DIY d70 ir conversion issues
Started Aug 24, 2018 | Discussions
kraff New Member • Posts: 3
Hi, I removed my hot filter from my D70. Does this make my camera full spectrum now? I have tried custom white balance off of bright green foliage, but cannot get the leaves and grass to come out looking white. This is without using a ir cut filter, just a uv filter.
Nikon D70
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: DIY d70 ir conversion issues
Pretty much full spectrum. White balance has a limited range on most cameras. You'll really want to shoot raw in any case.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
petrochemist Veteran Member • Posts: 3,619
What did you replace the hot mirror with? If it's glass or a UV filter then your conversion is properly known as two spectrum as it won't see UV significantly. For most IR type shooting this is fine, allowing filters to be used to give a very wide range of effects.
I never get white foliage from my full spectrum camera without desaturating unless using an IR only filter in front of the lens (720nm or preferably longer). With no filter added to the lens there will always be enough green recorded to give the foliage a definite hue.
With a red filter I typically see blue foliage SOOC (which most IR Photographers change to yellow with a red-blue channel swap). I prefer simply playing with the hue slider
Blue filters often give yellow foliage SOOC...
Actual effects on these filters will of course be highly dependent on the CWB.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
