Looking for zoom lens with more "reach"
Started Aug 31, 2018 | Questions
sunlove New Member • Posts: 21
I'm an amateur-hobbyist with a Panasonic Lumix DMC GX7 and Lumix 14-45 lens. I'd like a lens with a bit more "reach", maybe "12-60" or "14-140" or "14-150".
In the old days I loved the range my Canon 28-135 gave me, so the 12-60 would get me close to that, but still short. The 14-140/150 may be more than I need.
What to do?
The contenders:
Panasonic Lumix G Vario 12-60mm f/3.5-5.6
Panasonic Leica DG Vario-Elmarit 12-60mm f2.8-4
Panasonic Lumix G Vario 14-140mm f/3.5-5.6
Olympus M. Zuiko Digital ED 14-150mm f/4-5.6 II
The price on the contenders are in the same ball park, except for the more expensive Leica Elmarit.
Your ideas.......? Something else out there I should look at?
Appreciate your thoughts and suggestions!
Panasonic Lumix DMC-GX7
Badwater Senior Member • Posts: 2,095
Re: Looking for zoom lens with more "reach"
If you can manage it, the Olympus 12-100 f/4 would be the ideal everything in one lens.  But, the Panasonic Leica 12-60 is also a good choice.
G Rash Senior Member • Posts: 2,890
Depends on what camera you used with your 28-135.  If it was a film body, the the 12-60 gets you pretty close.  If you used it on an APS-C DSLR, then it would fall well short.
I really like the 14-140ii for an all purpose lens with good range.  For longer stuff, I like the Pany 100-300ii.
Gary
 G Rash's gear list:G Rash's gear list
Olympus PEN-F Sony a7R III Canon EOS R5 Nikon D610 Panasonic Lumix DMC-GX8 +3 more
JakeJY Veteran Member • Posts: 5,442
Note you can get the 12-60mm f/3.5-5.6 for drastically less than the others if you buy a de-kitted one (~$250). What this lens would give you is a little bit wider view and a bit more reach.
Given I already had the 12-32mm, that lens would have been a bit redundant. I got the 14-140mm II for my GX85 and it's a perfect match. Hardly bigger or heavier than the 45-150mm (which I might have got instead) and very convenient for travel. The IQ is excellent for a superzoom.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
alcelc
alcelc Forum Pro • Posts: 19,003
What to do?
The contenders:
Not owned both versions of 12-60. The PL f/2.8-4 version is a premium class lens without doubt on its IQ, at a cost and larger/heavier. Can't get comparable test result to compare but AFAIK, the non PL version could be similar to the recent kit class of lens of 12-32. So supposingly not bad at all. 12-60 is a very desirable zoom range to me.
According to DXO, 14-140 is better than 14-150, which is already quite a good superzoom lens. On GX7, due to the primitive IBIS, when going to the longer focal length zone, I'll prefer the Lens OIS of 14-140 for the 3 stops of stabilization.
If you need 12 AoV as me, 12-60, might add a cheapy/small 45-150 will do. I use a 12-35 f/2.8 & 45-150 (also 7-14 f/4) set up on GX7 for my traveling.
If you don't need the 12, 14-140 would be a perfect one lens solution on Pany body. Stop it down to f/4, basically it has similar IQ to 12-35 f/2.8 at the same aperture. Comparing to 45-150, 14-140 has better IQ (marginally). It is my wife's only lens on GX85.
Albert
OP sunlove New Member • Posts: 21
Thanks Badwater.  Re: Olympus: I can dream.  Re: Leica: looks good.
Thanks Gary.  Seriously considering the 14-140.
Hi Jake.  Glad to hear the 14-140 II is your perfect match.  I'm going to give it a good look!
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
I think the lumix 14-140 is one of the best zoom all around lenses. Personally I have taken some of my best photos with it. The Leica 12-60 would also be a great but expensive choice, starting from 12mm. I have the cheaper lumix 12-60 which is also fantastic.
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
What to do?
The contenders:
Hi alcelc.
Great suggestion about using lens OIS for 14-140
Sorry I don't know what AoV is. Please explain.
Seriously looking at the 14-140.
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
AoV= Angle of View
Cheers
Eric
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
Hi Yannis.
Thanks for your feedback.  I'll be in Greece this fall and will be using the new lens, which one I'll decide on soon!
Duh... of course!  Thanks Eric.
alcelc
sunlove wrote:
What to do?
The contenders:
Hi alcelc.
My bad, angle of view.
Albert
Yannis1976
sunlove wrote:
Hi Yannis.
I find the 12mm more useful for landscapes or city...
TheDream168
TheDream168 Regular Member • Posts: 155
sunlove wrote:
Hi Yannis.
I was in Greece this past Summer and used the PL 12-60mm as my main lens:
https://microfourthirdssite.wordpress.com/2018/06/29/whats-in-my-camera-bag-micro-four-thirds-travel-lite-greece-edition/
But you'll see from my writeup that I missed the reach of the 14-140mm over the better IQ of the PL12-60mm.
The 14-140mm used to be my main travel lens and I think I'll be reverting to it for my next trip. Here's me using it for my trip to Vietnam last December:
https://microfourthirdssite.wordpress.com/2017/12/26/whats-in-my-camera-bag-micro-four-thirds-travel-lite-vietnam-edition/
Got it!
