Budget Portrait Photopraphy?
Started Aug 24, 2018 | Discussions
RawGrass Forum Member • Posts: 83
I'm getting into fuji and I bought the XT100 with the 35mm f/2. For budget portraiture I was thinking the 23 f/2 and 50 f/2. Even though I am not primarily a portrait photographer and I was wondering if that is all the lenses I would need?
P.S. I'm not a big fan of zooms
 RawGrass's gear list:RawGrass's gear list
Samsung NX500 Fujifilm X-T100 Samsung NX 50-200mm F4-5.6 OIS Samsung NX 45mm F1.8 Samsung 16-50mm F3.5-5.6 power zoom +1 more
Hoenemor
Hoenemor Regular Member • Posts: 268
Re: Budget Portrait Photopraphy?
I would say that in my book you're pretty much covered. I use 35mm for most of my photography and I think it makes for more interesting portraits as you as you can place a person in an environment rather than a straight up portraits.
Of you want a more traditional focal length for portraits I would go for the 50mm f2. This is an excellent lens and I would say my second favourite focal length 😀
Julie
 Hoenemor's gear list:Hoenemor's gear list
Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 16mm F1.4 R WR XF 90mm Fujifilm XF 35mm F2 R WR +1 more
tdwesbo
tdwesbo Senior Member • Posts: 2,282
Your 35mm f2 is fine
Now start looking into lights and modifiers and so on. Portraiture is not very demanding of camera and lens but needs a full understanding of lighting and posing
 tdwesbo's gear list:tdwesbo's gear list
Nikon Z6 II Nikon Z 24-70mm F4
OP RawGrass Forum Member • Posts: 83
I don't really pose my subject and I will be doing the majority of my shoots outside/in natural light or with a single speedlight and a transmitter.
Sjak
Sjak Veteran Member • Posts: 7,318
I agree with other posters.
In addition, you may want to shoot with just the 35mm for a while. It will become obvious very soon whether you will want a wider, or a longer lens next, or maybe a similar lens but with a wider aperture.
A different approach, if you want an extra lens, is a manual focus lens, either new or vintage. There's quite some new Chinese and Korean lenses in Fuji X-mount with a very pleasing character, and usually very affordable.
This recent thread could be of interest: https://www.dpreview.com/forums/thread/4310489
Enjoy, portraits are fun!
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
Vic Chapman Forum Pro • Posts: 10,694
Personally I think the 23mm f2 will be of no use in fact the 35mm f2 is also rather short if you're working outside and more so if you are using artificial light and modifiers neither will this lens give much separation as the distance to the subject increases. 50mm f2 will work but personally I think the 60mm f2.4 (used) would be more ideal. It gives space to the subject while being close enough to maintain intimacy. For me its oof bokeh rates close to the 56mm f1.2 or 90mm f2 (the best outside portrait lens of all).
Vic
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan. Writer, comedian, poet, Goon. 1918 - 2002
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
BaeckerX1 Regular Member • Posts: 317
50mm F2 hands down.
 BaeckerX1's gear list:BaeckerX1's gear list
Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS XF 90mm +3 more
photokitteh Junior Member • Posts: 34
Try some legacy lens. Especially if you want some 50+mm
I'm using Rokkor 58/1.4 and Nikkor 105/2.5.
MC Rokkor-PF 58/1.4
Nikkor-P 105/2.5
 photokitteh's gear list:photokitteh's gear list
Olympus PEN E-PM2 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
ikaika777
ikaika777 Senior Member • Posts: 2,632
The 35 f2 would be great, and adding the 90 f2 together would be perfect.
After all is said and done and your photo is hanging on the wall, no one is going to know or care what camera, lens, or what post processing you used. All they care about is if the image moves them.
 ikaika777's gear list:ikaika777's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +18 more
Arizona Sunset
Arizona Sunset Veteran Member • Posts: 3,797
Here's what I'd do.
Buy the 50 f2 or 60 f2.8 for the compression and flattering perspective. From a practical perspective, the 35 f1.4 is a better "all around lens", but it is not a portrait specialist's tool. It will show slight distortion for a head shot (not because of the lens, because of the distance).
Also, from experience, if you show a woman her portrait at 23/35/50 FOV's, she almost always picks the 50 (and the one with the thinnest depth of field), unless it's to show off the location / view, in which case, the 23 half body at f2-f2.8 might be preferred.
 Arizona Sunset's gear list:Arizona Sunset's gear list
Canon G7 X II Sony RX1R II Sony RX100 VI Apple iPhone 7 Plus
Rudy Senior Member • Posts: 1,075
I have a budget set : 23 2.0, 50 2.0 60 2.4 and 55-200 (planning to ad 18mm F2.0)
Also i am not a real portrait photographer.
To be honest, the 60 2.4 is my best portrait lens, it gives something "magical", nice bokeh. Ofcourse the 56 1.4 is the ultimate, but expensive and heavy.
When i go on a walk, my 2.0 primes are with me. When i think i will shoot some objects or portraits, the 60 2.4 replaces my 50 2.0
If you go used lenses, you can pick up the 2 lenses for about the same price.
In the end, you can't go wrong with the 50 2.0, but maybe you can try the 60 also (i had the luck that i found a store where they had all the fuji lenses to try out)
 Rudy's gear list:Rudy's gear list
Canon EOS-1D Mark IV Canon EF 85mm F1.8 USM Sigma 50mm F1.4 EX DG HSM Canon EF 70-300mm f/4-5.6L IS USM Canon EF 28mm f/2.8 +1 more
Klaus dk
Klaus dk Veteran Member • Posts: 9,768
You can make good portraits with almost any lens, although a fixed focal length forces you to work within its limits.
The pose and the light should support your vision, if you have no vision, there'll be no portrait.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 24-105mm F4L IS USM +7 more
horizont Forum Member • Posts: 77
Jupiter 8 50 mm F/2 @ F/2 (on X-T100). Price including adapter is on average 40 EUR, can be less if you are lucky (I paid 20 EUR on a local flea market).
There are some other cheap MF vintage lenses with good characters for portraits available out there. L39 mount fits nice to X-T100, M42 adds some bulkiness. However, Pentacon 135 F/2.8 and Pentacon 200 F/4 are all in the range of 50 EUR and worth trying.
Wider and fast focal lengths are more problematic for budget vintage lenses in my experience. Flektogon 35 F/2.4 is already quiet expensive since it easily sells for 150 EUR. Jupiter 12 isn't adaptable.
Jupiter 8 50 mm F/2 @F/2
 horizont's gear list:horizont's gear list
Fujifilm X-T100 Fujifilm XF 35mm F1.4 R Fujifilm 16-50mm F3.5-5.6 II Fujifilm XF 23mm F2 R WR Nikon D7000 +4 more
gsmayes Regular Member • Posts: 145
Canon 50mm FD f/1.4 SSC bought on ebay for $50
 gsmayes's gear list:gsmayes's gear list
Canon EOS RP Canon RF 35mm F1.8 IS STM Macro Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon EOS 70D +14 more
Jon Schick Veteran Member • Posts: 5,162
I like the results from both my 35/1.4 and 60/2.4 (the latter is a lovely lens if you don't mind slightly slower AF) but also agree with other posters that there's much good fun to be had with MF lenses.  The Samyang 50/1.2 is superb at the price, and of the legacy lenses I'd very highly recommend the old Pentax Super Takumar 55/1.8 (M42 mount).
 Jon Schick's gear list:Jon Schick's gear list
Olympus E-M5 III Panasonic Lumix DC-S5 OM-1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +13 more
