V3: mechanical vs electronic shutter - panning
All images shot in RAW, processed in DxO 11 using Prime, microcontrast 25. The PGNs were imported into Photoshop Elements, clicking on "automatic". No further editing.
#1. V3, mechanical shutter, no VR, 1/2500 sec [fast panning]
#2. V3, mechanical shutter, no VR, 1/4000 sec [slow panning]
With the mechanical shutter, fast panning wipes out most finer vertical structures. Even a slow panning movement and 1/4000 sec doesn't retain much vertical fine detail.
#3. V3, electronic shutter, no VR, 1/5000 sec [fast panning]
Now let's try the electronic shutter. Again, fast panning wipes out vertical fine elements. No surprise so far. But then...
#4. V3, electronic shutter, no VR, 1/16000 sec [fast panning]
A surprise - the vertical fine structure is visible again. Is it the fast shutter speed?
The high ISO 5600 isn't appealing, but under perfect conditions high shutter speeds of 1/8000 sec or more are possible. Further tests are necessary.
Next I tried to set the VR on "active", which had always been my preferred BIF setting. We start with the mechanical shutter, just as in the series above.
#5. V3, mechanical shutter, VR active, 1/2500 sec [fast panning]
#6. V3, mechanical shutter, VR active, 1/4000 sec [slow panning]
#7. V3, mechanical shutter, VR active, 1/4000 sec [fast panning]
Apparently the mechanical shutter doesn't profit significantly from the active VR setting. The vertical fine structure is mostly gone. It seems to me, however, that the horizontal elements are clearer than in the shots taken without VR support.
But a selection bias may be in play - from several shots I tended to select the clearest.
#8. V3, electronic shutter, VR active, 1/10000 sec [slow panning]
#9. V3, electronic shutter, VR active, 1/10000 sec [fast panning]
#10. V3, electronic shutter, VR active, 1/16000 sec [fast panning]
I'd say that the electronic shutter cooperates very nicely with the "active" VR.
