Make your own dry bag
Started Sep 10, 2018 | Discussions
Offside Veteran Member • Posts: 6,246
I've spent a lot of time looking for a dry bag for my travel tripod. Never found one that was not overkill.
Ran across an article on how to make your own dry bag.
You'll need dry bag fabric, nylon or polyester strap, a good adhesive, and a buckle.
Below are links to fabric.
Outdoor Wilderness Fabrics
http://www.owfinc.com
Seattle Fabrics
https://www.seattlefabrics.com/
I bought from Seattle Fabrics because it was the only company I was aware of at the time of purchase.
These fabrics are designed to be sealed with a hot iron.
I'm using the 400 denier fabric, E6000 adhesive, and strap and buckle purchased at a local outdoor store.
Here are some DIY links.
https://www.questoutfitters.com/DIY%20Custom%20Dry%20Bags.pdf
http://www.canoetripping.net/forums/forum/general-paddling-discussions/diy/83031-making-diy-dry-bags
http://www.paddlewise.com/topics/boatequip/drybag.pdf
I'll post a pic of the finished bag once completed.
Alan
HEA-45 Regular Member • Posts: 413
Re: Make your own dry bag
I never heard of a "dry bag." What is this? Is it used exclusively for a tripod?
 HEA-45's gear list:HEA-45's gear list
Nikon D810 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-120mm F4G ED VR +7 more
NancyP Veteran Member • Posts: 6,608
"dry bag" is a generic term for a urethane cloth or silnylon or plastic bag designed to keep water out (and air in), used by paddlers who want to have guaranteed dry (clothing, sleeping bag, electronics, etc). Dry bags come in all shapes and sizes. There are dry bags that look like duffels, dry bags that fit into the pointed ends of kayaks, dry bags attached to waistbelt, ..... All have either a roll-top top (roll at least 2 to 3 times) or a much sturdier version of a zip-lock bag seal. All should have some form of seam seal (paint-on urethane, to plug the needle holes for sewn items, as well as waterproof fabric.
I don't play around with dry bags for electronics and expensive items. I buy top quality, because all it takes is one overturned kayak / canoe to wreck electronics. It is ok to double dry bag clothing, etc.
Watershed brand has a gear bag for photographers.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
I haven't found a great long skinny dry bag for a tripod, either.
NancyP
Sigma DP3 Merrill
Thank you! You answered a question for me. I am thinking of getting a small canoe next season. Besides the great pleasure I will bring for its original purpose, I can also use it to reach previously inaccessible photographic locations on the many lakes and rivers in this area. Naturally I will need something to protect my gear- that is my DSLR, camera bag, and tripod.
OP Offside Veteran Member • Posts: 6,246
Re: Make your own dry bag (with pics)
Here are the two bags I made. The smallest is 9 x 30". My travel tripod, with head, is 20" and fits perfectly. The larger bag is 11.5 x 39". These are bag dimensions as they lay flat, not internal dimensions. Each bag has a 1" glue seam on one side and the bottom. A rolled up, self-inflating, 2-1/2" x 27 x 72" sleep pad fits perfectly in the larger bag. So will my larger Manfroto tripod without the geared head.
I've been canoe camping for 25 years and have always put stuff in a strong garbage bag prior to putting it into a dry bag. For my primary camping gear bag, I use the black construction trash bags. For clothing, just a big kitchen trash bag has worked fine. For cameras, I have always used a Pelican box.
My October trip will be the first time I have used a dry bag for a tripod.
Here are my costs for the below two bags:
400D fabric - $22.00 (1 yard - 36 x 58")
E6000 Glue: $5.00 (Warning: this glue does not like to be in contact with the coated side of the bag. I sanded off the coating prior to gluing the strapping at the top of the bag.)
Webbing/straping: $3.50 (11/16" tubular nylon from outdoor store @ $0.22 a foot)
Two buckles: $4.00
Hangar 9 hobby/craft sealing iron: $22.00 (Warning: at a setting of 400 degrees, the knob on the iron gets really hot. I used a temperature laser to test how hot the bottom of the iron was. At around 400 degrees, I would press down for 25 seconds, take the iron off, then press down on the heated spot with a metal ruler till it cooled a little. Overlap the previous heated area about 1/2" with the next iron press. Only burned myself once. And yes, once is enough. I used a metal straight edge to keep the seam consistent. I did a better job of making the fabric square on the larger bag and it looks better.
My household iron would not stay hot enough to melt the inside glue coating to seal the seam so I purchased the sealing iron.
Re: Don't use the E6000 glue
After testing this morning, the E6000 glue is not doing it's job. Not recommended. Going to have to find someone with a heavy duty sewing machine to put some stitching in the webbing to keep it from pulling off. Bummer...
Two buckles: $4.00
Wow, this is awesome! I appreciate the detail. One of my greatest concerns was protecting my gear. I have rented a few kayaks and canoes at local parks over the years, but since it was with friends and family I never brought my photo gear along. As a complete beginner a mishap due to inexperience may occur, and I hate to see my gear be the unfortunate victim. Thanks again!
