Which camera gets the best out of the Lumix G 30mm f2.8 Macro?
Started Sep 1, 2018 | Questions
HenrilensUK Junior Member • Posts: 43
Which m43 camera gets the best out of the Lumix G 30mm f2.8 Macro? Personally, I have 2 choices, the GX7 or Olympus OMD EM 10 Mk ii but please feel free to suggest others. I just love this lens and the camera body isn’t so important. It is capable of some stunning images. Thanks, in advance, to anybody who contributes.
 HenrilensUK's gear list:HenrilensUK's gear list
Canon EOS-1Ds Nikon D300 Nikon D700 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-G2 +4 more
Panasonic Lumix DMC-GX7
Mark9473 Veteran Member • Posts: 6,428
Re: Which camera gets the best out of the Lumix G 30mm f2.8 Macro?
I'd pick one of the Dual IS2 capable cameras from Panasonic.
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
I suspect the sensor would be the primary indicator of image goodness. Both cameras use the 16 megapixel sensor, so they are problably similar at the RAW level. At the JPEG level, it depends on whether you like Olympus or Panasonic JPEGs (I'm in the Olympus camp).
The 20 megapixel cameras (Pen-F, G9, E-m1 mark II) are said to offer somewhat better images, particularly in high ISO situations.
The E-m10 mark II does have focus bracketing where you can get the camera to automatically take a lot of pictures, moving the focus point slowly. You can then use software in post processing to stack the images together to give you more depth of field. It does not offer an automatic stack option where the camera does the stacking in the body if you shoot with certain Olympus pro/macro lenses (the E-m1 mark I/II, E-m5 mark II, and Pen-F offer focus stacking). I doubt the E-m10 mark III has focus bracketing.
But since your 30mm is Panasonic branded, you would not be able to use focus stacking on the cameras that support it.  I believe focus bracketing works on any micro 4/3rds lens with auto-focusing.
The GX7 has a similar mode to Olympus stacking where it shoots a special 4K video with all of the different focus points as separate frames, and you can later pick with focus points to combine together. Note a 4K image is only 2.1 megabytes, while the Olympus focus bracketing mode would record each frame at 16 megapixels.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
nevada5
nevada5 Forum Pro • Posts: 15,569
If your routine includes using a tripod, then stabilization won't be a concern. Most of my macro happens on the fly - walking around. I'll take Dual IBIS Super Turbo any time I can get it.
Stay thirsty, my friends.
If I'm ever on life support, unplug me - then plug me back in....See if that works.
Walt Palmer
Walt Palmer Senior Member • Posts: 2,001
If you want to use the Dual-IS feature, the GX7 will not, go up to the GX85 or later for that feature. I think which IS is better is a very personal choice - your shakiness is just different than mine; so your IS system might not work as well for me.
Either camera should produce good images with good glass. The GX85 might have a very slight resolution advantage without the AA filter; but nothing worth breathing heavy about.
Both are great cameras, get the one that feels best in YOUR hands. Good glass will always beat a good body. Get the good glass.
