Miops trigger, Need 2.5mm extension cable
Started Aug 17, 2018 | Discussions
ilzho
ilzho New Member • Posts: 19
Ok, I received my Miops trigger and for the sound part of it, I want to move the Miops trigger a lot closer to my sound source. The little cable is came with is fine, but it's way too short.
Has anyone bought a 2.5mm extension cable and have it worked?
I bought a cable, but it didn't work, so I am assuming there is a specific type of 2.5mm cable that I need to get.
Any help is appreciated.
Thank you!
Piranha215
Piranha215 Forum Member • Posts: 70
Re: Miops trigger, Need 2.5mm extension cable
I invariably use a 2.5mm extension cable in order to get the right position relative to the source. I have never had any problems with this and I doubt if I ever will. I don't use a MIOPS, however.
 Piranha215's gear list:Piranha215's gear list
Sony a6000 Sigma 70-300mm F4-5.6 APO DG Macro
