Canon ES-60 Lens Hood for 32mm lens (PIC)
Started Sep 12, 2018 | Discussions
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
An image of the Canon ES-60 Lens Hood has surfaced. The shape isn't one I'm particularly fond of (I prefer the petal type) although i note that Canon prefers the tubular type of lens hood for some bright primes like the 50mmL and 85mmL lenses.
Looks to have a lockdown tab on the side (similar to the EF 100-400mmL USM lens hoods) which ought to be just shy of the Minimum Focus Distance. These hoods appear to be Made in Malaysia where Canon's plastics manufacturing plant has been located for some time. I wasn't going to buy a lens hood for this lens but I may yet reconsider if the price isn't ridiculous. The image below is a mockup if how I think the hood ought to look on the lens (posted a few days ago in another thread).
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
dave_bass5
dave_bass5 Veteran Member • Posts: 7,342
Re: Canon ES-60 Lens Hood for 32mm lens (PIC)
Ill get the much cheaper 3rd party one when they are available.
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
(unknown member) Regular Member • Posts: 209
Looks pretty huge. ¯\_(ツ)_/¯
lumenite Senior Member • Posts: 1,207
Wow, It looks like a telephoto lens like 85mm f/1.8.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
StevenSHH
StevenSHH Contributing Member • Posts: 609
Ditto, I will probably go with JJC when they have it. Pricing is a bit of shocker lately on these original lens hoods.
Have fun with photography! Start taking photos!!
 StevenSHH's gear list:StevenSHH's gear list
Canon EOS M6 II Canon EF 24-70mm F4L IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 32mm F1.4
mouzhik
mouzhik Regular Member • Posts: 404
"An image of the Canon ES-60 Lens Hood has surfaced. The shape isn't one I'm particularly fond of (I prefer the petal type) although i note that Canon prefers the tubular type of lens hood for some bright primes like the 50mmL and 85mmL lenses."
I am not sure it's a matter of preference, I can imagine it's more about optics and field of view: petal type hoods for wide-angle primes and zoom starting with wide angle, tubular hoods for everything from 50mm and longer, referring to Canon full frame lenses.
32mm  x 1,6 = 51,2mm -> tubular type lens hood...;-)
 mouzhik's gear list:mouzhik's gear list
Canon G1 X III Ricoh GR III Canon EOS 5D Mark II Canon EOS Rebel SL1 Canon EOS M6 +13 more
I see RF 50mm f/1.2 with non tubular type hood.
Marco Nero
OP Marco Nero Veteran Member • Posts: 7,582
Literally worthy of mockery...
That's just ridiculous.  So the original Photoshopped image was actually correct.  Looks like I won't need to secure one of these stupid things.  What a bizarre decision from Canon.  The tiny little lens hood on the 11-22mm lens was undersized.  Now this.  Oh man.  Does Canon understand the concept of modern design Vs consumer desire?  This is literally worthy of mockery.
Marco Nero.
Marco Nero
Yeah, I'm going to buy one of those.  But the design factor should have come along with the 50mm lens.  At least the optics are recessed and I can add a filter (which will shield the lens further from side-flare).
Marco Nero.
Marco Nero
What happens when you reverse it? ...
What happens when you reverse it?  The switch will be covered, right?
Marco Nero.
Marco Nero
Re: What happens when you reverse it? ...
Menwhile... this shows up on DPreview....  those pesky fisheye lenses with their latent lens hoods....
Marco Nero.
