F4L IS USM Canon EF 16-35mm F4L IS USM Tamron SP 70-200 F2.8 G2 +2 more
Rick Knepper
Rick Knepper Forum Pro • Posts: 17,870
Ignorance is bliss.
While I just recently used a lens without the hood in Carlsbad Caverns, :), this statement of KR's didn't strike you as totally stupid?
Once you've done fifty, anything less is iffy.
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Sony a7R IV Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW +11 more
Le Kilt Senior Member • Posts: 2,527
Rick Knepper wrote:
Ignorance is bliss.
Yes, amazing the crap you can get away when it's published on a web site.
 Le Kilt's gear list:Le Kilt's gear list
Digitalis32
Digitalis32 Contributing Member • Posts: 574
I fail to see the problem here, Canon makes one minor ergonomic change and now you will be using the lens hood properly, like everyone else.
A camera is just a camera. Who is behind, it matters far more.
 Digitalis32's gear list:Digitalis32's gear list
Leica M Monochrom (Typ 246) Leica M (Typ 262) Pentax KP Pentax K-1 II Leica Summilux-M 21mm f/1.4 Asph +13 more
NRBlack
NRBlack Contributing Member • Posts: 706
Ignorance is bliss.
Hoods on most wide zooms are only really functional at the wide end. Still they protect the front from bumps. Also, I like zoom cases. I can leave the lens cap off since the hood protects the lens front when in the case.
There is one exception to the effective hood situation and that is the original 24-70 f/2.8. It was a reverse zoom in that is was longest at the short end and the hood was attached to the body and not the zoom extending part. Therefore the hood was just as functional at 70mm as it was at 24mm. Flippin brilliant design but most people thought is was weird.
Push-pull zooms get a similar reaction. Ideal for lens balance, at all focal lengths, on heavy long extending zooms. Push-pull just rubs people the wrong way.
 NRBlack's gear list:NRBlack's gear list
Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 85mm F1.8 USM +4 more
Lawn Lends
Lawn Lends Senior Member • Posts: 2,432
Le Kilt wrote:
Rick Knepper wrote:
Ignorance is bliss.
Isnt Rockwell known for including some pretty inane statements.
 Lawn Lends's gear list:Lawn Lends's gear list
Canon EOS 6D Canon EOS 5D Mark IV Sony a7R III
Rick Knepper
Lawn Lends wrote:
Le Kilt wrote:
Rick Knepper wrote:
Ignorance is bliss.
He’s legendary for it.
voronspb
Yes, I owned the old 24-70/2.8L. What's funny, I almost always left the hood at home because of its enormous size. In Iceland this led to a lot of pictures ruined by water drops on filter.
It was impossible to zoom the lens with hood in reverse position, which made me mad. While cycling, every other action required to start and finish shooting means that either your group will ride farther away, or other people will be waiting for you a bit longer under rain. Neither is good for you. Also I worried about the strength of hood bayonet, it was weak enough to be damaged during rough riding with camera on handlebar.
With 24-105/4L it became a lot more convenient, because I wasn't obliged to engage the hood every time before shooting. And also it became possible to carry the lens in bag with hood in shooting position (without the front cap) to save even more time.
Vladimir Gorbunov
