One of the best lenses on the system. Period.
Started Aug 25, 2018 | User reviews
bluevellet Veteran Member • Posts: 4,172
18
Olympus M Zuiko 12-40mm f2.8 Pro came out in 2013 alongside the E-M1 mark 1. The lens has received many rave reviews and after 5 years of resisting its allure, I've finally given in. It's not without good reason. I've owned the already excellent, but older Zuiko 12-60mm f2.8-4 from the defunct 43 DSLR system and the lens still delivers good results via an adapter on m43 cameras. But the lens AF with contrast detect of modern cameras is a slow combination and the 12-60 is front heavy on your typical, more nibble m43 cameras.
The old and the new.
But before we get ahead of ourselves, what is this hyped 12-40 (or the old 12-60 for that matter) supposed to be about? It's a general purpose zoom lens, wide enough to shoot landscapes and architecture and can zoom enough to create some pleasing portrait shots. It's the kind of lens that is most likely to be constantly attached to your camera. These zooms have a similar range as the usual kit zooms often sold with interchangeable cameras, but the image quality is noticeably better, they also suck in more light for more low light situations so they cost and weigh more as a result.
The 12-40 comes in an all-black box and packaging and it is first rate like many Olympus products in recent years. It makes you look forward to whatever is inside.
Nothing wrong with casual shooting.
The lens itself gives a similar first impression as I had with the 12-60 a decade ago: smooth, solid and reassuring. It feels like a younger sibling of the older lens. It is by no means a small lens though, even by m43 standards, but I find it's about as long as the M. Zuiko 14-150 II zoom lens, only thicker and slightly heavier. In practice, on my main EM5 markII camera, it is still a bit front heavy, but it's lighter and smaller than my old 12-60. Having no extra lens adapter helps too. Good.
Like the classic 12-60, the 12-40 offers weather-sealing (granted your lens is attached to a weather-sealed body too). I think most photographers have shot with non-weather-sealed camera/lens in rain and/or snow and got away with it just fine. I think here the difference is that it offers peace of mind. Rather than hiding the camera in rain and only taking it out quickly for a few shots and then hide it again. This one you can just let it dangle around your neck, no matter the weather and shoot when needed. I think it reinforces its "all purpose" quality. For me at least, that type of convenience is great. Furthermore, if you don't fear your camera/lens is going to break after a few splashes, you will be tempted to shoot in challenging environments, increasing the odds of you getting that special shot.
Get wet. And get the shot.
Another big selling point of the 12-40 lens is the constant aperture, in stark contrast to your typical kit zoom. So, whether if it's 12mm or all the way to 40mm, your max aperture will remain f/2.8 (or whatever other aperture you choose). This has many advantages. It means your exposure settings can remain the same no matter the focal lenght. This becomes particularly evident when shooting video where zooming doesn't create a dimming effect. Furthermore, with kit zooms, you instinctively stick to the wider focal lenghts to keep as much light as possible when shooting stills. With the 12-40, this is a non-issue. And of course, if your constant aperture zoom lens sucks in more light, you have more artistic possibilities to isolate (or not) your subjects, at any focal lenght.
My old 12-60 lens has a classic manual focus override like many DSLR lenses which I've always liked. The newer 12-40 has that infinite, imprecise, focus-by-wire of many m43 and other mirrorless system lenses. Meh... Until you pull the focus ring down and the lens magically has a real manual override. I can't be absolutely sure if it is truly mechanical or just cleverly imitated (probably the latter), but it acts and is responsive like the real thing. Even better, you can use AF any way you like and when the right moment comes, pull the focus ring down to a preset position you decided on beforehand and it will focus back right where you want to be. Now that is an improvement over my 12-60. I love this. The only possible downside is the focus ring can be easy to activate by accident.
No 12-40 for you.
On the field, the 12-40 behaves like many recent m43 lens be it prime or zoom: fast, confident and silent. Limited only by whichever type of AF system your camera has and which generation your camera belongs to. It is a bit slower on a body like the classic E-PL1, but my GM1 and my trusty EM5 are on fire with the PRO lens attached. So already here, purchasing this lens is halfway justified by this point: It has fixed my AF problem.
One important detail is the old 12-60 was optically corrected; the 12-40 is software-corrected. For most people I guess the results matter more than how you get there. But I do use a RAW editor where I have to manually input the lens profile for every photo taken with the 12-40 otherwise the photos come out uncorrected. If you are shooting subjects with clear, straight lines then these distortions, uncorrected, can spoil your photos. But I find in non-critical work, uncorrected distortions are a non-issue and can even be a bit of cheat sometimes as they allow you to cram more in the shot in the wide end (it's like shooting at 10-11mm). So I often opt to leave my RAW photos as they are, choosing to correct only a handful, if any.
Well suited for pseudo macro and image stacking
On paper and with various technical reviews out there, the 12-40 beats the 12-60 with IQ. But in the real world, to me, the lenses are on par. This is not a bad thing. I love the IQ in the old lens: it's sharp, colorful and it has character. IMHO, either zooms match mid-level primes on m43 so I see little difference between them and, say, a Lumix 20mm f1.7 or a Zuiko 25mm f1.8 except for speed (aperture) and size. The more professional primes, like the Nocticron 42.5 f1.2 or the Zuiko 75mm f1.8, still have an edge in sharpness and "character". Ultimately, I think the 12-40 is only really limited by whatever your camera sensor is capturing and future improvements in sensor technologies will likely make 12-40 IQ even better.
Not just with the old 12-60 f2.8-4, but with the wide range of other competing zooms on m43, the usual trade-off between the different models is speed vs range. To me the 12-40 has the balance right, with enough speed and range. I take most of my photos below 40mm so that extra speed comes in handy in pure light-gathering abilities. If I need a bit more zoom, I would rather crop with the 12-40 than raise the ISO sensitivity or lower the shutter speed (which would be needed with a slower lens). This was a similar rationale for me with other highly competent zooms on m43 such as the Zuiko 12-100 F4 or the Panasonic 12-60 f2.8-4 and why I decided against them. I don't think constant f2.8 makes the 12-40 a low light lens per se, but I use it more often indoors than I ever used the old 12-60 or any of the much slower kit zooms I also own.
Yes, it can shoot landscapes too.
Speaking of which, the 14-150mm f/4-5.6 II that I own has a very practical focal range, very handy when travelling. It's also weather-sealed which is great. But it's noticeably a slower lens, which makes it more of a strictly outdoors lens (unless you use a flash). I think the IQ is ok, but noticeably below that of the 12-40. In this case, the 14-150 asks you to trade IQ and speed for focal range in comparison to the 12-40. Still a practical lens, but I never use it for anything critical. On the flipside, some kit zooms with narrower focal range like the Lumix 12-32 f/3.5-5-6, which I also own, offer some pretty sharp pictures in good light (and once you stop them down). There's no weather sealing with the 12-32, it's also slow and it doesn't have even a focus ring, but the lens is tiny, yet packs a lot of IQ at a fraction of the size and price (almost free when bought as a pack-in with a Panasonic camera body). If you anticipate shooting in broad daylight or in close proximity to subjects with a flash (like with a smartphone) then the 12-40 may seem overkill in those narrow circumstances compared to the 12-32. But of course, there are a variety of different shooting conditions so the 12-40 is much more flexible tool overall.
Though I can not speak from personal experience, the most obvious rival to the 12-40 is the Panasonic Lumix 12-35 f/2.8 (mark I and mark II). A similar, constant aperture zoom that is a bit smaller, a bit pricier, doesn't zoom as far and features the one feature missing from the 12-40: optical stabilisation. Since all Olympus m43 bodies and an increasing number of Panasonic bodies feature in-body stabilisation, I consider this 12-40 omission a non-issue. But recently, both Olympus and Panasonic have being pushing dual IS, both optical and in-body IS, for even greater stabilisation. Again, not much of an issue for me. But considering all the positive reviews the 12-35 lens has received, I'd likely be a satisfied customer if I owned it. Just be aware the Panasonic lens exist and should be considered if you are in the market for a constant aperture zoom.
Big performance usually equals bigger footprint.
And then comes the source of many arguments with m43: subject isolation. When compared to larger-sensored camera systems, m43 offers less DoF control when aperture is the same. In practice, you can get pretty good subject isolation on m43 with f2.8, but you have to work harder for it. For example, you can use the 12-40's pseudo macro abilities and get real close to your subject while keeping the background farther away. Bang! Easy bokeh. Conversely, you zoom all the way to 40mm, keep the lens at f2.8 and that gets you a decent half-body or head shot. Of course, if you use the same techniques with a f2.8 zoom on FF, your subject isolation would be more dramatic than on m43. it depends on how much is enough for you. Conversely, if you shoot more than a single subject, you'd likely have to stop down significantly on FF to get all your subjects in focus while on m43, maybe you'd stay at f2.8 or stop down significantly less which would help in a situation where light is not plentiful. In the end, only you know what you want and what you need. If subject isolation is a sticking point for you, then maybe faster primes are a better solution or just moving to a larger sensor camera system would be better for you in the end.
In conclusion, I find the 12-40 flexible enough for a whole range of shooting situations, has all-around good IQ with a good build and feel. It has replaced most of my primes in terms of general use and only my 8mm f/1.8 FE Pro competes with it for most time spent on my EM5 mark II camera. Highly recommended.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
Olympus M.Zuiko Digital ED 12-40mm F2.8 Pro
Zoom lens • Micro Four Thirds • V314060BU000
Announced: Sep 10, 2013
bluevellet's score
4.5
Average community score
4.7
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Yes.
Agree.
Best lens that I have ever bought in getting close to 60 years of my photography hobby. Hesitant at first because of the price here in Oz but from day one enjoyed the lens, first on E-PL5 and now on E-P5.
The lens improves if you use DxO Photolab+Prime noise reduction and use their auto downloaded body+lens profile.
Just looked up my list, owned it now for 4.5 years and never a problem with it.
The closeup ability at 40mm (use the AF/MF switch ring) means that I never seem to carry my macro lens any more, it's good enough for those random bee-in-flower shots.
The constant f/2.8 means good AF in silly low light situations, and if prepared to handle high ISO then there's no need at all to carry any larger aperture primes in that range. It certainly removed my prime lens lust forever.
Likely problems........
Some people have problems with the lens hood popping off or failing, never happened to me, lens hood always stays on.
Also most people seem to have failures with the lens cap, it auto destructs at some point. Not for me as I put the cap aside at purchase  and I never use it any more, the hood does the protection. If you are a lens cap user then best to buy some after-market cap, I have a Kenko centre pinch cap that would work nicely if I ever needed it.
And the usual warning, at some stage everyone (and I do mean everyone) gets caught by the AF/MF switch ring. First time often results in a plea here about "my lens won't AF any more" but later on it drops back to only a second or so of confusion. Best to always check the lens ring is in the right position when removing it from the camera bag - it can get snagged and moved at times.
The lens can be prone to flare with the sun or bright light just out of the frame, in that case I extend the hood by shading with my hand to make a visible difference.
Regards.... Guy
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
Re: One of the best lenses on the system. Period.
Enjoy the new lens.  It was my first PRO lens purchase when the E-M1 came out.
I still have my 12-60 zuiko as well.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
(unknown member) Forum Pro • Posts: 19,317
glad you like it, but it didn't sing for me ,my 25 1.8 and the sigma 60 and a new sigma 19 on order have better contrast/sharpness, the 2 I tested were only slightly better than the 14 42 kit.
Don
Olympus EM5, EM5mk2 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1
MannyV
MannyV Senior Member • Posts: 1,055
Will written review. I love this lens too. The micro contrast, Sharpness, and colours rendered by this lens is what makes it my go to lens.
their isn't such a thing as micro contrast
Don
MannyV
Don
😂Ok. Contrast 🤣👌😂
Gary Martin
Gary Martin Veteran Member • Posts: 5,301
I just picked one up recently, after agonizing for quite a while on a walk-around zoom for my Pen-F. I went for the Panasonic 12-60 first because it was a light-weight option, but I was disappointed with the optical quality outside the center of the frame. I was afraid that the 12-40 would be too heavy for the Pen-F, but the handling of that combo turned out much better than expected; the leather half-case helps quite a bit. And the optics ... shockingly good. I've used a lot of zoom lenses, but this is easily the most consistently sharp one that I've ever used, crisp across the frame at all apertures out to the edges by f4. And the build quality is superb.
So I must kindly amend the OP's post title: One of the best lenses on any system. Period.
 Gary Martin's gear list:Gary Martin's gear list
Ricoh GR III Pentax K-1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R +9 more
OP bluevellet Veteran Member • Posts: 4,172
It would be difficult for me to go that far without being knee deep in all other systems.
Within m43, I either own or have tried many lenses, with a few exceptions. It's easier to call the 12-40 one of the best, within m43.
Dunsun Contributing Member • Posts: 656
Hey,
That's a really nice write up. I did own this excellent lens as well as many other Olympus PRO lenses. It's a great lens optically + it's very versatile.
But it was not for me. Way too large and heavy. Frankly If I wanted to shot that large lenses I would not shoot a m43 system, but that's just me.
One thing I would like to add (again just my subjective experience) is that 2.8 aperture is not good enough (for a m43 sized sensors). That's why I would prefer a slow small and light zooms for a daylight shooting (like plastic-fantastic Oly 40-150, Pana 12-60, Pana 12-32) and use fast prime lenses when needed (either for a thin DOF or for a fast aperture).
Cheers
Guy Parsons
Dunsun wrote:
Hey,
Cheers
Well, my oft repeated story about very low light AF disappointment with f/1.8 primes compared to the AF reliability of my f/2.8 zoom keeps me firmly in the f/2.8 zoom camp and well away from f/1.8 primes. Prime lens lust was forever eradicated.
So for me first with E-PL5 and now E-P5 the 12-40/2.8 made photography in all light conditions so much more reliable. Naturally I added the Panasonic 35-100/2.8 to complete the set for what is my most used range of focal lengths.
Regards..... Guy
Gary Martin
Well, I wouldn't exactly say that I was "knee deep" in a lot of systems, but I have tried a lot of zoom lenses over my lifetime and very few have been as consistently excellent as the 12-40; but I guess you'll just have to take my word for it
Guy Parsons wrote:
Dunsun wrote:
Hey,
Cheers
And this is an interesting part since I have experienced a bit similar behaviour. Though I guess it has nothing to do with those fast primes  but it's just another one Olympus AF system failure (since it focuses all lenses wide open it is confused by a too much blur everywhere). By the way using these primes on any Panasonic camera is a much nicer experience when shooting in the dark enviroments.
Regards..... Guy
DonParrot Veteran Member • Posts: 4,968
Well, I have to take another point of view.
For me, the 12-40 2.8 doesn't come close to my wonderful 12-60 SWD and so, I sold it after a relatively short time. I missed the range and am of the opinion, that the 12-40 is - like many µFT lenses - oversharp. As I see it, the 12-60 is far better balanced. What by the way also applies to the 50-200 SWD compared with the 40-150 2.8. Wich I kept nevertheless as the 50-200 unfortunately doesn't C-AF fast enough when it comes to really fast action such as running sighthounds. While I think the AF / C-AF of the FT lenses on the E-M1 MKII is clearly faster than on the last FT flagship, the E-5, and therefore fast enough for anything but sighthounds, RC racing boats and the likes. What I would should with the longer lenses anyway. But playing children or my own dogs running - no problem at all.
And in addition, I like the heavy-duty design of the FT lenses far more than the bling-bling µFT lenses where you would be annoyed by every scratch.
I wish I was an OLYgarch
 DonParrot's gear list:DonParrot's gear list
Panasonic FZ1000 Olympus E-30 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GH4 +13 more
Landscapephoto99 Veteran Member • Posts: 3,216
It's on of the best lenses on any system.  Period.
Albert Valentino Veteran Member • Posts: 9,770
Yes. Outstanding lens. I got mine with my EM1 two years ago and it is the best wide/normal  zoom I ever owned and I eapecially like the 1:3 close focus ability.
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
ZeBebito
ZeBebito Regular Member • Posts: 430
Love those over the top claims. Have you use or compare it with the Sony 24-70mm F2.8 GM or the Otus Zeiss primes?
Focus on what's important
 ZeBebito's gear list:ZeBebito's gear list
Canon EOS 5D Leica M8 Panasonic Lumix DMC-G1 Leica M9-P Canon EOS 6D +11 more
Gary Martin
I can! The Otus 50/1.4 is optically brilliant, but it's large and manual focus only. I tried it on a Canon 5Ds. And the Sony lens is very sharp in the center but is somewhat weaker towards the edges of the frame, and I would rate it as inferior to the Olympus. Its also heavy and huge, I didn't like how it balanced on the A7. I'd much rather shoot a lens like that on a DSLR.
Is there a 24-80mm f2.8 lens that is not a bazooka?  Can it focus close?  No lens is perfect, but the 12-40mm f2.8 lens brings professional quality optics in a small package with a relatively long range.  That is the basis for my "over the top" claim.
ahaslett
ahaslett Forum Pro • Posts: 12,660
It's a remarkably well balanced lens, my most used one from different systems.  If it suits you best, then go over the top with it.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
