OM-D E-M10 II LCD not working when EVF auto switched on
Started Aug 6, 2018 | Discussions
CheeEng New Member • Posts: 1
hi, I have an EM10 Mark 2. Recently I found out that my LCD doesn't work when I switched the EVF auto on. When I move my eye away from the EVF sensor, it doesn't turned on the LCD for live view, but the EVF is still turned on. Could it possibly be the problem of the EVF sensor? Need help.
Olympus OM-D E-M10
pterosonus
pterosonus Regular Member • Posts: 282
Re: OM-D E-M10 II LCD not working when EVF auto switched on
Toggle the button on the side of the EVF opposite the diopter knob. Even with the EVF Auto on in the menu the button must be in the right setting. If that doesn't work gently clean the right side of the EVF with a DRY Q--tip.
 pterosonus's gear list:pterosonus's gear list
Olympus Stylus XZ-10 Olympus OM-D E-M10 II Panasonic GX850 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Rokinon 7.5mm F3.5 UMC Fisheye CS +3 more
james005 Forum Member • Posts: 67
As pterosonus said above, its possible that dirt on the Electronic View Finder (EVF) surface may obscure the eye sensor, giving a false signal that your face/eye is against the EVF and so the camera will display through the EVF only. Its also worth checking that you haven't inadvertently set the menu option to EVF display only (The EVF auto switch function), although your thread title implies you have checked this!
This thread caught my interest as I had a similar issue with my E-M10 mk2 in December 2017. The (EVF) did not work automatically when I looked through it . It allowed manual switching between the screen and EVF view (using the button pterosonus mentioned), so I knew the EVF itself did actually work.
I noticed that if I folded the LCD tilt screen out and back in again the automatic switching between EVF and screen worked intermittently, so I believed this is where my fault was; the camera somehow was sensing that the tilt screen was open/tilted - even when not, hence the automatic switching between screen and EVF did not work.
This was confirmed by gently thumb pressing the lower right or left hand corner of the closed LCD screen (as if to ensure the screen was closed). When doing this the EVF auto switch function worked fine.
Fortunately mine was still covered by Olympus warranty and I was able to describe this issue in correspondence to them. I hope this makes sense and that you get it sorted.
Sir Reginald New Member • Posts: 15
Ah, the wonders of Google search, which led me directly to this exact description of the problem my E-M10 mkII has just developed. Could be a bit terminal if the camera isn't worth repairing.
 Sir Reginald's gear list:Sir Reginald's gear list
Panasonic Lumix DMC-GM5 Olympus OM-D E-M10 II Olympus E-M1 II Olympus E-M5 III Panasonic Lumix G Vario 7-14mm F4 ASPH +12 more
