Lost in the wide lens jungle !
Started Aug 15, 2018 | Discussions
Solomai New Member • Posts: 1
Hey everyone,
As the title probably implies, I'm looking for a new lens with a max of ~600€ in price. But I'm getting so lost in the possibilities, it's getting scary.
Right now, my go-to lens is the Oly 25 f1/8 which has followed me for the past 2 or 3 years, almost alone with the occasional addition of the Oly 40-150 and very rarely used 14-42 kit lens.
As I'm getting a bit more into video, I swapped my E-M10 for a G80/G85 a few month ago but now I feel REALLY locked in with my lonely 25mm.
I'd like to find a good friend for him though, the uses would be I think mostly landscapes/night photo along with, well, the usual shots you can expect with something wider or smaller than 25mm.
But I'm really wondering what would be the best bet, right now I'm looking at the :
• Olympus 12 - 40 PRO 2.8
• Olympus 12 f2 / Samyang 12 f2 (and basically a lot of prime lenses)
• Panasonic 7 - 14 f4
And a few more wide range lenses that look less interesting than those ones.
It would be awesome if you could give me a hand on this one ! Thanks !
addlightness Veteran Member • Posts: 3,641
Re: Lost in the wide lens jungle !
For stationary objects, I find my 9-18 more than adequate for night photography as well as landscape.  I also have a 12-32 which is pretty good but not wide enough for landscape IMO.  I use filters, so both the 7-14 offerings won't do.
As for AF prime, I was eyeing the Oly 12/f2.0 but since I don't really need f2.0, my 9-18 or 12-32 is good enough.  For ultra-wide, I use my Samyang 7.5FE
Hope this helps.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
Given what you have, get the 12-40 first.
A single fixed-focal-length lens is limiting. The 12-40 is the very best wide zoom lens you can get. You can later decide whether 12mm at the wide end is enough or not, and add an ultra-wide if needed. I find that no matter which lenses I take with me I end up taking pictures almost solely with the 12-40.
Getting to know the Olympus OM-D E-M5 II.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
3dwag
3dwag Veteran Member • Posts: 4,674
Solomai wrote:
Hey everyone,
An excellent all-around zoom, main advantage compared to Lumix is the much-closer focusing, plus I really like the manual focus slip-ring.
However...IMO since you are looking for a companion towards the wide end for your 25mm friend, you should stretch (pun not intended) and seriously consider the PL 8-18mm.  This will give you much more interesting framing and perspective options than 12mm max wide.  The advantages of the 8-18mm vs the 7-14mm f/4 are that a) 18mm is close to a more “normal” viewing angle than 14mm when you need it (without having to change lenses), b) it takes standard round screw-in filters, and c) it is weather sealed, like your camera.
The 8-18mm is also on sale right now in the USA, not sure about where you are from though, so it might be just a bit more than the 12-40mm, if you can manage it.
Since you have the Panasonic body now, other choices - again, depending on pricing in your region, either the Leica 12-60 f/2.8-f/4 or the Lumix kit lens 12-60 f/3.5-5.6 would also be good choices.  On the other hand, the constant-aperture 12-40mm f/2.8 is certainly a fine lens.  These all give you a nice all-purpose wider to mild telephoto range at higher IQ than your old 14-42mm kit lens, and are weather-sealed, if that is of any consideration for you.
You would still have your 25mm f/1.8 for when you need the light gathering.
-Dennis W.
Austin, Texas
¯\_|’_’|_/¯
http://www.pbase.com/3dwag/image/97156660.jpg
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
Aaron801 Veteran Member • Posts: 7,900
Re: Given what you have, get the 12-40 first.
That's what I would do. I had a kit zoom type thing that I upgraded to the slower 9and cheaper) Panasonic 12-60mm, but I'd love to have that Oly 12-40mm. I'd much prefer the extra wide f-stop over the 20mm at the long end and even though my 12-60mm seems pretty sharp, I know that the 12-40mm is more so.
Primes are great, but a fast, sharp zoom in that medium range that goes down to 12mm for me would be perfect and a lens that I'd use more than anything else, as I do my 12-60mm. I feel like 12mm is plenty wide and though I'd love to play around with something even wider, I seriously doubt that I'd be shooting all that much at focal lengths lower than 12mm... A 12-40mm 2.8 is going to be super versatile... at least for most folks.
my flickr:
www.flickr.com/photos/128435329@N08/
 Aaron801's gear list:Aaron801's gear list
Olympus PEN-F Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +1 more
larsbc Forum Pro • Posts: 18,282
video
If you're considering doing any handheld video with your G85, I'd strongly suggest the Panasonic 12-35/2.8 (v1 or v2) over the Olympus 12-40/2.8 because the Panny's OIS will work hand-in-hand with your camera's internal stabilization system.
For a superwide zoom, the 7-14/4 is a good choice as long as you're only going to use it on a Panasonic body (due to purple blob issue it has with Olympus bodies).  Also, if you want to use filters (such as an ND filter) then you'll have to buy some sort of third party filter adapter setup to use with that lens.  For superwide zooms that accept threaded filters, you're looking at the Olympus 9-18 and the Panny 8-18.  I've got both and strongly prefer the 8-18 although I do like the 9-18's small size.  Unfortunately, my 9-18 is soft or smeared at the edges of the frame vs the 8-18 which is sharp and contrasty.  So if you're considering the 9-18, definitely try it in a shop, first.
The recommendations for the Panasonic 12-60/3.5-5.6 are a good idea, too.
Walt Palmer
Walt Palmer Senior Member • Posts: 2,001
The Laowa 7.5mm f/2.0 is another to consider.
Badwater Senior Member • Posts: 2,095
Solomai wrote:
Hey everyone,
Either the 12-40 Pro f/2.8 or 7-14 f/4 would do great for video.  Both have constant apertures which make zooming easier for less exposure changes.  And both have smooth manual focus rings for pulling focus.  And their zoom rings area also smooth for slow zooming or fast.
Keep in mind that the Olympus 12-40 will suit more video and photo shooting situations.  At 12mm there is not much distortion, and the constant fast aperture makes it ideal for video and photo in low light.  The longer range can also be used for portrait, and interview videos and photo.  The shorter range is ideal for night photography and landscapes.
The 7-14 ultra wide is a specialty lens for video used for close up shots, and to create distortion.  You've seen them used in skateboard and other action type videos.  It's a close up lens.  In video it distorts the architecture but some like to use it for architecture.  Other's avoid it for architecture due to the distortion and false sense of space in real estate sales.
jeffharris
jeffharris Forum Pro • Posts: 11,409
• Olympus 12-40mm f2.8
• Panasonic 7-14mm f4
You can't go wrong with either lens. I have both. @ the 600€ mark, look at used lenses.
The 12-40mm is more of an all-around lens.
The 7-14mm a bit more specialized and requires some practice learning to compose with such a wide field of view (114° @ 7mm). It was the first "extra" M4/3 lens I bought and remains one of my most used (mainly for business) and favorites.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
