Anyone used the Oly E-pl9?
Started Aug 19, 2018 | Discussions
MaciekPruski Regular Member • Posts: 288
Hi, I'm thinking of replacing my Oly E-p3 (a great camera that I really enjoy using) with a newer model.
However, I'm slightly annoyed by the choices I get from Olympus. The pen F is just to expensive, I could afford it but I wouldn't feel comfortable walking around with such expensive camera where I live. On the other hand the e-pl9 seems very entry-level, no control dials at all.. There is obviously no mid-range model, except for the om-d line, but I would really like a pen camera, it is less pro looking and rather onobtrusive.
So I would like to ask anyone who used the e-pl9 about the ergonomics. Does it dequire a lot of menu diving to adjust parameters in PASM modes? Is the "super panel" accessible? Is exposure compensation easy to access? Will it frustrate me after using the e-p3 that has near perfect ergonomics and interface?
Thanks for any help.
 MaciekPruski's gear list:MaciekPruski's gear list
Pentax K-1 Pentax KP Pentax smc FA 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Pentax smc DA 17-70mm F4.0 AL (IF) SDM +6 more
Olympus E-PL9 Olympus PEN E-P3 Olympus PEN-F
(unknown member) Senior Member • Posts: 1,001
Re: Anyone used the Oly E-pl9?
A couple of years ago I replaced my E-P3 with an E-PL7. Much better IQ, better stabilisation, 0 sec. anti-shock setting (among others) made it a great step up. The PL7 probably isn't available anymore, but if you can get your hands on a PL8 rather than a PL9 I think that is the better option. The PL8 is the last model with an accessory port (should you one day want to add a viewfinder), whereas the PL9 seems to be "dumbed down" to make it easier for users stepping up from a smartphone or a compact camera. If you're accustomed to an E-P3 you may find these changes frustrating, hence my vote for the PL8. It's probably cheaper than the PL9, too!
dougjgreen1 Veteran Member • Posts: 4,068
Best choices: E-P5, E-PL7, and E-PL8
The E-PL7 and E-PL8 are quite similar, other than cosmetics, from one another.   And both of them have the ability to take an EVF - a feature Olympus removed from the E-PL9.   Very little was added to the E-PL9 from those other two cameras.   IMHO, the PL8 and PL7 are superior.
The other choice which is good is the E-P5.  It's main advantage compared to the E-PL models is it has a 2nd control dial, and superior IBIS.  Clean used examples of all of these cameras should sell for between $200 and $300 for the body.
 dougjgreen1's gear list:dougjgreen1's gear list
Olympus Stylus XZ-10 Nikon 1 V2 Olympus PEN E-P5 Olympus E-M1 Olympus E-PL7 +17 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Best choices: E-P5, E-PL7, and E-PL8
I'd vote for that. But I'm a little biased.
Anyway, if having used any Olympus before, then E-PL9 and E-M10 Mk3 are definite no-go zones, they have been dumbed down way too much so as to be unrecognisable and frustratingly non-configurable.
Of the recent cameras the E-PL8 or the E-M10 Mk2 are the best choice.
Consider the E-P5 if you can find one and that it has good control dials as that was a weak spot that had to be fixed under warranty for me. The E-PL7 is more or less the same as E-PL8.
Otherwise Panasonic GX85 or more recently the GX9 may be considered. Panasonic models are a mysterious jungle to me so best to ignore what I say there.
Wiki has a chart that helps with all M4/3 models https://en.wikipedia.org/wiki/Template:Micro_Four_Thirds_cameras and I have a Timeline chart of Olympus bodies http://homepages.ihug.com.au/~parsog/olyepl1/80-Oly-timeline.html
Regards...... Guy
