Lumix G7 Quick Menu?
Started Aug 4, 2018 | Discussions
Rupert The Camera Man Junior Member • Posts: 27
Does anyone know if the G7 has a quick menu or like a super control panel like the other lumix and Olympus cameras have?
 Rupert The Camera Man's gear list:Rupert The Camera Man's gear list
Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS
hindesite Veteran Member • Posts: 4,893
Re: Lumix G7 Quick Menu?
Yes it has both.
Lumix menus are reasonably consistent for these cameras.
Helen
Helen Veteran Member • Posts: 7,606
Yes, it has the usual three Panasonic options for a model with an EVF and touchscreen - a touch-interactive data-only screen which is cycled to via the Disp button (this is like the Olympus Super Control Panel in a way, but doesn't allow itself to be combined with live view, you just use the EVF for that).  Then there is the standard Q Menu, which is a way of making the various icons and telltales along the top and bottom of the screen touch-sensitive so you can access their settings, and the customisable alternative, where you can build several screenfuls of icons to your taste which superimpose over the middle of live view and again are touch sensitive.
alcelc
alcelc Forum Pro • Posts: 19,006
Helen and Hindesite before me answered your question.
I wish you should also know that the Q.Menu, also the fn keys (physical or soft), can have their own order and feature under the normal (P/S/A/M) shooting modes and each of the 3 C modes.
Albert
(unknown member) Veteran Member • Posts: 7,274
Yes it has both.
And Olympus is throwing all around on each model?
