Nikon dot sight DF-M1 announced (for P1000)
Started Aug 23, 2018 | Discussions
P10004K
P10004K Senior Member • Posts: 1,337
 P10004K's gear list:P10004K's gear list
Sony a7R Samsung NX1 Sony a6300 Panasonic GH5 Nikon Coolpix P1000 +25 more
Gzoladz Contributing Member • Posts: 672
Re: Nikon dot sight DF-M1 announced (for P1000)
Wow I wasn't expecting that!
 Gzoladz's gear list:Gzoladz's gear list
Nikon Coolpix P1000
jshen808
jshen808 Forum Pro • Posts: 16,067
..Wowie!!!
..from past readings, there are many forum members wants one of these..
..Cheers..
 jshen808's gear list:jshen808's gear list
Panasonic Lumix DMC-FZ300 Panasonic FZ80/FZ82
Avian2016 Senior Member • Posts: 5,993
Is it true that it will be only compatible with the new P1000? If yes, I'm afraid this would be wrong move from Nikon. As owners of Nikon Dslrs will still be buying Oly EE-1or some other RDS.
P10004K
OP P10004K Senior Member • Posts: 1,337
no
Fine then for Nikon DSLR owners. Though it's more expensive than Oly's EE-1 costing 91-125 EUR (106-144 USD) in Germany.
Dodge_Rock
Dodge_Rock Senior Member • Posts: 2,792
BIFs May be Possible
Will 1st try larger EVF B4 considering this.  I bet it’ll sell out quick.  Smart folks over at Neekon right now.  Giving Sony a run for their money.
 Dodge_Rock's gear list:Dodge_Rock's gear list
Nikon Coolpix P950
fred from nashville Regular Member • Posts: 162
according to nikon site. it will work with any nikon with hot shoe.
fred from daytona (formerly fred from nashville)
 fred from nashville's gear list:fred from nashville's gear list
Nikon Coolpix 900 Nikon Coolpix P1000 Pentax K-1
I need to research how this would be used? Is it for very distant targets so instead of using the viewfinder you just point with the dot?
The main reason why I haven't pre-ordered the P1000 is because I want to see its size and weight in real life, currently I would be slow to get any accessory that adds to it, other than a macro or close up lens (what I am researching and may open a separate thread for)
Nikon Coolpix P1000
CrisL Contributing Member • Posts: 888
The only good reason I known to use it is to follow BIF perhaps other wildlife moving.
I own the Olympus EE-1 and intended to use it on the P1000
My question will be if there will be some reason to switch to the Nikon Red sight ?
Probably no answer until somebody can do the comparison
 CrisL's gear list:CrisL's gear list
Nikon Coolpix 950 Panasonic Lumix DMC-FZ70 Nikon Coolpix P900 Panasonic FZ80/FZ82 Nikon Coolpix P1000 +5 more
kimg1961 Regular Member • Posts: 131
I’m a great one for gadgets but even I am not sure how I would use it, unless it’s for tracking a lion across Kenya!!
 kimg1961's gear list:kimg1961's gear list
Panasonic Lumix DC-ZS70 Nikon Coolpix P1000 Sony a6000 Sony DT 18-55mm F3.5-5.6 SAM Apple iPhone 7 Plus +1 more
Nikon's RDS enables changing the dot color (red/green) and its form/shape (3 options: point, circle and circle with point inside). It has also bigger knobs for horizontal&vertical dot settings. Instead of having a "click-type" round button for the dot light intensity as is the case with Oly's RDS it employs 2 press type buttons.
Looks like an uprated Olympus EE-1 RDS with mods and a higher price.
Thanks for the precisions let's decide if it worth the 200 dollars to upgrade?
User4286416121 Contributing Member • Posts: 696
This was one of the things I was asking for. In addition to the focus ring and several other points. I will be buying several of these. If review is good, all my friends will receive one. Every birder could have one of these! (birding is one of the most participated activity.)
Call it a very wide rangefinder with a focus area dot. Makes keeping small items in the FOV easier. Imagine warblers and their well-known cloaking devices, shy Kingfishers, or even airshow jets at close-range, reading the watch on the pilot.
Now if focus could get faster and get rid of diffraction issues... Or use pre-focus on a spot..  Really hoping this works as expected.
If the new 500 pf focus and IQ are as we expect, winners all around.
jshen808
..thanks for explaining these neat benefits!
..Cheers..
(unknown member) Veteran Member • Posts: 4,084
Then why would they announce it the same day "alongside" the 500/5.6E ED PF VR, if it was only for the P1000?   (I have an idea the product web page, which is barely two days old, will be updated as it nears release).
I shoot anywhere between 400-800mm so anything that can assist these old eyes in tracking moving objects like flying birds is worth its weight in gold.
Agree!  Swallows at 1200. This should help tremendously.  Hoping it has a wide fov.
Not that it's needed, but I wonder if this unit has parallax correction?
http://jamesmbailey.com
My tests are different than yours
historianx wrote:Not that it's needed, but I wonder if this unit has parallax correction?
My understanding is that the sight has to be adjusted for distance.  I could be wrong.
