Canon 750D / Rebel T6i Problems
Started Sep 10, 2018 | Discussions
Davy_Jones New Member • Posts: 1
Hi guys (and girls) I have a 750D. Had it for two years now. Love the camera, but recently I had a few stuff happen to me that I cannot explain.
I had freezing while shooting, Error 20, very slow shutter when set at fast speed on camera, freezing while holding the focus button, freezing while using external flash.
Shutter is around 40.000 . I had a faulty memory card, replaced that with a new one.
Everything is Canon OEM on the camera except the flash (K&F Concept E-TTL) .
Now the most of these problems have gone, but the one that keeps coming back is the one from focusing. I have set the focus on the back button on my 750D . When i hold it and shoot a moving subject in burst mode the camera freezes every time after 7-8 shots. This happens with every lens that I have (18-55 , 50-250, 70-200, 50 ) . I have also tried a different battery (OEM and non-OEM) . Alyways the same problem.
Has anyone had any of these problem with this camera and especially the one that keeps coming back to me ????
 Davy_Jones's gear list:Davy_Jones's gear list
Canon EOS Rebel T6i
Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
R2D2 Forum Pro • Posts: 26,551
Re: Canon 750D / Rebel T6i Problems
Still sounds like a card write problem (either due to camera, or card).  What card are you using?
R2
Lemming51
Lemming51 Forum Pro • Posts: 15,278
What Image Quality setting?
What make/model speedlite? What flash settings? If it's not HSS (High Speed Sync) compatible or not set for HSS, the camera will force the shutter speed to the x-sync (1/200).
Sounds normal if you've set the camera to save RAW or RAW+JPG. p. 117 of the instruction manual.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
