Panasonic G7 - trouble focusing in low light.
Started Aug 11, 2018 | Discussions
Brisn5757 Veteran Member • Posts: 4,540
One weakness with this camera compared to other cameras I've used is that the Panasonic G7 seems to keep changing focus when trying to record a lit object at night. I usually use Auto focus but it will only stay in focus a short time then it goes out of focus then back into focus. Something seems to falsely tells the camera that it's not in focus when it is.
If I'm quick enough I can switch from Auto Focus to manual focus while it's correctly focused to lock the focus. But it's more difficult when recording in video as you can have a mixture of near and far subjects.
I've tried using manual focus only but it's difficult to focus on a dimly lit object even with the magnified screen that pops up.
Do others have this problem and have found a way to over come it?
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
Panasonic Lumix DMC-G7
Aberaeron Forum Pro • Posts: 10,184
Re: Panasonic G7 - trouble focusing in low light.
Brian
Use single autofocus rather than flexible or continuous.
kravemir Regular Member • Posts: 165
All G/GX cameras with set zoom?
I've read similar posts for different G/GX cameras.. It seems to be common for Panasonic Lumix G/GX with set zoom.
I own Panasonic 42.5 f1.7, and it performs much better in low light.
Belief is each man's own choice, and my choice is to believe in God.
 kravemir's gear list:kravemir's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Lumix G 42.5mm F1.7
tef68 Regular Member • Posts: 112
If you use AFF or AFC mode then what you describe is true.
Set the camera to AFS and you should be ok.
 tef68's gear list:tef68's gear list
Panasonic Lumix DMC-GX85 Olympus E-M1 II Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +6 more
Why is it like that?
OP Brisn5757 Veteran Member • Posts: 4,540
Brian
The small lever on the back of this camera is set to AFS, unless there is some other setting in the menu that I need to change.
Brian
It normally is set to AFS  (lever on back of camera),  unless there is another setting in the menu.
Brian
Brian
While taking another look at the camera the lever is pointing to AFS/AFF, so there must be some common in the menu to tell the camera that I want AFS only.
Brian
Brian
Brian
I’ve lost my G7, hopefully temporarily, but from memory try switching off tracking or face recognition. Once you lock focus there should be no focus breathing no matter what the light.
alcelc
alcelc Forum Pro • Posts: 19,006
AFS =/= focus mode
AFS = AF single shot. It is a drive mode but is nothing relate to focus. I.e., how many focus point you use.
As per my experience on still shooting (the running LED light hanging over trees should be regarded as still object), use single focus point in its smallest focus box size should be the fastest and most accurate way.
However when it is in the dark, a slightly larger size focus box might be easier for the camera to find and lock on a focus (more options within a larger focus area) at the risk of not focus on exactly the point you wish to focus.
Albert
Brian
Brian
Turn off AFF in the menu and use single autofocus, which is what you have been repeatedly advised to do.
Re: AFS =/= focus mode
It does not mean single shot. It means that it locks focus once. You can use burst mode with this setting.
alcelc
U are right. My ommission.
Albert
I usually have the camera set for Spot Focus so anything in the center of the cameras view will be in focus. I see your point about needing a bigger area for the camera to focus in low light situations.
I could turn the peaking focusing aid and use manual focus but the peaking colour would get in the way of viewing the image. It would be nice if you could quickly turn peaking on or off.
Brian
Aberaeron wrote:
Brian
Brian
Well do. It's been a while since I've studied the manual for the camera.
Brian
Brian
That's another reason why you may have difficulty achieving focus lock.
The camera is actually very good indeed at focussing in low light. You do need to learn how best to use it though, just as with any sophisticated tool.
alcelc
Focus Peaking
Brian
I think you can, just assign the Peaking to one of your fn keys or put it on the Q.Menu...
P.71 of pdf Operating Manual of G7.
Albert
pannumon Veteran Member • Posts: 4,130
It's also generally a good idea to set "Quick AF" to "OFF". Unlike what someone might think, the opposite of "Quick AF" is not "Slow AF", but "user-triggered AF". Setting Quick AF to OFF disables constant focusing when shutter button / back focus button are not pressed.
In earlier models this setting was called "Pre-focus", which in my option is much much better name.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
Ah yes! I set that to 'off' on all cameras when new and forget about it.
Brian
I have done very little night photography with this camera so it looks like I'll need to experiment more with the settings.
There are times when the camera will go out of focus for a moment even when recording video in the daytime. However I'll check the setting on this camera.
Brian
