Super Macro: Spiratone Vario-Dupliscope
Aug 5, 2018
Between the exciting new Laowa macro probe and this DIY thread about reversed enlarger lenses , I just felt like I needed to do some 1:1 or higher macro. I actually have a bunch of macro lenses, extension tubes, bellows, and close-up lenses... but will any of them really give me great IQ beyond 1:1?
Then I realized I also have a Spiratone Vario-Dupliscope III. There are multiple variants of this (here's an original ad for them ), and probably also under several other brand names; they typically sell for about $25 used. This is a simple device intended for slide copying at variable magnifications from 1:1 to 4:1. It has no aperture nor any significant focus adjustment, but obviously is designed to provide a flat field aligned with where the slide mounts. Well, the slide holder can be unscrewed!
The T2 adapter allows me to rotate and lock the dupliscope to an upright rotation... but I didn't bother. The idea was just to quickly try this out as a super macro lens. The zoom simply moves glass within the tube -- the outer tube is fixed. That unfortunately often casts a shadow, and the slow aperture means high ISOs or extra lighting even in daylight (the "S" setting on my A7RII was to ensure a fast enough shutter speed).
It works pretty well, even hand-held. All of the following were shot hand-held, in available daylight, and are unprocessed OOC JPEGs scaled-down in GIMP.
Aside from the specular bokeh in the 3rd shot (which was shot at a higher magnification), these look quite good to me. Certainly, sharpness is excellent and backgrounds mostly give a pleasing bokeh. Contrast is slightly low, but easily could be repaired in post. Here's a 100% crop from the last shot:
One issue is how to set IBIS for this. It doesn't have a marked focal length and being a macro can change the ideal IBIS settings anyway. It's hard to be sure, but it seemed that a setting around 100-200mm helped despite the fact that the view looks significantly wider. I'd really need to experiment to determine the best setting....
