Why dxomark tests show so bad result for Panasonic cameras in comparison with Olympus
Started Aug 15, 2018 | Discussions
Max Polonski
Max Polonski Regular Member • Posts: 324
For example results for Panas lens 15\1.7 with Oly EM5 and Panas Gx7. Panasonic shows resolution are much worse.
 Max Polonski's gear list:Max Polonski's gear list
Fujifilm X-T20 Sony a7R III Panasonic Lumix DC-GX9
Panasonic Lumix DMC-GX7
(unknown member) Veteran Member • Posts: 7,274
Different sensor stack
8
GX7 has a different AA filter and little different sensor than E-M5.
And who cares about DXO when their testing methods do not reflect the reality anyways?
Regardless of that test results (or any similar test results really) you can make same IQ images.
If you want to compare something, get your hands on the gear and do the tests yourself in real world situation, process the files yourself and then make the final images as you would need and then do the comparison.
Max Polonski
OP Max Polonski Regular Member • Posts: 324
Re: Different sensor stack
Have to notice, that dpreview test shows not so bad results.
DPReview Test
alcelc
alcelc Forum Pro • Posts: 19,003
Re: Why dxomark tests show so bad result for Panasonic cameras in comparison with Olympus
This recent thread on similar matter (low DXO score of GX7) might of your interest:
https://www.dpreview.com/forums/post/61501279
Albert
Cagey75
Cagey75 Senior Member • Posts: 1,347
I sometimes think they just chuck numbers into a blender and post up the results.  They over inflated the ISO performance of the EM1mkII, it is no better than any other mid range to higher end M43 sensor but it has a massive spike on DXO ... this is DXO who still can't figure out how to test Fuji's X-Trans, all these years later btw.  Huge pinch of salt ...
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Fujifilm XC 35mm F2 Venus Laowa 65mm F2.8 Macro +1 more
Max Polonski
Thanks a lot. Looks like it is a reason why I get so much blurred  photos at night sessions.
alcelc
If purely about shutter shock, you should get soft image rather than blurry image. Blurry image might often be caused by OOF, stability etc more.
When it'll be possible, use e-shutter (12 bits) could be a better option of course. I indeed have not much problem on shooting with GX7 in low lighting, quite dark indeed:
Albert
drj3 Forum Pro • Posts: 12,634
You can always use Photons to Photos
http://www.photonstophotos.net/Charts/PDR.htm
It is easy to use for quick comparisons, they also find the E-M1.2 and the Panasonic G9 to be different from the other mFTs cameras and Fuji is included.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 16,262
Just disregard
As a professional shooting GX7, I long ago learned to disregard DxOMark scores. My GX7 delivered sharp, crisp, detailed images that outclassed my Canon 1Ds MkII.
"No matter where you go, there you are." - Buckaroo Banzai
http://jacquescornell.photography
http://happening.photos
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-LF1 Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-GX8 Sony a7R III +54 more
