Low Light Environment Tips
Started Aug 26, 2018 | Discussions
Mike32837 New Member • Posts: 3
Hey everybody, fairly new to AV. Just bought myself a Lumix G7 for 1080p-4K vlogging. I'm loving it good light scenarios. It seems like various test videos show it can do decently in low level light environments but despite the tips I've picked up, my footage still looks super dark.
I would normally use my own lighting but outdoor events during the evening I wanted to record I can't really control the lighting so much.
I am just using the stock lens. I put the camera mode in iAS so it'll adjust my aperture and shutter based on exposure. I cranked up the ISO to 25k.
And interestingly the OLED LCD monitor shows a passable, colorful image. The second I hit the record button that image shows the true footage of mostly blackness. I did turn on that constant feature for the monitor to show the live footage. Is the colorful LCD  prerecord image a pipedream? If so, how can the simple monitor do the processing to make it look good?
Panasonic Lumix DMC-G7
Martin Ocando
MOD Martin Ocando Veteran Member • Posts: 6,722
Re: Low Light Environment Tips
Hi, and welcome to the forum. This thread belongs to the micro four thirds talk, and not the Panasonic Compact talk. Let me move it for you.
Martin
"One of the biggest mistakes a photographer can make is to look at the real world and cling to the vain hope that next time his film will somehow bear a closer resemblance to it" - Galen Rowell
 Martin Ocando's gear list:Martin Ocando's gear list
Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH +13 more
Mark Kaprielian
Mark Kaprielian Regular Member • Posts: 400
Hi
The camera is using settings that it knows to display the scene as best it can. When you start recording, it is using the settings you've selected !
I would recommend you read through this recent thread which was also asked by someone new to video. I think the thread and my couple of posts in there will help jump start your questions.
https://www.dpreview.com/forums/thread/4310703
Mark
 Mark Kaprielian's gear list:Mark Kaprielian's gear list
Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-GH6 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +9 more
alcelc
alcelc Forum Pro • Posts: 19,006
Martin, it is a Pany G7... (nt)
Albert
alcelc
What is the iAs mode?
Do you mean hitting the Red REC button to start recoding?
Going to ISO 25,600 will guarantee a serious noisy footage having most detail be erased by noise reduction (NR).
To start and stop a video by the red REC button, will indeed start your shooting in full automatic mode. It is quite basic for Panasonic, and I found it does not response quick enough on various ambient lighting condition. So, might use iA+ (hit the iA button, and select iA+), which will response much better and will use various pre set scenery mode whenever G7 thinks fit. It can guarantee you a nice footage.
When you feel comfortable with G7, can move on to use manual video for more control (select the Creative Video Mode on the dial).
Albert
larsbc Forum Pro • Posts: 18,282
Record in 24 or 30 fps, not 50 or 60, for low light.  It'll let your camera choose longer exposure times.
