EF-M Lenses: Not as durable as I thought...
Started Aug 3, 2018 | Discussions
THE EOS MASTER New Member • Posts: 18
Hi All,
So a few months ago I purchased an EOS M100. Not because it was small and light, but more because of the new DIGIC 7 features, ISO 25600 etc. and it seemed like a 'fun' camera. I just wanted to try EF-M mirrorless for once. The camera was enough for me in terms of performance, and I received it direct from Canon (so definitely genuine) with the 15-45mm and 55-200mm lenses.
I knew from experience with my friend's 18-55mm kit lens, that it can definitely survive a few drops and general wear and tear. The quality of both my EF-M lenses appeared better and the price said so too.
But... somehow I dropped my 15-45mm. It wasn't a severe drop, but for some reason the optics misaligned and the camera thinks it's stuck at 45mm. Moreover, my 55-200mm won't extend when zoomed. I don't know what is going on. Also I can't find any EF-M repair centres, just EF and EF-S.
Can anyone tell me if you've had problems with the durability of these lenses???
 THE EOS MASTER's gear list:THE EOS MASTER's gear list
Canon EOS-1D X Mark II Canon EOS M100 Tamron 18-200mm F3.5-6.3 Di III VC Sigma 35mm F1.4 DG HSM Art Sigma 120-300mm F2.8 DG OS HSM +23 more
Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EOS M100
OP THE EOS MASTER New Member • Posts: 18
Re: EF-M Lenses: Not as durable as I thought...
And I can't take any photos because my lenses won't work!!!
bluefoam
bluefoam Regular Member • Posts: 236
I would tend to avoid dropping anything containing glass... it is by it's nature a fragile material, even though you have assessed that it could take some knocks.
However, don't worry, there are a number of repair centers that can deal with your lenses LINK
 bluefoam's gear list:bluefoam's gear list
Canon EOS M6 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +5 more
R2D2 Forum Pro • Posts: 26,528
+1 Agree.  This level of equipment isn't built anywhere near the standards of L lenses or 1D bodies!
I baby mine, and haven't had any issues yet (knock on wood!).
Good luck with the repair,
R2
(unknown member) Senior Member • Posts: 1,972
7
THE EOS MASTER wrote:
Hi All,
From my experience in a manufacturer's service department I have seen a lens that had fallen from 18 inches onto a thick carpet and which had to be written off. On the other hand I have also seen a lens that fell from the 4th floor of a multi storey car park which survived with minor scuffing and a bent filter ring.
The moral, if there is one, is that it's simply the luck of the draw and less to do with durability. If you don't want your lenses to be damaged it's probably best not to drop them.
Thank You!
Thank you all for that. I think maybe, that because the lenses are small, they might have lighter, but weaker zoom cam systems. I have noticed this because:
1) The 55-200 still zooms, but you can hear a clicking sound telling you it has come out of place.
2) The 15-45 can be forced out of retraction position (I wish probably that I didn't do this).
By the way, I treat my 1DX Mark II, my Sigma's (in fact all except the M100, 15-45, and 55-200) VERY CAREFULLY. In fact, I have all the packaging and still use it. My M100 is more of a 'use and abuse' camera.
tamaraw35 Contributing Member • Posts: 784
I have had no such issue with any of my photo gear. I guess I had a chrome strap lug on a Coolpix 4300 oxidize and paint wear off a few buttons over 15+ years, but I treat my gear very carefully and haven't dropped or caused serious damage to a camera yet (knock on wood).
Obviously mistakes happen, but I generally take care to have a wrist, shoulder, or neck strap attached to me at all times, so that even if I do loose my grip, the camera is safe.
Dropping any camera, or especially lens could have the potential to cause serious damage, regardless of brand or product line. As a product designer, when I think of durability, I think of ability to withstand general wear and tear, and maintain functionality over X number use cycles. I don't typically think of this as protection against throwing out of windows, but this obviously depends upon the working environment, as a gopro or waterproof camera would be designed with shock resistance in mind. It is safe to assume that their is no such protection unless marketed as so. Drop an expensive Leica lens and you might have similar results as an EF-M one.
I am sorry to hear about your issue. Try contacting a Canon service center and see what they tell you, I would imagine that they if repairable, they could either do the work or ship it to another center that could. Good luck!
Rock and Rollei Senior Member • Posts: 2,899
R2
No, but equally they have nothing like the mass of L lenses, and mass is not good when dropping lenses.
Fact is it's the luck of the draw. If you drop a lens, you run a strong risk of decanting elements at the very least
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
trungtran Senior Member • Posts: 1,747
EFM lenses are generally not worth repairing depending on the damage. You can send it to Canon for a quote, they probably just send you a new one instead of attempting a repair.
 trungtran's gear list:trungtran's gear list
Olympus OM-D E-M10 Sony a7 II Canon EOS M6
plantdoc Veteran Member • Posts: 4,339
Probably will not be able to find a repair shop. Even Canon doesn't seem to repair M lenses, at least not my 18-55mm. They replaced it and indicated it is not repairable. Good luck.
Greg
Andy01 Veteran Member • Posts: 5,188
I am not sure that ANY camera lenses are designed to be drop-proof, and especially ultra cheap, plastic mount, throw-away kit zoom lenses. Same applies to any M camera - not designed as a robust "action" camera to be knocked around. Maybe treat it carefully like you treat your very robust 1D camera (that is designed to be knocked around) and it may last longer.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
R2
LOL, I'd rather be dropped from 12 feet in an M1A1 Abrams than a Ford Fiesta!
I've banged L lenses around for decades without any issues (knock on wood). I definitely would not do that with these plastic lenses!
Absolutely avoid dropping any lens. I've been there when other people have, and it's not pretty!
R2
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
This is what drives me batty...
6
Canon's initial EF-M offerings - the 18-55, the 22 MM, and the 11-22 MM were all built like little tanks - and love those metal lens mounts.  Optically they also do a very good job and the 22 and the 11-22 are optical marvels for the price.
But something ridiculous happened on the way to the forums (pun intended) - Canon elected to get cheap.  Everything produced after those 3 gorgeous lenses turned into all plastic designs with the exception of some 3rd party lenses that feature superb construction with metal mounts.  And the bantering back and forth between the "metal lens mount" fans and those who are "purveyors of the plastic lens mount," is ongoing.  IMO, there's some truth and logic to customers wanting better constructed optics.
This is but one facet of the EF-M lens line in general that prevents me from purchasing more M serious bodies - that is, both the quality and the pitiful number of EF-M lenses available.  Think about it - Canon has released 8 M bodies since the M was first released - only to have a current selection of 7 Canon EF-M lenses (6 really since the 18-55 is no longer being produced).
Now lest any of the EOS M fanboys infer that I'm knocking the system - I'm not - not by a long shot!  I enjoy shooting with the system, but many of us aren't satisfied with the current EF-M selection of optics.
Sincerely,
Bernd ("Ben") Herrmann
Fuquay Varina, North Carolina USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
Jefenator
Jefenator Senior Member • Posts: 2,866
Never Struck Me As Being Durable
The EF-M lenses have always seemed a little delicate to me. But they're small and light and inexpensive for what they do optically, so what the heck...
When the aperture mechanism quit working on my 11-22, I sent it in to Canon and they sent me a replacement for roughly what a repair might have cost. That seems to be the approach with this line and I get it. (They probably wouldn't be so nice and affordable if they were designed to be serviced and Canon had to stock a bunch of parts.)
If you want something more durable, you might look in to Canon's L Series. If you want something really durable, check out some old manual film era lenses (especially from Nikon & Leica).
 Jefenator's gear list:Jefenator's gear list
Sony a7 Canon EF-M 11-22mm f/4-5.6 IS STM Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro Sony Alpha NEX-7 +8 more
rxb dc Senior Member • Posts: 2,104
You said a few months ago - send the lenses in for warranty service, noting that you dropped the 15-45. Canon will probably give you a brand new lens for both, charging you a nominal amount for the 15-45.
https://500px.com/rbhardvaj
https://www.instagram.com/rxbdc/
Safety Warning: Bad taste unmitigated by moderate skill
Disclaimer: I reserve the right to take bad photographs with any camera, irregardless of DXOmark scores.
 rxb dc's gear list:rxb dc's gear list
Canon EOS 700D Canon EOS 7D Mark II Canon EF 50mm F1.8 II Tamron SP 150-600mm F5-6.3 Di VC USD Canon EF-S 10-18mm F4.5–5.6 IS STM +9 more
Sittatunga Veteran Member • Posts: 5,406
Re: This is what drives me batty...
Section of the 18-55mm lens on the EOS M
Most of the metal in this lens is in the vanity shell and the bayonet. Just like a MacBook Pro. It doesn't mean it's a badly constructed lens, just that the later lenses are more honestly made. Lenses in this price range aren't designed to be repaired, it's too costly, just like the original Timex clockwork watches.  If it breaks in the guarantee period it's cheaper to replace than to mend.
Sincerely,
"...just that the later lenses are more honestly made" - what do you mean by this?
All the EF M lenses basically have high grade engineering plastic bodies. That's not to say that they're bad, Canon have at least had 42 years of practice in making good cameras with lots of plastics. The three EF M lenses that I own have very thin, easily dented metal vanity shells that look nice, feel great but are essentially there for decoration. The lenses would been just as good and a bit cheaper without those shells. Canon have dropped the shells on their later lenses, making it explicit that the lens bodies are plastic and people complain that they look cheap. They can't please everyone.
There again, I don't like the stone cladding on London's Tower Bridge. There's a steel framework inside those towers. I'd rather the bridge showed how it worked as an example of Victorian engineering than it hid behind mock-mediaeval masonry.
Helen
Helen Veteran Member • Posts: 7,606
In a way I'm going a bit off-topic here, but in the vein of "it could be worse"/"let's hope they don't go that far!" you could take a close look at Canon's new cheapest DSLR (except that it isn't "cheaper enough" yet as far as its actual price goes) - the EOS 4000D/3000D (not sure if it has a US designation or even will be on sale in the US) - it's a scary illustration of how cheap Canon is willing to go on construction etc.  It was launched alongside the EOS 2000D/1500D/Rebel T7, which is a direct replacement for the EOS 1300D/Rebel T6.  The 2000D/T7 ups the old model to a 24MP sensor but otherwise leaves it unchanged, aside from one weird downgrade it shares with the new 4000D (there's no large X contact in the hotshoe any more, just a blank, so they cannot use cheap undedicated flashes and even some of Canon's own units aren't fully functional) but by comparison the 4000D is a bit of a shocker.  It stays at 18MP (not a sin), is made of especially cheap polycarbonate, has an all-plastic lens mount (we've seen this before back in film days and these days only Sony had done it on the a58 and a68, but it always looks ugly), a lift-it-yourself flash (like the EOS M50, thankfully the only "downgrade" it shares with these and it's not too bad a feature), no rear thumbgrip material, a 2.7" 230k dot LCD (when was the last time we tried to ignore the dots on a resolution that low?), control labels printed next to buttons because it's cheaper and no blue paint for any of the legends either for the same reason, no on/off switch (just an OFF position on the mode dial - so you can't leave it set to your favourite shooting mode, ready to go), no eyesight correction facility for the viewfinder.  They bundle it with the worst variant of the 18-55 still made, unsurprisingly, yet it barely costs any less than the 4000D.  Both models (and their predecessor) dropped the automatic dust removal systems from the sensor too.
At least they're not doing that to the EOS M range (yet  )...
Ben Herrmann
Maybe he's hinting that Canon was...
..."dishonest" with all of the other lenses...
Sincerely,
