Panasonic 100-300 morning 11 advantages over mk1
Started Aug 19, 2018 | Discussions
Baron Birder Junior Member • Posts: 38
I shoot the Gh4 with the original Panasonic 100-300 And get some great shots.
Would  like to hear what benefits if any I could expect if I traded up to the 100-300 mk 11 especially from anyone has done this. Were you pleased or was the £500 plus cost of lens a disappointment?
The 100-400 is just too heavy for me.
Baron birder
Panasonic Lumix DMC-GH4
TheDream168
TheDream168 Regular Member • Posts: 155
Re: Panasonic 100-300 morning 11 advantages over mk1
Interesting that you seem very happy with the 100-300mm. I find it really good at 100mm, but not so much at 300mm. I use this lens only when the 100-400 is too big/heavy for what I'm doing (e.g. jogging).
I understand the only difference you can expect with the Mk II is the Power OIS over the older Mega OIS, but I haven't tested the difference.
Optical quality wise, no difference as far as I can tell. Here're some 300mm heavily-cropped shots I recently took with the Mk II:
OP Baron Birder Junior Member • Posts: 38
I have found it fine up to about 275mm after which it softens off
TomFid Veteran Member • Posts: 3,999
more
5
It also adds weather sealing, improved focus motors and aperture, and smoother zoom. The Power OIS adds dual IS support.
Mingjai
Mingjai Senior Member • Posts: 1,430
Re: more
I went from the Mk I to the Mk II and can definitely confirm that the focus speed is quicker and the IS is much better on the new version.
 Mingjai's gear list:Mingjai's gear list
Panasonic Lumix DC-GX9 Olympus E-M5 III Leica Nocticron 42.5mm Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic 8-18mm F2.8-4 +17 more
JSB1960 New Member • Posts: 16
Re: more
I've had 3 copies of the Mk i and eventually sold them all after disappointing results, bought an Oly 75-300 recently and it's really good, could be I've just lucked on a good copy though.
Re: more
This may be copy variation. I went from the 100-300 Mk I to the 75-300 Mk II. I don't see any significant optical difference (nor do I notice the 1/2 stop loss). The smoother zoom mechanism and smaller size are pluses though.
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
Re: more
Thank you for the FULL picture.  And yes, I do enjoy that lens, though I never had the original iteration of it.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
Re: more
Went to Park Cameras and chatted to them. The benefits of the dual IS are not available on the GH4 as there is no IS in the body only the lens.
As that is one of the main improvements I think I will save my pennies for when I upgrade the body as well eg Panasonic G9
