55-250mm IS - Image Stabilizer not working
Started Sep 10, 2018 | Discussions
DM661
DM661 New Member • Posts: 10
I've had this lens for a few years and it's always performed great. I'm using a T5i and I've taken many photos @ 250mm (400mm equiv) using IS where you can clearly see the image stabilized on Live Preview when depressing the shutter button half-way.
I took a trip to Alaska and when I went to use the lens, to my chagrin, I noticed that the IS just wasn't working.  I cleaned the contacts, messed with the IS on/off switch, etc. and no dif.  Auto focus works fine (as good as it does on this lens) at full zoom.
I can hear the click sounds as if the IS is working, but it's not.  The clicking sound happens whether the lens cap is on or off and also when I have it in manual focus.
My guess is a bad aperture flex cable in the lens, unless someone can point me to another possible reason/fix?  I've read many posts about this and haven't found a case exactly like mine.  The other symptom, although I need to do more tests to confirm this, is bad blurring at the edges.  Probably from trying to shoot at 400mm handheld but not sure.
 DM661's gear list:DM661's gear list
Canon EOS 700D Canon EF-S 55-250mm f/4-5.6 IS II Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF 50mm F1.8 STM
Canon EF-S 55-250mm f/4-5.6 IS Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i)
seri_art
seri_art Veteran Member • Posts: 3,063
Re: 55-250mm IS - Image Stabilizer not working
I have test shots from my T7i with 55-250mm STM lens at 250mm (400mm equiv), hand held, and they are sharp out to the edges.
 seri_art's gear list:seri_art's gear list
Sony RX100 III Canon EOS Rebel T7i Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +3 more
scrup Contributing Member • Posts: 595
IMO these type of lenses are not worth fixing.
You are better selling the lens as is while it still semi works and buying the STM version.
On Ebay a new one can be had for less than 150 USD EFS 55-250mm STM
I had the Is version in the past and the STM version is a step up.
The only parts i see are the aperture flex cable. The risks involved fixing the lens is just not worth it. You could buy the wrong part, break something else while repairing it, not reassemble correctly or brick the lens completely.
 scrup's gear list:scrup's gear list
Canon EOS M Canon EOS M3 Canon EOS M6 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM +2 more
DM661
OP DM661 New Member • Posts: 10
Yeah it's a bummer because I love this lens, even no STM, makes great images.  I'm selling my T5i and upgrading to an A7III here soon so I'll probably just throw it in with the rest at low/no cost.  Thanks!
DM661
Yes I have many shots at 250mm as well that are perfectly fine to the edges.  I'm describing a NEW problem with my lens here.
guinness2
guinness2 Veteran Member • Posts: 4,617
No evidence of malfunction , yet, IMHO.
Find a very small dot target like the wall clock face center and try to aim on it and focus, with IS switched on and then off. No shooting, just halfpress and hold on. If you don’t see the difference when aiming , IS is not working. If you see the “sticky” effect when IS is on, it works.
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
DM661
Yes, that's exactly what's happening.  Thanks.
