Spectacular lens
Started Aug 17, 2018 | User reviews
Okyar Atilla New Member • Posts: 2
Spectacular lens
9
1. 35 mm equ is 80 - 300. So you can't find this range similar price in other brands.
2. Lens hood is smart designed. You never need to remove it.
3.  Very sharp.
4. Min focus is 70 cm. So You don't need close up filter or other equipment.
5. Result is fatastic with focus stacking photos. Just try.
And I read some comments about weight that says "a little heavy".
Gentlemen, OMD E M10 MK3 body and this lens lighther then Nikon 70-200 VR F/2,8
I thanks to myself for choosing these configuration.
Olympus M.Zuiko Digital ED 40-150mm F2.8 Pro
Telephoto zoom lens • Micro Four Thirds • V315050BU000
Announced: Sep 15, 2014
Okyar Atilla's score
5.0
Average community score
4.8
Leica M10 Olympus 40-150mm F2.8 Pro
glassoholic
glassoholic Veteran Member • Posts: 7,641
Re: Spectacular lens
Yes a great lens. Funny thing though for me is that I rarely use it. I usually shoot longer if needing long tele and use fast primes for short tele. But when it fits into what I need it never disappoints.
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me. Make the best you can of every day!
Geekapoo
Geekapoo Senior Member • Posts: 2,831
3. Very sharp.
Loved my copy of the lens (have sold it) and appreciate your review. However, I do take exception to your comment about the lens hood, which IMHO is a disaster waiting to happen. Google to learn about the many instances where the lens hood has disassembled, releasing springs and/or small pieces of metal..a $70 piece of junk.. crap.
 Geekapoo's gear list:Geekapoo's gear list
Sony RX10 IV Fujifilm X-E3 Sony a7R IV Sony a9 II Sony 35mm F1.4 G +15 more
nostradamus_8 Regular Member • Posts: 217
3. Very sharp.
Can second that about the lens hood, apart from that the lens is perfect.
Geekapoo
nostradamus_8 wrote:
3. Very sharp.
I want to add to the OP's post that the 40-150 works really well in combination with the 1.4xTE.
The 40-150 f2.8 PRO was easily one of the best lenses I've owned. Sold it because the AF-C for the EM1.1 is mediocre and decided to go the route of an RX10 IV instead of buying a 2nd gen EM1.
Day Hiker Forum Pro • Posts: 10,829
Rarely use it
I am like you; I rarely use my M.Zuiko 40-150mm f/2.8 Pro with my Pen F. But when I do, I smile when I see the images. Like the OP, I consider the lens spectacular.
Jim Pilcher
Summit County, Colorado, USA
Life is good in the woods
JIngrouille
JIngrouille Senior Member • Posts: 1,523
Great lens+the1.4tc  along with the 12-100 & 300mm pro all superb lenses and could add more no doubt.
I think I must be one of the lucky ones as I have no problem with the lens hood although I do prefer the one one the 300mm f4
 JIngrouille's gear list:JIngrouille's gear list
Sony RX10 IV Panasonic Lumix DC-G9 Olympus 40-150mm F2.8 Pro Olympus 14-150 F4-5.6 II Panasonic Leica 100-400mm F4.0-6.3 ASPH +2 more
Badwater Senior Member • Posts: 2,095
I totally agree.  The Olympus 40-150 Pro may be one of the best lenses in the MFT line up.  I had borrowed the lens for a week, and took it out for some birding, and elephant seal videos.  That f/2.8 at 300mm equivalent is amazing.  In fact, I had to stop down to 5.6 get some of the birds in total focus.  Optic quality is as good as any top of the line 70-200 f/2.8 lens from any manufacture.
AF was super fast and accurate on the G9.  Stability was excellent with the G9's 5 axis IBIS.  Any concerns I had about compatibility went out the window.  The Olympus works great on the G9.
The way it feels: smooth zoom and focus ring is excellent. And focus by wire was no problem.  And the range makes it great for portrait, landscape, action, and wildlife.  This is one of those all around zooms that is essential for any kit.  And for what they're priced at it's a great deal.
The only reason, I didn't keep it is, I already have the smaller lighter Panasonic 35-100 f/2.8 Power OIS II.   If it wasn't for the size and weight, I would have the Olympus in my kit.
Skeeterbytes Forum Pro • Posts: 23,182
My most-used lens of a pretty large collection. Mostly for sports I also use it for portraits, landscape and cityscape (good distance compression) and as you note, near-macro closeup. And trying to shoot the dog (he's very fast). Mine has been flawless for several years of heavy use.
What I'd like is a mkii with distance limit switch and OIS, like the 300 and 12-100. Make it "more perfecter."
Rick
rsmithgi Senior Member • Posts: 2,939
Also my most used lens because of sports. Just an excellent lens for HS and Club Soccer.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
Geekapoo
I have been wondering how well the PL 50-200 and 100-400 compare with the Oly 40-150. I assume that I'll stay with my RX10 IV for the next couple of years and then return to m43. I will look closely at the PL lenses mentioned and any new lens releases. The 40-150 is fantastic but even with the 1.4xTE, it only reaches 420mm..and I'm already quite spoiled by the 600mm reach of the RX10 IV (and quality of lens plus the stellar AF). If the current PL lenses canot match the 40-150 then I'm not interested in purchasing either of them.
bobn2
bobn2 Forum Pro • Posts: 71,955
5
Yup, it's smaller and lighter than something that does a lot more. It's also larger and heavier than things,that do a lot less.
Ride easy, William.
Bob
Colin Smith1 Senior Member • Posts: 1,104
3. Very sharp.
I think Olympus has redesigned the lens hood.  I had mine replaced under warranty after I experienced the rolling, tiny ball bearings failure.  The new one has worked perfectly.  It is the sharpest lens that I own from Olympus.
Colin Smith
 Colin Smith1's gear list:Colin Smith1's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 85mm F2 Macro IS STM Canon RF 800mm F11 IS STM
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Re: Rarely use it
Jim Pilcher
I bought it as a specialist use lens and don't think I could do without it - for indoor sports in dimly lit halls and for most motorsports (especially in UK winter when there is so little light), and also for soccer and rugby matches.
So in short I suppose I am saying it is my 'go to' sports lens of choice - and boy does it ever deliver.
PS. I am in love with that wonderfully clever sliding hood mechanism.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
glassoholic
Re: Rarely use it
Jim Pilcher
My feeling is that it has the quickest AF drive of any lens I have tried... really turbo charged!
Space the final frontier Senior Member • Posts: 1,229
No doubt it is a great lens. But the zoom range does not suit me. I have the cheap version and don't find it that useful. I have the 4/3 50-200 swd which suits me better. If I don' need the reach, I have 12-100 for travel.
 Space the final frontier's gear list:Space the final frontier's gear list
Olympus E-M1 II Olympus E-M1 III Olympus Zuiko Digital 35mm 1:3.5 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Sigma 70mm F2.8 EX DG Macro +14 more
Re: Rarely use it
Agree, it's almost as though the focus is equipped with ESP. Suspect in part it's due to Oly splitting AF duties between two modules, which I suppose divides the total moving mass between them rather than being handled by one motor. Silent, too.
Rick
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
Yes, a very beautiful lens, both in what it is capable of and how it is built.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
glassoholic
Re: Rarely use it
Rick
I wonder if other lenses have got this setup?
Velocity of Sound
Velocity of Sound Contributing Member • Posts: 964
Is the AF really different?
I just recently bought one, and have only had the chance to use it on still objects around my apartment.  My sense is that the autofocus speed is about the same as the other "pro" lenses (12-100mm, 25mm f/1.2, and 17mm f/1.2 are my comparisons; the 8mm f/1.8 is pretty quick but it generally doesn't need to do much focus adjustment so I don't have a good feel for its speed).  I know from the initial press release that the autofocus motor design is a bit different than the other lenses from that time period; I'm not sure if that became Olympus' standard design moving forward.
I like the 40-150mm so far, too.  Haven't had a chance to test image quality, but if it's anything like the 12-100mm (and based on reviews, it should be) then I'll be very pleased.  Size and weight aren't issues to me, but I'm used to 4/3 lenses.
The only odd things I've noticed:
1) When you adjust the zoom, in a dead-silent room or if you put your ear to the barrel, you can hear something mechanical whirring as you adjust.  You can see the lens adjusting even when removed from the camera so I know the zoom mechanism isn't a powered feature, but I found that interesting.
2) This is the only m.Zuiko lens I have that closes the aperture down when you turn the camera off.  I don't know the reason for that.
 Velocity of Sound's gear list:Velocity of Sound's gear list
Olympus E-M1 II Fujifilm GFX 50S Fujifilm GFX 100S OM-1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +14 more
