Safari and camera bags
Started Aug 20, 2018 | Discussions
larsbc Forum Pro • Posts: 18,282
Think Tank Change Up
FWIW I'm using a Think Tank Change Up. It fits my G85 with a 100-400 mounted and my GX7 with 8-18, 35-100/2.8 or 12-35/2.8 mounted, both with nose down, with room for another large-ish lens in between them. For that matter, if I had two 100-400 lenses, it could fit both cameras with those lenses, with a third in the slot between them. It has a wide waist belt along with a couple of shoulder straps so it's quite comfortable for day-long use. When sitting in a vehicle, you can loosen the belt and let it sit high on your torso. I also have a couple of Peak Design Capture Clips, one on the belt and one on one of the shoulder straps (I'm currently using it with just one strap). There's also stretchy outside pockets which are handy for stowing lens caps and filter cases, and inner pockets for managing batteries, unused filters, lens cleaning stuff, wallet, glasses, etc.
https://www.thinktankphoto.com/products/change-up-v2
Chris Noble
Chris Noble Veteran Member • Posts: 5,189
Pana 14-140
Perfect range for shooting from the safari 4-wheel drive.
 Chris Noble's gear list:Chris Noble's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +3 more
Phil Senior Member • Posts: 1,080
Re: Pana 14-140
I am a big advocate of a single battery, so I am renting another E-M1 ii. I am also renting a 100-400 and leaving my beloved 40-150 / TC-14 at home because of the weight. My second E-M1 ii will carry my 12-100, which I use extensively in city work. I suppose a fast prime will go and I have a 14-150 that will go in the suitcase as an emergency lens should I drop something.
I can carry all this in a Think Tank Streetwalker. I don't do a lot of wildlife, so renting the 100-400 seemed to make sense to me. I have an E-M5 ii, but taking identical cameras with one battery set makes renting the 100-400 easy. $600 rental on a $30K trip is not much of a hurdle.
Phil
 Phil's gear list:Phil's gear list
Olympus E-M5 II Olympus E-M1 II Olympus E-M1 III
Davejl Forum Member • Posts: 51
Re: Safari and camera bags
With respect to the Peak Design's Capture Clip, I love the system for hiking, usually hooked to a small LowePro backpack strap and sometimes to my belt (and also the Peak Design Clutch Hand Strap, but thinking of swtching to their wrist strap for added security). As the prior poster suggested, when seated in a vehicle you really don't want to be wearing a backpack. I have been thinking of mounting my capture clip on this: Think Tank Photo Pixel Racing Harness that attaches to their Think Tank Belt. I have not tried it, but it might work well in a safari vehicle. Although when seated I'm not sure if a long lens such as the 40-150 with TC would hang properly from the shoulder strap. I usually attach mine just below the sternum strap, so it isn't that high up. Good luck and please tell us what you ended up using and how well it worked.
 Davejl's gear list:Davejl's gear list
OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +1 more
David Yule Regular Member • Posts: 318
I did three safaris using Canon DSLRs (primary body, plus a backup) and also carried a Sony RX-100 compact with a 28-100 equivalent lens. The primary body had a 100-400L lens on it all the time I was in a vehicle. The spare DSLR body never left the rucksack.
If animals were too close for the DSLR and 100-400 I used the compact, which I kept in a case on my belt. About 95% of the animal photos were taken with the DSLR. I'd have found trying to juggle a second DSLR just too awkward.
I could see how keeping an EM5 plus short zoom in a belt case could work well for nearby animals and landscape shots. But I wouldn't fancy trying to juggle a third camera.
David
SGA
SGA Regular Member • Posts: 295
For our safari last year I used an E-M1 and E-M1.2.  On the drives I kept them on sling straps, resting in my lap when not shooting.   I had the 40-150/2.8 and 100-400 mounted most of the time, and the 12-35/2.8 and MC1.4 in the bag with me.
Backpacks don't work while your in the vehicle.
Belt clips don't work either (I'm partial to Spider, but the same goes for Capture Clips ).
A shoulder bag like the Tenba DNA might work to store the cameras while not shooting, but I didn't do this.  I transported my kit from the USA in a Think Tank Airport Essentials, which fit everything perfectly.  I brought a tripod, which turned out to be a waste.
Instagram: TheBassmanBlog
My Pictures: abbeyworks.smugmug.com
My Music: http://www.soundclick.com/bands/default.cfm?bandID=40937
My Blog: thebassmanblog.com
 SGA's gear list:SGA's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +7 more
Re: Think Tank Change Up
Further to my suggestion of the Change Up, I just used it on a small boat tour through some of the islands in the Gwaii Hanaas archipelago.  Sitting on the bench seat, it was quite comfortable having the pack sitting on my lap, and secured to me via the waist belt and one shoulder strap.  My G85 w/100-400 and GX7 w/12-35 were immediately accessible via the open bag (both bodies facing down, side-by-side).  When we landed and were walking around, I carried the G85 w/100-400 in the bag and the GX7 on a Capture Clip attached to the shoulder strap.  This worked out very well.  I also kept a Sony X3000 action cam attached to the waist belt via another Capture Clip.
The Change Up provided a great balance between ease of access to everything, including my filters, and a comfortable and flexible carry solution.  Besides the above-mentioned lenses, I also carried an 8-18.  I could also have fit another lens in there.
Chizuka
Chizuka Contributing Member • Posts: 967
Hi, although this post was started a while back, I thought I would ask you the following regarding the Think Tank Change Up V2.
Could I fit in it the Panasonic G9 with the PL 100-400 (mounted) and the Panasonic G85 with the Olympus 40-150 Pro (mounted) next to it, with room somewhere for the Olympus 12-40 Pro?
2nd question: besides using this bag on a safari or boat trip, have you ever hiked with that bag or walk for a couple of days with it?
“Make visible what, without you, might perhaps never have been seen.” -
Robert Bresson.
https://500px.com/blue_iris
https://www.flickr.com/photos/chizuka/
 Chizuka's gear list:Chizuka's gear list
Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Sony RX10 IV Olympus OM-D E-M10 II Panasonic Lumix DC-G9 +5 more
I'm 95% sure that you could.  I know I could fit two G85s mounted to 100-400s in the bag with room for a 12-40 in the lens slot between them.  One of the G85's would have to be turned 180 deg so that the long side of each body would be toward the middle of the bag when the camera/lens combo is stowed lens facing down.
I've never used it on a safari.  Just on a boat trip and 2 weeks of daily walks.  I think our longest walk was a 4-hr hike.  I didn't have any lower back pain even though I wore it on the side of my hip or perhaps mid-way between my side and my back, with only one shoulder strap (the other strap was in the mail).
gnik1 Regular Member • Posts: 263
Just back from Kruger. Took a G85 with 100-300 ii.  While I got some good pics, there were times when 100mm was too long at the short end. I also had a 14-140, but this would have been too short at the long end.
For a single camera solution, I now think the Leica 50-200 f2.8-f4 is the way to go.
Things happen pretty quickly, so while 2 bodies isn’t a bad idea, chances are you will have your most needed combo ready on your lap and the other will be used on occasion when time allows.
 gnik1's gear list:gnik1's gear list
Panasonic G85 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 100-300mm F4-5.6 II +1 more
