760d Stuck in Movie mode - please help
Started Aug 24, 2018 | Discussions
Fat Digester New Member • Posts: 2
My 760d is stuck in movie mode, the on/off/movie switch is unresponsive, it wont even turn off (see image below). the camera is 1.5 years old and in fabulous condition, not a scratch !
  • I have tried removing battery, pressing the button to clear charge and re-inserting the battery.
  • I have tried factory resetting the camera using menu
  • I have tried alternative memory cards.
  • I have tried alternative official batteries.
  • i have tried to find a firmware update but there isnt one.
Q - So anyone had a similar problem to this before on this exact camera, is it a hardware or software problem?
Q - Is there a was of obtaining the original firmware and simply replacing the existing code?
any help appreciated.
Canon EOS Rebel T6s (EOS 760D / EOS 8000D)
rmexpress22 Senior Member • Posts: 2,304
Re: 760d Stuck in Movie mode - please help
Maybe same thing that happened to this guy's camera, happened to yours?
https://www.dpreview.com/forums/thread/4310704
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
OP Fat Digester New Member • Posts: 2
FIXED MY CAMERA AT NOT COST
OMG yes the life worked rmexpress22, thankyou so much, although its a different camera it was exactly the same problem.
so i studied the post, then set about dismantling the camera, being careful I noted where all the screws went as I go.
The trickiest bit was actually removing the rubber grip sections at the left hand side of the camera surrounding the plugs and sockets, behind this grip are 4 hidden screws that must be removed to take anything off at all.
Note: you do not need to remove the circular silver lens attachment frame.
once you have removed the black casing you will need to remove the two flash controls cables at the front of the camera and the 2 smaller button control cables at the back. there are two other cables that need to be detached on the right hand side, a large white cable at the bottom right and a flexible PCB with a plug on it at the top right, gentle force will free these up, and they were easy to reattach.
I was shocked at the switch mechanism used to turn the camera off and on, its a sprung super skinny 3 way switch that should always try to get the middle position, mine had gotten stuck in the camera mode. once I had it out I waggled it until loose again and the switch returns naturally to the centre position. I was surprised how small and flimsy this switch was but i was shocked that is was not screwed to anything, instead the switch was mounted directly onto some flexible PCB then either end of the PCB slotted into holes in the mount frame. but its not securely attached at all, terrible design imo.
anyhow thanks so much - i hope alot of people see this
Nice! Glad that you were able to fix it. Good to know, also. My girlfriend has a t6i so if it ever happens, I'll know what to do.
Mariaplaza New Member • Posts: 1
Hello I got the same problem on my 760d. Please can someone make a video or tutorial how to do it. Pls help pls. Email me pls in madissplaza17@gmail.com. Thank you so much.
Digirame Forum Pro • Posts: 41,858
See if there is any information here that would help.
https://www.dpreview.com/forums/thread/3809588
izzmix80 New Member • Posts: 1
Hi, I have the exact same issue with the exact same camera. Have you found a solution? I have also tried everything you have, to no avail.
