What upper limit do you put on iso for the g9 and g85?
Shadow9d9 Regular Member • Posts: 417
I am new to the m43 systems.  On my fuji xt20, I let it go up to 12800 sometimes.  I've read suggestions to keep it maxed at 3200 on m43.  What do you guys think?
Fujifilm X-T20 Panasonic G85 Panasonic Lumix DC-G9
NZ Scott
NZ Scott Veteran Member • Posts: 4,779
1600
On my old Olympus E-P3, I used to be reluctant to go past ISO 800.
With my Panasonic GM5 and G85, I happily shoot at ISO 1600.
I'll shoot at ISO 3200 if I have to, but this is very rare.
S
 NZ Scott's gear list:NZ Scott's gear list
Olympus PEN E-P3 Panasonic Lumix DMC-GM5 Panasonic G85 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital 45mm F1.8 +12 more
Adrian Tung
Adrian Tung Veteran Member • Posts: 3,473
Re: What upper limit do you put on iso for the g9 and g85?
Different people have different tolerances to quality and noise, so I think you may get varying answers here.
Personally, on auto ISO I don't let it go over 1600, but I may set the ISO manually to as high as needed to get the shot I want.
 Adrian Tung's gear list:Adrian Tung's gear list
Olympus Stylus Tough TG-870 Sony RX100 III Sony RX100 VI Olympus PEN-F Panasonic Lumix DC-G9 +11 more
alcelc
alcelc Veteran Member • Posts: 9,591
3200
Not owned G9, but the same generation GX85 of G85.
I set the ISO ceiling to 3200, at NR=0, the SOOC jpg can be reasonably clean with optimist exposure. Can touch 6400 but must with great caution.
Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G Vario 7-14mm F4 ASPH +8 more
joeletx Senior Member • Posts: 2,401
The difference with the G9 is there is no need to go to 12800 due to its superior IBIS comparing to your XT20. For scenery or portrait, you can shoot the G9 at 1600 instead of 12800 on the XT20 and still maintain at least 3 stop advantage, i.e. 1/15 sec. instead of 1/120 sec. with same aperture.
 joeletx's gear list:joeletx's gear list
Olympus E-500 Olympus E-M1 Olympus E-M1 II Olympus Zuiko Digital 2.0x Teleconverter EC-20 Olympus Zuiko Digital ED 18-180mm 1:3.5-6.3 +8 more
dbelling Regular Member • Posts: 390
True, as long as you can keep  you shutter speed low. However, if you have to shoot at 1/1000 second or faster because of fast action you may have to raise your ISO to 3200 or 6400. Especially if you are shooting in lower light. This is the dilemma if you are not using a FF camera (which I do not own).
Regards, Dave
Regards, Dave
It is not a dilemma if you know your gears strengths and limitations. You will learn technique to overcome shortcomings. No system is perfect in my opinion. Regardless, take a look at this thread by Vass.
https://www.dpreview.com/forums/post/60524875
Osa25 Senior Member • Posts: 1,647
Best to not oversell the product. Everything has pros and cons. Moving subject may require high shutter speed in which case this is not your ideal system for dim light. It has it’s strengths and so too weaknesses. Horses for courses...
 Osa25's gear list:Osa25's gear list
Panasonic Lumix DMC-GM5 Panasonic 20mm F1.7 II Panasonic Lumix G 42.5mm F1.7 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +1 more
G1Houston Senior Member • Posts: 2,741
Need a minimum of 1/125 sec to shoot people
Just because people move around, lip moves while talking, slight moving of the hands and head, etc.  We are not talking about people in excise or sport, just normal social situations, a very common subjects for all cameras.
Thus the values of IBIS or any IS are often greatly exaggerated.
 G1Houston's gear list:G1Houston's gear list
Nikon D7100 Olympus OM-D E-M10 II Panasonic Lumix G 20mm F1.7 ASPH Panasonic 12-35mm F2.8 Sigma 50mm F1.4 EX DG HSM +6 more
WhatSteveDid
WhatSteveDid Junior Member • Posts: 27
Re: Need a minimum of 1/125 sec to shoot people
5
I have the G80 (G85) and I try to stick to the upper limit of 1600, though I do think its more important to get the shot than worry about a bit of noise, so will stretch it if I absolutely have to and worry about fixing a bit of noise in post.
Fundamentally, I think a lot of people miss the point entirely - when a photo makes you look twice because it really catches your eye, the last thing I'd really be concerned about is a bit of noise.
 WhatSteveDid's gear list:WhatSteveDid's gear list
Sony a7R III Panasonic G85 Sony FE 24-70mm F2.8 GM Sony FE 85mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +6 more
Badwater Senior Member • Posts: 1,703
Depending on the camera and personal taste.  I can get away with more for video than photo.  Thus, I keep the high limit at 6400 on the G9.  However if the lighting and detail is good, I'll shoot 12800 for photo.
horsth Senior Member • Posts: 1,309
Re: ISO 6400 after PP
With the G9, don't pixelpeep !
 horsth's gear list:horsth's gear list
Fujifilm X20 Olympus E-M1 II Panasonic Lumix DC-G9 Olympus 12-40mm F2.8 Panasonic Leica Summilux DG 25mm F1.4 +8 more
mwyyc Regular Member • Posts: 192
This phrase needs to be plastered on the top of every gear review site's front page in big bold letters.
NZ Scott
Static subjects only
This is only true when photographing static subjects at slow shutter speeds.
Also, there are at least nine lenses available for the Fuji that are stabilised.
S
Re: Static subjects only
S
Fuji OIS lenses are no match for G9 5-1/2 stop IBIS. True for static subjects, but with Fuji, you have no choice but to raise the ISO.
Smith-64 Regular Member • Posts: 234
3200 for E1.2 (nt)
No text.
 Smith-64's gear list:Smith-64's gear list
Olympus E-M1 II Olympus 14-150 F4-5.6 II +1 more
