new EF-M 32mm f/1.4 coming! Price???
Started Aug 28, 2018 | Discussions
StevenSHH
StevenSHH Contributing Member • Posts: 609
It’s good news unless it won’t fit APS-C models and only FF MIRRORLESS. - which is less likely.
https://www.canonrumors.com/the-canon-ef-m-32mm-f-1-4-stm-confirmed-again/
EF 50mm f/1.4 release in 2008 at USD$325.
My guess it’s probably around $399 if without IS.
Add $100 with IS. What do you all think the price would be?
Have fun with photography! Start taking photos!!
 StevenSHH's gear list:StevenSHH's gear list
Canon EOS M6 II Canon EF 24-70mm F4L IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 32mm F1.4
KrisAK Contributing Member • Posts: 845
Re: new EF-M 32mm f/1.4 coming! Price???
I'd think the price might be SOMEWHAT determined by how the crop M-series fits in (or doesn't fit) with the upcoming FF ML.
Is it part of a more robust system? Or is the M forever destined to be an outlier?
tomwilde Forum Member • Posts: 91
I'm hoping for something cheap, inspired by the $125 Canon EF 50mm f/1.8 STM Lens.
StevenSHH
OP StevenSHH Contributing Member • Posts: 609
EF-M 50mm f/1.8 would be around that price if they ever design one.
dave_bass5
dave_bass5 Veteran Member • Posts: 7,342
The one thing im really hoping for, but dont expect, is that the lens isnt STM, but Nano USM. That is just so much faster than STM. Even in the small EF-S/M primes you can feel a lag compared to USM and Nano USM.
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
$400 seems about right...
5
This is an important lens for the M-series. It's overdue but it's essential. This is said to be an EF-M lens so it's clearly designed to fit the existing M-series range of APS-C cameras and I going to be a 50mm equivalent lens suitable for portraits and low light. The bokeh should be more than most can ask for if it's f/1.4 with a focal length of this figure.
I'd expect something akin to around $400. Canon want to establish their EF-M lenses and they want to do so at an attractive price. I'd be very surprised if this lens is more than $500... and if it is, it will need to possess IS for that price.
With Canon expected to announce their FF mirrorless camera in about a month, and with strong indications they'll announce it with TWO 'EF' series 50mm lenses (f/1.4 and f/1.2 Mk II), I think that this 32mm lens will be just for the EF-M series. And that's a good thing. More EF-M lenses means more leverage on the mirrrorless market. There's something magical about lenses with fast, wide apertures but they don't need to be obscenely expensive. They certainly aren't too difficult for Canon to mass-produce these days. With the speed of recent releases from Canon lately, it's wouldn't surprise me if they announce a new EF-M body at the same time they announce the mirrorless FF.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
LKFX_House
LKFX_House Regular Member • Posts: 334
Knowing canon and past ef-m lenses and for reference 35mm 1.8 lenses are not usually cheap this one is around that at 32mm 1.4, i'm almost sure won't have IS, and should be around the $400-550 price, again just for reference Sony's 35mm 1.8 with IS, is $400-450, sigma lens for sony aps c mirrorless 30mm 1.4 is $330
LOW LIGHT DOESN'T MEAN NO LIGHT, Get you gear out! PRACTICE WILL make you better, debates on forums will not
 LKFX_House's gear list:LKFX_House's gear list
Canon EOS M Sony a6000 Sony a6300 Sony a6400 Sony E 18-55mm F3.5-5.6 OSS +10 more
nnowak Veteran Member • Posts: 9,073
USM vs STM vs Nano USM
5
There seems to be a lot of confusion in this thread about the different focus motor varieties.
USM - This is a ring type motor roughly 5mm in cross section and with a diameter almost as big as the lens using it.  Think of it as an electronic hand that spins the mechanical focus ring.  One rotation of this motor = one rotation of the focus ring.
STM - This is a very small can motor to one side of the optical path.  Instead of a shaft like a typical motor these are designed with a hollow, threaded core.  When the motor spins, it drives a treaded screw in and out.  The threaded screw is directly connected to the focus group.  This motor needs to rotate numerous times to cover the entire focus throw.
Nano USM -  Electrically, they are a USM moter, but instead of a ring, the motor is a flat line.  Like STM, the motor is directly connected to the focus group.  These are also called "linear" motors and they are often used in mirrorless lenses from other manufacturers and are often used in multiples.
Tom Kelley Forum Member • Posts: 89
Re: USM vs STM vs Nano USM
So, is there a standard USM and a NANO USM and if so, which is best?
Tom Kelley
 Tom Kelley's gear list:Tom Kelley's gear list
Canon EOS 6D Canon EF 50mm F1.8 II Tokina AT-X 16-28mm f/2.8 Pro FX Canon EF 24-105mm F3.5-5.6 IS STM
AbuMahendra Regular Member • Posts: 106
The latter.
