G7/70 does not keep on recording in new file?!
Started Sep 4, 2018 | Discussions
thebastian New Member • Posts: 1
Hello @ll,
I am new to Cameras and thought the G70 would be perfect for the beginning.
I can't find a solution in the manual for this:
- Recording videos stops after max. time/size but does NOT go on in a new file.
What am I doing wrong?
SD Card has enough space!
Some background: It is a G70 changed to 30/60 fps - but the max. time is not extended - sadly.
So splitting in several files is not that bad - if it would work.
Additional question: Can I do a firmware update with G7 Firmware on my G70?
Would you suggest to use the latest firmware?
Panasonic Lumix DMC-G7
