Can I do this with a mirrorless, I tried polariser... no joy Canon 700d or G7 Pan
Started Aug 31, 2018 | Discussions
HRPOWER Regular Member • Posts: 159
Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i) Panasonic Lumix DMC-G7
Shadowfixer Senior Member • Posts: 1,769
Re: Can I do this with a mirrorless, I tried polariser... no joy Canon 700d or G7 Pan
5
Not sure what you're asking. Any camera and any type of camera can make the image above. A polarizer has an effective angle it can work at. It's most effective at 90 degrees to the light source. If it didn't work for you, learn how a polarizer works and apply that knowledge to make the image.
 Shadowfixer's gear list:Shadowfixer's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro Olympus 9mm F8 Fish-Eye Body Cap Lens +1 more
OP HRPOWER Regular Member • Posts: 159
All I got from my polariser was windscreen nothing behind. Hence It must either be a really expensive polariser and mine is rubbish, or its not quite the polariser. If you look the talent seems to be cut out in the screen, this would have been set and forget before he drives off, and thus taking into consideration the light changes at all times,
Skeeterbytes Forum Pro • Posts: 23,186
6
As noted above it's situational and pola effectiveness varies depending on the angle of the light source, light quality, etc.
Worth noting mirrorless cameras do not require a circular polarizer; a simple linear pola works on them and those can be more effective than CPs. They also have a lower filter factor than all but a few CPs.
Having shot cars with polas I find they're typically effective but not always. Windshields especially are tricky because they're a glass and plastic sandwich that itself is a polarizing element, frequently creating goofy patterns.
Keep experimenting!
Rick
Tom Axford Forum Pro • Posts: 10,100
If that was the case, you had the polariser set at the wrong angle of rotation or the camera was at the wrong angle to the screen.
As a previous reply said, you need to experiment a bit to find what works best.
Walt Palmer
Walt Palmer Senior Member • Posts: 2,001
Yes, you certainly can. Practice and experiment until you find the right angle and polarization combination. Mirrorless is not keeping you from getting this effect. Hang in there.
uRebel Rob Senior Member • Posts: 1,537
Rotate the polariser, watch in the EVF/monitor, and stop when the reflection goes away.
As already said (in slightly different words), the polariser angle needs to be rotated 90 degrees to the reflecting surface, in the above case, the windshield.
If your polariser can't be rotated, then yes it sucks. But I think you just need to practice and learn how they work.
 uRebel Rob's gear list:uRebel Rob's gear list
Pentax K-1 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Pentax FA 28-105mm F3.5-5.6 Nikon D5100 +21 more
Danielvr Veteran Member • Posts: 6,863
Chances are it WAS done with mirrorless
The Top Gear crew uses Panasonic GH4's a lot. Note also that this looks to have been filmed in Winter, with the Sun hanging low in the sky, so the presenter's face caught a lot more light than it would in Summer (unless you'd shoot very early or late in the day).
btw, Top Gear has some of the best camera and editing people in television today -- it won't be easy to match their skills (or resources).
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
Re: Chances are it WAS done with mirrorless
True enough. Their road crew is enormous and they attract top-notch directors for various episodes. Some of their unusual POV shots have had me scratching my head in wonder.
Rick
Fair enough... yes - not worth stressing over - I think if it was as easy as turning a polariser than everyone on youtube would be doing it, and top end film crews would all be out of work.
Dan Burkholder Regular Member • Posts: 240
This might come across as a bit wonky (harkening back to my photographic undergraduate days) but when dealing with polarizers and reflective surfaces, the angle at which light is most attenuated will vary according to the surface material. Glass and water, for instance, have different angles for maximum reflection reduction. For glass, it's about 57°. Also, because different colors of light will have slightly different angles, you cannot eliminate all reflections from white light. Hope this helps.
Dan
www.danburkholder.com
 Dan Burkholder's gear list:Dan Burkholder's gear list
Olympus E-M1 Olympus E-M5 II Olympus E-M1 II Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro +1 more
Notice the car scene toward the end.
https://www.youtube.com/watch?v=ktHEeR4OyPc
Interesting... ... Maybe I bought a sh&* one...
They go from around £20 - My one to around £100 ... I think we might have a point here!
Photo Pete Veteran Member • Posts: 5,430
Is it possible that you have inadvertantly fixed the polariser on the lens the wrong way round. They are directional.
Have Fun
Photo Pete
hahah that is highly entirely possible
If you look at this film I twist it at the beginning to show an effect....:) best I could do
https://www.youtube.com/watch?v=T0ToUMzyiko&t=399s
Seriously. I’ve known people try to use filter systems with their polariser mounted back to front and think it wasn’t working properly.
Have Fun
Photo Pete
