lug rings for M5?
Started Aug 27, 2018 | Questions
lumenite Senior Member • Posts: 1,208
lug rings for M5?
So far I have not used any strap for M5 usually, while I have used JOBY wrist strap for M.
Now I want to add another JOBY strap for my M5. The problem is the connection between the strap and the camera.
How about something like this?
https://www.ebay.com/itm/1-Pair-Camera-Shoulder-Strap-Quick-Release-Adapter-Connecting-Buckle-Strap-Grips/253759611602
Do you think that it fits M5? Are M5's lugs common or dedicated?
I want to keep the original lug rings for the original Canon neck strap.
P.S. I do not know why Canon has been changing the styles of lugs at every iteration of EOS Ms.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
OP lumenite Senior Member • Posts: 1,208
Re: lug rings for M5?
I just found the following thread:
https://www.dpreview.com/forums/thread/3154086
I am giving up to use triangle rings.
KEG
KEG Veteran Member • Posts: 4,909
I have OEM Fujifilm triangles on my M6, looks great.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
kbdkbd Regular Member • Posts: 287
Single wire will fit, double loop rings don't always fit through the holes. I have these ones and they do fit
https://www.ebay.com.au/itm/Hama-Split-Rings-/172786780914
 kbdkbd's gear list:kbdkbd's gear list
Canon PowerShot G12 Canon EOS M100 Canon EOS M6 II Canon EF 50mm F1.8 II Canon EF 100mm f/2.8 Macro USM +11 more
Yes, single wire in my mind.
Your link shows double wires, doesn't it? Moreover, too expensive. Thank you.
Thank you. difficulty locating FUji rings....
KEG
I went to the local Fuji-store, paid somewhere around $5 for them, you could also just order X-A5 and sell the camera afterwards...
I am always interested in Fuji system. Maybe it is time to check it.
Re: JOBY + Canon
I have ended up using the Canon original ring for JOBY wrist strap. Thank you for your concern. It is very tight because the JOBY strap is wider and thicker than Canon's strap, but it works wonderfully.
