Olympus TG5... Pleasantly surprised!
Started Aug 28, 2018 | User reviews
Yannis1976
Yannis1976 Veteran Member • Posts: 6,307
13
Hi,
This is my full review after using the camera for 10 days in the Greek islands. Initially I wasn't expecting much after having tried and returned the TG4 a year ago. This summer, I decided to give the TG series another try combining it also with the fish-eye lens.
Pros:
1) UW AW balance and colors are most of the times very good, better than myself editing the RAW!!
2) The fish-eye lens is a must for UW photography compromising the small sensor low resolution vs a larger sensor camera (e.g. the RX100/3 I also had with me).
3) Ergonomics are great and definitely better than any larger sensor camera due to the smaller size (again mainly vs my RX100/3)
4) When in UW wide mode, you seldom miss a higher shutter speed, despite not having an S mode.
5) RAW files do give you some space to play despite the small sensor (look samples later)
6) Macro modes are great. Focus in camera stacking works great!
7) Light painting is SUPER easy with this one!
8) Well built
Cons:
1) IQ and especially details are not that good while pixel peeping.
2) there are times that you will miss the S mode
3) Lens, especially with the fish-eye, is extremely prone to sun flares
Some samples:
Edited in LR
Edited in LR
UW macro mode and edited in LR
Edited in LR
Overall, I would give a 4 stars to the TG5 mainly for what is allows you to shoot (UW, sports etc) with acceptable IQ and great ergonomics vs other solutions.
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Olympus Tough TG-5
12 megapixels • 3 screen • 25 – 100 mm (4×)
Announced: May 17, 2017
Yannis1976's score
4.0
Average community score
3.4
bad for good for
Kids / pets
good
Action / sports
good
Landscapes / scenery
good
Portraits
mediocre
Low light (without flash)
mediocre
Flash photography (social)
acceptable
Studio / still life
acceptable
= community average
Olympus TG-5 Olympus Tough TG-4
J_dpr Contributing Member • Posts: 990
Re: Olympus TG5... Pleasantly surprised!
Thanks for the review!
I'm not sure what you mean by
"2) The fish-eye lens is a must for UW photography compromising the small sensor low resolution vs a larger sensor camera"
Why is it compromising the sensor?
Which of your photos are shot with the fisheye lens? Have you noticed a lot of purple fringing or chromatic aberration towards the corners of the frame with the fisheye attached?
Thanks.
Yannis1976
OP Yannis1976 Veteran Member • Posts: 6,307
Thanks.
Apologies for not being clear
During my holidays, I also had the RX100/3 with the Ikelite action housing. IQ from 1" was indeed better when cropping or even at base ISO, but in my opinion the wide field of view of the TG5 and the smaller size proved to be much more important to achieve a nice UW photo.
The fish-eye lens was constantly attached to the TG5, all shots were taken with it. Yes there is some purple fringing, but its been corrected by the Olympus JPEG engine and you can also correct it with LR.
Thanks.
Excellent - thanks.
Linnin
Linnin Regular Member • Posts: 206
Thanks for the review. First shot is killer with such good vibrant color.
My Best Days Are Still In Front Of Me
 Linnin's gear list:Linnin's gear list
Olympus TG-5
Yannis, did you experience any fogging up on the screen like discussed in the long thread here on this forum?
Yannis1976
No, nothing like fog on the screen. Sometimes only  the wide lens would collect some air or was not filled fully with water creating some artifacts.
stefpix Regular Member • Posts: 220
Yannis, did you use the Olympus wide angle adapter or a third party?
Did the attachment come with a pouch / case?
Does it work with the housing as well?
I have been playing with the TG-5, that I bought refurb and looks new. I had returned the TG-4 or TG-3 a couple of years ago. Anyway I find the sharpening and contrast a bit too high by default, I have seen that they can be dialed down.
I wish it had S rather than A mode, since it only has 3 apertures. I'd dream of a firmware update that would replace A with S.
 stefpix's gear list:stefpix's gear list
Sony FE 55mm F1.8
Yannis1976
Hi again,
The adapter is from Olympus and is this one:
https://www.amazon.com/Olympus-Fisheye-adapter-Cameras-Adapter/dp/B00CMKONQ8
https://www.getolympus.com/us/en/fcon-t01-fisheye-converter-lens-cla-t01-adapter.html
IMHO it is essential for underwater shots and I don't think it fits the UW housing, just the TG-5 camera.
Thx
Enders Shadow
Enders Shadow Veteran Member • Posts: 3,604
The fisheye adapter is a good option to have available, but I don't always use it. On shallow reef dives I'm usually more interested in photographing fish. I avoid using the zoom in order to take advantage of the relatively fast lens. In more open water, the adapter can be helpful.
You're correct, the fisheye adapter is only useable when mounted directly on TG cameras, It has 40.5mm threads and is only rated to 20m. The Olympus housings have 52mm threads. Olympus has a wide angle adapter, the PTWC-01, that was designed for use with their housings. For some reason they no longer list it as a accessory for the PT-058. It's a expensive piece of glass, about $500. I borrowed a friend's for a deeper wreck dive. I was surprised it is a rectilinear design and doesn't offer as wide of coverage as their fisheye adapter. Its optical quality was excellent.
Update:
I talked to my friend who owns the PTWC-01 and asked why it's not listed as a accessory for the PT-058. He pointed out that Olympus shows it on their case system chart for that housing. So, it remains compatible with the all their housings for the TG series. He reminded me that the adapter lens actually has 67mm threads and requires using a step-up ring.  I also forgot it will slightly vignette with the lens at full wide. If you select the adapter in the accessory menu, the camera will automatically zoom to the widest useable zoom without vignetting when powered on. But, you can still manually zoom. The PTWC-01 doesn't seem all that competitive compared to aftermarket wide angle lenses.
Phil
 Enders Shadow's gear list:Enders Shadow's gear list
Canon PowerShot G12 Olympus Tough TG-3 Fujifilm X30 Canon EOS 7D Mark II Nikon D500 +19 more
