Add aperture blades to old manual lenses
Started Aug 31, 2018 | Discussions
neil bayin Regular Member • Posts: 120
I wonder if anyone has tried this before, some old Minolta prime lenses are really sharp and nice, for example 50/1.4, problem is bokeh is kind of bad. But if we are more blades to it, would that improve the bokeh?
This is very hard in the old slr world because it will add weight and slow down the shutter speed, but for most of the ppl nowadays using as adapted lens, I don't think it's a problem anymore, just wonder if anyone has tried before and how hard it is.
I have cleaned several lens' aperture, take off all the blades and wipe off the oil stains and put them back, from what i imaging, all you need is buy two of the same lenses, drill holes on one of the plates, put the diaphragms in the new holes, that is it. One think I think will cause problem is it will increase the thickness and may cause diaphragm stuck,
 neil bayin's gear list:neil bayin's gear list
Sony a7R II +8 more
petrochemist Veteran Member • Posts: 3,619
Re: Add aperture blades to old manual lenses
Quite a few of my adapted lenses don't have an aperture control.
I've used paper discs up against the front element (with both circular & shaped apertures) and have tried an iris in front of the lens. In a few cases I've ended up with noticeable vignetting (usually when the lens has a long built in hood) but many have been OK.
Here's a quick example of shaped bokeh via a paper disc https://flic.kr/p/27KRhGp
For lenses with more space between the rear element & the camera I'm planning on experiments with my iris there, and then might end up buying some of the adapters that have an iris built in.
I personally wouldn't attempt to modify the aperture mechanism in a lens my DIY skills are definitely not up to it. Cutting a slot to allow a waterhouse style aperture to be inserted is a possibility, but I'd only consider that if I cant arrange something outside the lens.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Waterhouse stops and Apodizers
petrochemist wrote:
Most fast 50s are Double Gaussian formulas for which you can place a new aperture in front of the lens -- a Waterhouse stop. To work as a stop, the opening must be smaller than the focal_length/f_number for the f_number the lens is set at -- so less than 35mm for your 50mm f/1.4 wide open. Depending on details of your lens design, it might need to be even a bit smaller than that.
Vignetting happens if your opening is too large. I know that's counter-intuitive, but it's how optics work. You're then vignetting rays from the lens aperture, which is placed differently, and that explains why the front element is bigger than focal_length/f_number.
Yup; that works. Shape of the bokeh will mirror the shape of the aperture. BTW, you can even use that to shoot stereo anaglyphs with a single shot and single lens. My Instructable explains the anaglyph trick and shows how to make 'em from paper, but I also have a Thingiverse Customizer program that designs ones to 3D-print ... all free.
The cooler thing is to make an apodizing filter, but it's really difficult to make one that is of very high quality. Here's one made using film , which produces really good quality, but for front mounting, you'd want one bigger than 135 film. I've played with 6x6 film, laser-printing on overhead transparency material, and even home-made sputtering... they all sort of work for giving really smooth bokeh, but I have a Sony 100mm STF with is perfectly apodized -- all my attempts fall a bit short of that standard. The Sony is also a nearly perfect optic to begin with -- no vignetting at all, which is needed to keep the bokeh smooth near the corners of the frame; most fast 50s, including yours, will need to be stopped down a couple of stops to remove all vignetting, and that means a slower aperture and smaller opening in the apodizing filter.  BTW, you can also do apodization in the time domain using multiple exposures.
I don't recommend this. Stay up front if you can -- it's a lot less touchy. That said, behind the lens can sometimes work with a smaller filter.
Agreed. Keep in mind, it's hard to know where to cut a slot, and there can be lots of stuff in the way. I've never been desperate enough to cut a slot -- it's so much easier to just find a different lens with similar rendering.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Re: Waterhouse stops and Apodizers
I know that's one of the causes but wasn't the case here. The lens I was using for my last experiments was a 50mm/1.2
None of the apertures I used were even remotely close to the limiting size for this lens, typically being around 1/2" in their biggest dimension. For ease of use I was just applying the masks at the end of it's hood about 1.5" from the front element.
A slot in the hood to allow easy inserting of masks & waterhouse stops is something I'm considering...
ProfHankD
Ah, wrong place. That can cause vignetting too.  Most lenses have at least three valid places for a stop -- near the middle, in front, and behind -- but positioning matters a lot and it's not uncommon that any of those spots is mechanically awkward/impossible (e.g., intersecting an element).
However, be warned that most f/1.2 lenses actually vignette a lot. It usually takes more elements to make such a fast lens, and that tends toward a thicker (longer) optic, which tends to increase vignetting. Even some of my f/1.8 lenses vignette less wide open than some f/1.2 lenses stopped down to f/1.8. Try measuring the OOF PSF to see how bad the vignetting is: photograph a point light source (e.g., white LED) placed far away in a dark room with focus set close. When the spot is centered, it should be a bright disc (outside shape matching the aperture); when the spot is near a corner, you'll see vignetting as re-shaping the disc. For example, here's a composite of 5 OOF PSF varying only placement of the OOF PSF within the frame:
You want an aperture that is small enough to not be clipped in the corners -- still have the same shape. For an f/1.2 lens, that could be anywhere from f/1.2-f/8.
Again, I'd vote against cutting anything. Better to make your own hood with a filter slot or even with an iris (hard to 3D print an iris, but you can buy them).
Useful tips I'll give it a go when I get the chance
The hood is permantly fixed (& there's no filter threads) so using anything else would need cutting...
The lens was only £16 and needed excess cutting off the back to prevent it fouling on a c mount. Even so I might be tempted to source a second copy first
