Best Prime Lens to Buy in the Format
Started Aug 9, 2018 | Discussions
Rupert The Camera Man Junior Member • Posts: 27
Hello all, I am planning on getting a Panny G7 in the next few weeks. I'm going to be getting it with the 14-42 kit lens and soon after buying a telephoto. I want to get a prime lens for my camera both for better low light performance and also for a simpler and smaller package. I am looking into sub- 500 dollar primes which I feel has a good selection. What is the best prime for the job? Thanks!
 Rupert The Camera Man's gear list:Rupert The Camera Man's gear list
Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS
yanisha Senior Member • Posts: 2,630
Panasonic 20mm f1.7
6
Panasonic 20mm f1.7 for your Panasonic G7.
inlawbiker Senior Member • Posts: 2,066
Re: Best Prime Lens to Buy in the Format
Best at that price range? It depends entirely on your preferred angle of view. I personally am a 50mm (Full Frame) fan, so I would select the Panasonic Lumix 25mm 1.4. This is a unique, special lens worth seeking out.
If you like a bit wider then I would get the Olympus 17mm 1.8 or Panasonic 20mm 1.7.  Again depends entirely on your preferences. Personally again, I like the Panasonic 20 due to the size.
At your price range you can probably pull off two lenses, buying used, such as a Panasonic 20 + Olympus 45 1.8, which is a pretty powerful little combo.
Greg
 inlawbiker's gear list:inlawbiker's gear list
Panasonic Lumix DMC-G7 Fujifilm X-T2 Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Badwater Senior Member • Posts: 2,095
8
Depends on what you're using the prime for. A 15mm f/1.7 is the ideal lens for street, indoor photography, and video. A 42.5 f/1.7 is a great portrait lens with huge bokeh ability. Both are small.
ekaton Senior Member • Posts: 1,046
Get two: Panasonic 42.5 f1.7 for portraits (has OIS in contrast to Oly's 45 f1.8) and a Panasonic 20mm or 25 f1.7.
 ekaton's gear list:ekaton's gear list
Ricoh GR IIIx Sony a7R IV Sony a7C Leica Summilux-M 50mm f/1.4 ASPH Leica APO-Summicron-M 90mm f/2 ASPH +5 more
jhunna Senior Member • Posts: 2,739
Thesw two are my constant carry kit.  I always have mu gx85 and these two lenses with me.
 jhunna's gear list:jhunna's gear list
Sony a7C Sony E 20mm F2.8 Sony FE 50mm F1.8 Sony FE 85mm F1.8 Sony FE 35mm F1.8 +7 more
richj20 Forum Pro • Posts: 10,181
Consider Panasonic 20mm f/1.7.
- Richard
Astrotripper Veteran Member • Posts: 8,676
Best for what?
5
What job?
Answer that question and maybe you'll get some useful answers. As it is, you might simply throw a dice. There's really no bad primes in the system, so whatever you'll get will be at least good. Will it be useful? That's another story.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
RobbieBear Senior Member • Posts: 2,356
Second that!
 RobbieBear's gear list:RobbieBear's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus E-M1 II Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +1 more
Sheacash Regular Member • Posts: 436
Personally I prefer the angle of view of the 25mm f1.7 over the 20mm F1.7. The 25mm is also cheaper.
I do want a 42.5mm f1.7 for portraits, and a for particular video setup (it's the ideal length to get the entire stage of the kids school play in 4k, meaning I can crop and zoom in post).
The 25mm and the 42.5mm could probably be obtained for around your budget, but for you, you are probably best off to wait and try out what focal lengths you like, and then plan your primes around that.
As a side note, consider the 12-60mm (if you like wide angle) or 14-140mm (if you like tele) instead of the 14-42mm kit lens if you can afford either of them. They are far more versatile than the basic kit lens.
 Sheacash's gear list:Sheacash's gear list
Olympus E-420 Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +9 more
MattKrull Forum Member • Posts: 97
Re: Best for what?
What he said.
On the wide end, the PL15 F1.7 is an excellent lens, period. But it is expensive. For much less money you can go slightly wider, a stop slower, and less sharp with the Panny 14mm F2.5. Less sharp, but with plenty of people who like it. Full disclosure, I went with the more expensive PL15.
Moving to the mid-wides, You have the 17mm F1.8 (see me note about the 2.8 below), sigma 19mm f2.8, sigma 16mm f1.4 (heavy, very high quality), and Panny 20mm f1.7. All are good lenses. The sigma 19mm is dirt cheap and while slow (f2.8) it is sharp when wide open (at 2.8 it is as sharp as anything else at 2.8).
Standards are the 25mm F1.7 and f1.8 from Panny and Olympus. General consensus online is that the Oly is slightly better, but Panny is much cheaper. PL25mm f1.4 is a great lens (I have one), but the new Sigma 30mm F1.4 is sharper. Sigma also makes a 30mm f2.8 that should not be discounted if you like slightly tighter compositions and want to save money.
On the longer end, the 42.5 f1.7 and 45mm f1.8 are excellent (I have the 45mm f1.8 and it is my second most used lens). The Sigma 60mm f2.8 give you reach that your kit lens doesn't, and while f2.8, can still provide a very shallow DoF (headshots with one eye in focus and the other out). All three are winners. The Panny 42.5 is probably the best bet for you as it has DfD (faster focusing on your body) and a more traditional "portrait" fov.
For your $500 you can have all three Sigma 2.8s, or a Panny 25mm f1.7 and a Panny 42.5m f1.7. I'd probably go the latter, as those two focal lengths make up 95% of the shooting I do.
The only lens I'd avoid is the Olympus 17mm F2.8 Pancake. I say this having owned one. It does lovely colour but handles high details terribly. Detail turns to mush. Panny 14 f2.5, Oly 17 f1.8, Sigma 19mm f2.8, or Panny 20mm f1.7 are all better choices.
 MattKrull's gear list:MattKrull's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GX8 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +9 more
LB1940
LB1940 Regular Member • Posts: 155
Me too! 20 + 42.5 or 45. Light kit and versatile.
LB1940
 LB1940's gear list:LB1940's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +1 more
Max Polonski
Max Polonski Regular Member • Posts: 324
20/1.7 doesn't support AFF and AFC and can take a long time to focus in low light. 15/1.7 is better. And agree about 42.5/1.7 - must have.
 Max Polonski's gear list:Max Polonski's gear list
Fujifilm X-T20 Sony a7R III Panasonic Lumix DC-GX9
Dave Andrade Contributing Member • Posts: 587
Unfortunately as others have mentioned, you left way too many options open.
The 75mm 1.8 by Olympus is famously sharp.
I hear great things about the 15 1.7 for panasonic.
the 30mm 1.4 and 16mm 1.4 by Sigma ALSO have great reputations.
That's as far as I know/have heard, and I will leave others to provide more suggestions and the option to agree/disagree with this
(side note: I've rented an oly 17 1.8, and I also like that lens as an option to the 15mm i mentioned above)
 Dave Andrade's gear list:Dave Andrade's gear list
Panasonic Lumix DC-S5 Panasonic Lumix S 85mm F1.8
Max Polonski
30 mm Sigma is really big and heavy.  I can't recommend it. Panas 25\1.4 is more preferred until you really need 30 mm not 25 mm.
I wanted to chime in and say that I also hadn't heard many good things about the 20mm 1,7, either.
Or, to be fair, I heard that it had a few issues, and that there were better options.
burritosandbeer Regular Member • Posts: 314
I've got two of these and love em!  the 25 f1.7 i got new for $147 and the 42.5 f1.7 I got demo used for $250 i think.
My absolute favorite lens is the 42.5 f1.7
 burritosandbeer's gear list:burritosandbeer's gear list
Olympus PEN E-PL6 Panasonic Lumix DMC-G7 Panasonic G95 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS +7 more
james005 Forum Member • Posts: 67
The Panasonic 20mm f/1.7. I have owned many of the m43 system lenses and my 20mm is one of the few I could never part with.
-Its the sharpest on this thread list, except the mighty Olympus 75mm.
-Its one of the cheapest and arguably the best value for money of all m43 lenses (I got a used copy of the mk1 and it is phenomenal value for money).
-It focal length is perhaps the most versatile. A 20mm (40mm equivalent) focal length sounds odd, but in practice I love it. Versatility is an important consideration if using a fixed foal length.
-In addition to its razor sharpness, the 20mm can produce beautifully rendered images with character.
-Being a lightweight pancake it fulfills your need for a simpler and smaller package. It is never too big to carry in additional to another lens, and when on the camera it makes it so discrete and portable.
With prime lenses I believe you should choose one with a focal length that fits your preferred style and genre. I can only share my enthusiasm for the 20mm because I am not a portrait photographer. I have the Olympus 45mm f/1.8 too, its produces great images and I really appreciate its capabilities but it spends 95% of its time in the bag.
OP Rupert The Camera Man Junior Member • Posts: 27
Re: Best Prime Lens to Buy [Under $500]
Okay so I probably was a little general in my original post. I guess what I had in mind when I originally wrote the post is a lens that would kind of simulate a cheap film camera like a disposable camera or a consumer film camera from the 70s- 2000s or so. a "Point and shoot lens" for lack of a better term. I have a lot of experience with those types of cameras from when I was younger and I think especially since I'm a beginner a familiar focal length will simplify things. I think I'm looking somewhere between the 15 and 50 mm (35 mm equiv.) focal length. Correct me if you feel I'm wrong on anything though. I plan on buying other primes but I thought it best to start with that range of lenses.
jwilliams Veteran Member • Posts: 6,400
2 Suggestions ...
Oly 17 1.8 or 25 1.8.
The Panny 20 1.7 is also a good lens optically and a very usable FL, but the AF can be frustrating.  I own all three of them.  The 17 gets the most use followed by the 25.  Since getting the 17 & 25 the 20 just sits.
When thinking about the FL, remember you can always crop, but you can't put back something that was not in the frame originally.
Jonathan
