Doug Lauson wrote:
I'm so sad in writing this post on the M5. I have had this camera for a few years and it has travelled with me around the world - North America, UK, Ireland, Wales, 8 countries in Europe, Kenya on safari, etc. I have babied this camera because it is the ideal travel camera (mt 5DSR and 6D are too big for travel) and has given me great photos. In preparing for my upcoming trip to the Peoples' Republic of China, I discovered that the plastic bottom base-plate is cracked all around the tripod socket. There are 4 screws around the tripod socket and it is so badly cracked on the one side that small bits of plastic have fallen out. Because it is too late to get it fixed, I have put Gorilla glue in the cracks to hold it in place for my trip. I hope it works.
In thinking of how this could have happened, the only thing I can come up with is the fact that I used the Peak Design belt clip on my Europe and Kenya trips and that the constant bouncing of the camera on my belt must have eventually weakened and broken the base-plate.
My disappointment is that this is right around the metal tripod socket and it is undamaged. So, what's the point of having a steel tripod socket when it is attached to a plastic base-plate?
My wife with the EOSM on her hip via the Peak Design ProPad and CapturePRO V2.
I've been using the Peak Design CapturePRO V2 belt clip with the Peak Design ProPad - on a daily basis since early 2015. On rare occasions I'll mount the camera with the belt clip to the shoulder strap of a backpack harness. But 99% of the time it's on my hip via the ProPad. And it can take a lot of accidental but serious impacts without any damage to the camera or the mounting plate. On one occasion I chipped a hard-wood cabinet when I turned around, gouging a 2 inch long section out of the wood of a table. I've screwed the mount to the base of my EOS M and also the EOS M6 VERY, VERY tight. The strength of the grip has even left a slight impression against the plastic panel on the base. When I say that I screw the mounting plate down right, I really mean it. No movement from the rig no matter how hard you apply pressure. I've knocked the M6 camera VERY hard against a couple of hard surfaces when wearing it this way but there's been no harm done to the base region.
I may be wrong here, but I would imagine that the M6 and M5 are designed on roughly the same platform. It's interesting that your camera has sustained physical damage. Are you using the normal sized plate because I think they produce a Mini plate that is for small cameras and that one might be a problem. The plate I'm using is smaller than a Manfrotto standard plate but it fits in most Manfrotto tripod mount heads. It's quite large and is just shy by a few mm of being half the width of the entire EOS M6 base.
When the CapturePRO V2 is on my cameras, the base clip (which has a raised, red "grip" area) overlaps the mounting region of the camera body considerably. The mounting base plate on the camera itself is much smaller than the size of the base plate from Peak Design. This means that if the camera is pulled hard against the clip mount in any direction at all, the same amount of pressure is applied in the opposite direction against the base of the camera.
The only way I can see damage being done to your M5 is if the CapturePRO base was the wrong size (eg Mini Plate), or if the base plate was loose (or incorrectly threaded on to the tripod mount). If it was loose, then hard pressure against the unit would likely cause exactly this sort of damage. Either that or an accident with a falling tripod etc or travelbag might well have applied enough torque to do the damage.
The frustrating thing about the CapturePRO plates is that there's a V1, V2 and possibly a new V3 version and they all have differences in physical design. I suspect that the decision to remove the fold-down ring-lock from the latest version shows how miserly Peak Design have become because now you need to carry other tools to secure the mount. The Micro Mount still has the fold-down twist lock. But not the V3. The body of the M6 uses a very strong Polycarbonate material that can be dented more easily than it can be split. Again, the circumstances around your camera's damage is unusual.
If you feel that the design of the M5 is poor or that there's a flaw in the design, it can be grounds for demanding a repair or a refund from most manufacturers - even if the warranty has expired. All goods must be suitable for the purpose of which they were sold and this means a tripod mount on the base of a camera should not be capable of splitting the base of the camera where the mount is situated. A consideration is that Canon did not design their EOSM cameras to be carried via a mount attached to the base plate. Nor did they design their cameras to work with any specific other-brand products. At least consider sending either your camera (or at some photographs) to Canon because they'll actually put an alert out to their design and manufacture department heads to ensure that in the event of a problem, it is dealt with for future designs.
My EOS M1 on the Peak Design system.
I saw some of these last week at my local camera dealer and I'm thinking I'll try to buy at least one more Mount (V2) since the newer ones have a less appealing mechanical design.
