G9 first impressions
Started Aug 8, 2018 | Discussions
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
8
it's come, Amazon £1273 (Camera Price buster still showing best price, £1442), £300 Panasonic Cashback, hope to get £300 for one of my G80s, total outlay £673, no brainer.  I may even get a little for my GX7.  I know it doesn't matter to some of you but for some of us it's all about the price.
So:
Big
Heavy compared to my G80
I like it to look at
There is an awful lot to learn. I have gone, G5, 6, 7, GX7 and G80 and barely had to look at the manual. This thing is a very different beast. Some benefits in that menu system is basically the same but even then there are differences.
The general praise of the EVF is not overstated it is fantastic. I wear varifocals and tried the reduced magnification but no difference other than smaller, I shall stick with the big one. That eye cup is nice. It would be very easy to put something like that on all cameras.
I read some criticism of the shutter button but I am, still able to do half press comfortably and I have extremely poor sensitivity in my hands.
Some of the button placement will take some getting used to and I will leave it for a few days before customising. Controls generally very responsive.
I'm optimistic that I may find BBF a bit more comfortable than on the G80 but haven't tried it in the field.
Mode dial very comfortable but not quite so keen on the drive mode dial underneath but I expect I will get used to it.
At least a diopter I find easy to use, might be because the screen is so clear.
I don' think I'll be using in camera charging but I suppose it's a nice to have as is dual cards but I'm going to have to fork out on some new high speed cards.
I'm not sure I like the Exposure comp button, I am very used to just flicking dials.
Joystick, I have an open mind at the moment.
Focusing on the G80 was to my mind as fast as it was possible but I may have been wrong.
I tried the 6K photo. CAF is faster although lag hasn't completely disappeared. I think half press actually assists focus but I'm not sure.
That's as far as I have got. I may go out and do some birds tomorrow but possibly with the G80 because it is that much more complex that I feel I may not be ready to take it out yet.
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Panasonic G85 Panasonic Lumix DC-G9 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7
jrharvey592 Regular Member • Posts: 343
Re: G9 first impressions
Not to mention it is fantastic for 4k video.
Dutch Newchurch
Dutch Newchurch Veteran Member • Posts: 5,716
I like the man-maths Trevor!
It sounds like just the right kit for you.  Enjoy using it, and do show us the results as soon as you can.
How do you think the handling will work out for aerial photography, or will you continue to use more portable gear for that?
Dutch
forestmoonstudio.co.uk
My DP Review gallery
Photography is about light, not light-proof boxes.
brentbrent Veteran Member • Posts: 5,766
I can't say that I've become completely touch-comfortable with those three top-panel buttons (WB, EV, ISO).  I set the back panel dial (the big one with the four-way buttons) to also adjust EV when rotated, and that's what I mostly use for that purpose.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Trevor Carpenter
OP Trevor Carpenter Forum Pro • Posts: 19,435
No really much different to my G80 in size and weight.  I am thinking that my next camera if and when I replace my G80 may be a rangefinder style body although I am wary because I have never liked my GX7 as much as my other Panasonics.
Trevor Carpenter
thanks I may try that
Three potential criticisms of the joystick: could be faster; could allow diagonal movement; and could be a bit closer to the thumb rest. It would be great if a firmware update could address the first two, or at least the first one (maybe giving a couple of speed options).
Still, I find the joystick quite useful, particularly when shooting with the LCD closed (which I do more of with the G9 than any prior camera). Being able to center the focus box with one push on the joystick is great. Also, you can give the joystick a tiny nudge to activate the focus box size, which can then be adjusted with the back dial.
I agree with you that there is definitely a lot more to learn about setup and options and menus on the G9 compared to all other Panasonic bodies I have used (I've never owned a GH).
Brent
amtberg Veteran Member • Posts: 6,217
I've set the front dial to adjust EV, as I did with the GH3 and GH4. The only time I use the EV button is if I'm in M mode with Auto ISO (because the front dial then controls shutter speed).
I set the back panel dial to adjust AF area size.  Really like that.
Ted_G
Ted_G Regular Member • Posts: 207
I have had mine for a couple days longer than you and am still learning the system....at least the menus and most everything else are intuitive.
The joystick works well. I too have barely customized anything and probably won't for a while yet.
It's a pleasurable beast. I will be hitting a wildlife preserve this weekend to give it a good workout.
Have fun!
"Lead Me....Follow Me....Or Get The Hell Out Of My Way"
 Ted_G's gear list:Ted_G's gear list
Sony RX100 VA Panasonic Lumix DC-G9 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 100-300mm F4-5.6 II
alcelc
alcelc Forum Pro • Posts: 19,003
Can the extra weight and size gives you better stability on using longer lenses?
Albert
Badwater Senior Member • Posts: 2,095
It all depends.  Some people like the extra weight balance for use on gimbal head tripods, and in most cases the G9 body works well with the  3 huge panasonic lenses, as well as the Oly 40-150 and 300.  But, using the lens bracket mount the camera side is heavier than the lens.  On the other hand, I suppose the extra weight will be needed for people attaching DSLR lenses and using a gimble head and tripod.
Since the G9 is a camera designed for hand holding long telephotos it would be better if the G9 was a little lighter.  Nevertheless, even with the weight, that grip on the G9 is what makes it comfortable to hand hold those long telephoto lenses.
One thing I found helpful to learn about the hard to find AF and other focus modes is the YouTube.  There are tutorials on how to access menus that work in conjunction with other settings.
Pete Berry Veteran Member • Posts: 4,322
My G9 Setup
Trevor, Here's a summary of my G9 setup:
Rear wheel : Exp Comp (M mode - SS)
Top wheel: S, A, P (M mode – Aperture)
Scroll Wheel: ISO (GREAT!)
Joy-stick: AF box/point control: Flick down to activate box for re-size; press to center box Playback - L-R image search; Up-Down - video play controls
AF/AE lock: AF w/ hold on - using more back button AF w/ very sensitive shutter button
Function Buttons
  • 1 - AF mode     Playback – WiFi/Bluetooth on/off
  • 2 - Quick Menu
  • 3 - LVF/Mon
  • 4 - AF Point scope
  • 5 - Video IS Lock
4-way pad
  • 16 - Up - image review
  • 17 - Right – 0ff, due to inadvertently pressing when scrolling ISO
  • 18 - Down - burst shot settings
  • 19 - Left - bracket settings
Touch Screen Fn’s
  • 6 - Shadow/highlight
  • 7 - Aspect ratio
  • 8 - Ex. Tele Converter
  • 9 - Dig. zoom
  • 10 - Shutter type
Lever: Toggles face detection AF mode
Pete
jrsforums Senior Member • Posts: 1,859
I reserve the back panel button for ISO. Use the top back dial for EC in P,A,S modes.  Only need EC button for M mode as I will mostly use the a and s dials for exposure control and want iso dial (back panel) as needed.
the beauty is, one can set the G9 up to fit ones likes and needs.  Had mine since First ship and am still tweaking.
 jrsforums's gear list:jrsforums's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GH6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +17 more
Trevor Carpenter
Re: My G9 Setup
Function Buttons
  • 2 - Quick Menu
  • 3 - LVF/Mon
  • 5 - Video IS Lock
4-way pad
Touch Screen Fn’s
  • 7 - Aspect ratio
  • 9 - Dig. zoom
  • 10 - Shutter type
Pete
Thanks for that I'm trying to hold off doing any customisation for a couple of weeks until I've played with as is settings a bit more.  I definitely think I shall be doing away with the extra button for EC.
timmer350 Contributing Member • Posts: 939
I did the same maths for my new G9 23 months ago - $300 instant rebate for sending in my old functioning GH4, plus an extra $250 for the Gh4, made it a no-brainer. Plus I sold a few old macs which brought it down to about $100!
Have loved it using it so far. (and AF is better than Gh4).
Tim
 timmer350's gear list:timmer350's gear list
Panasonic Lumix DC-G9 Panasonic Leica 100-400mm F4.0-6.3 ASPH Apple iPhone 11
s.seng Regular Member • Posts: 411
Trevor, Currently there are no body only listed by Amazon at £1273. Only a market place seller is advertising for £1273. To get the £300 rebate one needs to buy the camera through  Panasonic authorised dealers listed in the Panasonic's website. I saw Amazon was advertising for £1442 about a week ago.
Best check your receipt and Panasonic website to satisfy yourself before the return window closes.
Seng
 s.seng's gear list:s.seng's gear list
Sony RX100 VII Nikon Z fc Nikon Z 16-50mm F3.5-6.3 VR Nikon Z 50-250mm F4.5-6.3 VR
Trevor Carpenter
Seng
Thanks but don't worry I've been very thorough.  I think you can still do what I did.  Go to the page you are seeing where it is supplied by MH-Direct.  Now look on the right hand side of the screen and you will see in the other sellers box  at the same price but supplied by Amazon.  When I did this it said they were out of stock but gave me a delivery date of four weeks time.  I ordered anyway, bearing in mind the end of promotion date and thinking I might have to cancel but a few days later I got an email saying delivery date had changed too just a few days time.  I let the order stay, camera was delivered as promised with a proper Amazon receipt.
Trevor, I am glad you manged to get it through Amazon. I am still sitting on the fence waiting for G90. All depends on how long I could put off GAS.
Seng
JosephScha Veteran Member • Posts: 7,249
It is heavier that G80 but not much; it's lighter than the GH5. I really do sympathize with your first reaction, I felt similar amazement at how many things were configurable or adjustable that were not on my G7. But the breakthrough comes when you realize that just because you could assign your own choice of function to almost every button and dial does not mean you have to. Just because there are multiple picture presets doesn't mean you need to use anything but Set1. And just because you have controls to adjust exposure, tint and more on the camera's JPEG engine certainly doesn't mean you have to (especially if you shoot raw). Take your time.. learn a new feature when you need it. In the meantime set it to P or A or S and use it much like your G80. Enjoy. I think you will will. And I think you'll find JPEG color much improved.
- Joe S.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Cutomising new cameras
Congrats Trevor, we know you'll make good use of it.
Regarding customising, how I eased myself into the frighteningly different and more complex em1-mk2 when it arrived, was to program the controls so that the main ones operated as similar as possible to the GX8 (and gx7) that I am so used to.
Then after a week or so I gradually programmed all the extra controls to do various 'nice' things.
However - I tend to take both cameras with me on important shoots and - I still get in a bit of a muddle when frequently swapping!
Best of luck.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
