Jon555
Re: The sharpest lense regardless of format
LingoDingo wrote:
Dr_Jon wrote:
It really is impossible to compare, a FF super-telephoto on a 50MP (or 48, or 42) camera resolves an amazing amount of detail.
But if the m4/3 lens is resolving the SAME amount of detail on to a m4/3 sensor that can record all of this detail, then it can become a toss up.
I have a 20MP m43 camera and a 50MP m43 camera. I have lenses where you can see pixel-level detail on the FF camera (some need stopping-down). I suspect if someone makes a 100MP FF sensor they'll be good there too. The fact some people like to test lenses on 21MP FF sensors really doesn't mean much.
Many of the pro grade m4/3 lenses ( especially the telephotos ) are resolving twice the number of lpmm as the Full Frame lenses are, so the SAME amount of detail can be captured by both sensors despite the large difference in sensor size. ( a sensor can't capture detail if the lens can't resolve it )
They really aren't if you use a high-pixel-density FF sensor. There are a lot of FF lenses out there that out-resolve 50MP sensors but they are limited if you test on low-res sensors. Lenstip recently reviewed the Sigma 105mm f1.4 on a 21MP FF sensor and shock horror even allowing for the test software doing some guesstimating it topped out at 42lp/mm.
Photozone tested the Sigma 85mm f1.4 on a 21MP Canon camera and got a peak resolution of 3693 lw/ph (where ph=24mm), they tested it on a 5Dsr and got 5473.
Plus if you stop them down it gets insane.
It depends on the lens. Some lenses perform best at full aperture ( like the Panasonic 200mm f/2.8 does ) and some lenses only reach their peak 2 - 3 stops down from their maximum aperture. ( older lens designs tend to perform poorly at full aperture )
I found using the same focal length lens (no equivalence) my 5Dsr used to resolve the same level of detail as my GH4, or sometimes better as I have some good Canon lenses. My GH5 is a little better with good glass (meaning you see somewhere between 10-20% more detail at the same focal length, just 3/4 of the image isn't there).
