Lens for Lumix G7 - advice needed
Started Aug 11, 2018 | Discussions
Sparkio83 New Member • Posts: 6
Hi. I'm new to this forum and hope you can offer some advice.
I have a Lumix G7 camera which came with a 14-42 lens. The camera has micro four thirds fitting.
I want a new lens with better Zoom and came across this Olympus ED 40-150 on eBay https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F173452051146
I assum that will fit my camera? Will it work with the auto focus? Are there any other lenses you can recommend? I'll need to but used.
Thank you
Panasonic Lumix DMC-G7
KirillQPR Regular Member • Posts: 140
Re: Lens for Lumix G7 - advice needed
The item depicted there is a native m4/3 lens, just like the 14-42mm that came with your G7, so it will work just fine.
 KirillQPR's gear list:KirillQPR's gear list
Sigma dp3 Quattro Sony Xperia 5
idahophotoguy New Member • Posts: 14
Are you sure about that?
I'm concerned that it may not be a Micro 4/3....but the regular 4/3 mount.
brentbrent Veteran Member • Posts: 5,768
The description says, "This Olympus M.Zuiko f/4.0-5.6 Telephoto Zoom lens . . . ." An "M. Zuiko" lens is a native Micro Four Thirds lens.
Here it is new from B&H: https://www.bhphotovideo.com/c/product/827291-REG/Olympus_V315030BU000_40_150Mm_F_4_5_6_R_M_Zuiko.html
I had one, and it's amazingly good for the price.  It is widely regarded as one of the best bang-for-your-buck lenses in the MFT catalog.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
good general lens
Thank you
This would fit.
there are multiple zoom lenses of this ilk
panasonic has a 35-100 in two different construtions
also has a 45-150 or a 45-175 and a 45-200 for the basic telephot zoom ranges.
the panasonic ones might be better, but I have done well with the 40-150 from olympus.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
It is a micro four thirds lens and will fit your camera just fine.  It is also an underrated lens and give you the extra reach you seek.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
hindesite Veteran Member • Posts: 4,893
I have that lens and it works with my G7 just fine BUT unless price is your main criteria, I would get the 45-150 Lumix because this has OIS. The M.Zuiko has no stabilisation.
In the right conditions, the M.Zuiko does produce very good images, but the Lumix is just as good and easier to use.
Aberaeron Forum Pro • Posts: 10,184
This.
Don't buy it!   The G7 has no in-body image stabilisation and neither has that lens. It is altogether too long to be without. Get a Lumix lens, which is stabilised, for that focal length range. Ideally a 14-140 so you can leave it on most of the time. It is a superb all-round lens for the G7.
kiwigirl
kiwigirl Senior Member • Posts: 1,934
G7 does not have in-body image stabilization.  As I understand it this lens does not have built-in stabilization?  Wouldn't he be better off with a Panasonic lens for a long zoom?
 kiwigirl's gear list:kiwigirl's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-ZS3 Panasonic Lumix DC-ZS70 Panasonic G85 Panasonic GX850 +9 more
the OP might do better, but it did not seem to bother me with the lack of IS
OP Sparkio83 New Member • Posts: 6
This.
Thanks for your advice. I ended up not getting it. I'm not experienced with lenses so don't know what I'm looking for. Will any Lumix lens work with the G7 and do auto focus?
FunGuy66
FunGuy66 Regular Member • Posts: 304
Those branded Lumix G and Leica DG, yes. (Leica DG is still Panasonic.)
There are four Panasonic Leica lenses for regular Four Thirds. You're unlikely to come across them in the wild, but you can recognize them by the "Leica D" designation.
Scroll all the way to the bottom of dpreview's list of Panasonic lenses:
https://www.dpreview.com/products/panasonic/lenses?subcategoryId=lenses&page=1
Thanks. I'll have a look at that list. Mine needs micro four thirds so I'll look for those reviews
FunGuy66
Sorry, I should have been clearer: I called your attention to those lenses as the only four Panasonic interchangeable lenses you need to avoid.
Ah, thank you!
