The sharpest lense regardless of format
Started Aug 1, 2018 | User reviews
nerves New Member • Posts: 10
5
ive owned the lense now for just over 4 months and I can say is truly and amazingly sharp.  Very fast and the micro contrast is just beautiful.
 nerves's gear list:nerves's gear list
Fujifilm X100F Canon EOS-1D Mark II Sony a6300 Olympus E-M1 II Olympus OM-D E-M1X +30 more
Olympus M.Zuiko Digital ED 75mm F1.8
Telephoto prime lens • Micro Four Thirds • V311040BU000
Announced: Feb 8, 2012
nerves's score
5.0
Average community score
4.9
Derek Dean
Derek Dean Veteran Member • Posts: 3,284
Re: The sharpest lense regardless of format
A fine piece of glass is a joy to use, especially during post processing when you can spend quite a bit of time working on an image.  Enjoy!
 Derek Dean's gear list:Derek Dean's gear list
Sony a7R II Sony FE 24-105mm F4 Samyang AF 18mm F2.8 FE Sigma 100-400mm F5-6.3 DG DN OS Adobe Photoshop CS6 +2 more
Felice62 Veteran Member • Posts: 5,079
Not really but on the top list
I believe Sony FE 55/1.8 ZA outresolves it.
But with those specs it's amost irrilevant..
I cook with wine, sometimes I even add it to the food.
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
Sranang Boi Senior Member • Posts: 2,860
Re: Not really but on the top list
About the wine: do you add it to the food whilst you are cooking the food? Or do you add it to the food that you have just swallowed?
 Sranang Boi's gear list:Sranang Boi's gear list
Panasonic Lumix DC-FZ1000 II Panasonic Lumix DMC-GX8 Panasonic G90 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +1 more
The two make sense, don't they?
Both are possible, but produce a different result, which affects the taste.
Agreed.
Although it's nice to start cooking and grab a refreshing Prosecco, just to prepare for dinner, you know.
Alexis D Contributing Member • Posts: 858
Have you used similar lenses in other formats and brands to claim this is the sharpest lens?
rashid7
rashid7 Veteran Member • Posts: 7,011
as it is rumoured to be built by Sigma, it helps explain why my 30f1.4C is so darn sharp!
Keep it fun!
Sigma 30/1.4
I got mine last night delivered. Can't wait to test it.
robonrome
robonrome Senior Member • Posts: 2,334
I have both and the 55/1.8 with an a7rii. I've never done any scientific comparison. Both are very sharp but I would pick the 75 as having an edge. Could be more perceptual thing from the sorts of things I photograph at that focal length.
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
kravemir Regular Member • Posts: 165
Some examples?
Could you post some photos made with this lens as examples?
Belief is each man's own choice, and my choice is to believe in God.
 kravemir's gear list:kravemir's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Lumix G 42.5mm F1.7
According to lab tests Sony's 55/1.8 ZA resolves above 3500 lines which is astonishing itself.
Oly 75/1.8 is at 3150 which is extremely high.
Specs apart both lenses are insanely sharp.
bobn2
bobn2 Forum Pro • Posts: 71,955
14
Presumably, these are Optical limits tests. You should be aware that they do their tests on sharpened JPEGs, which means that the usual 50% contrast criterion for MTF rather goes out the window, and why they show something like double the resolution of other sites (that don't do the tests with sharpened JPEGs). Still, they should be self-consistent, so:
The lens in question
I think that's enough to suggest that the OP's statement 'The sharpest lense regardless of format' is the usual kind of tiresome provocative hyperbole from which this forum suffers (apart from the fact that he can't spell 'lens').
Ride easy, William.
Bob
paul cool
paul cool Veteran Member • Posts: 3,137
Think it gets bettered by the pl 200mm and olympus pro 45mm f1.2
 paul cool's gear list:paul cool's gear list
Sony a7R III Sony a1 Sony FE 70-200mm F2.8 GM OSS Tamron 28-75mm F2.8 III Tamron 17-28mm F2.8 Di III RXD +3 more
Bob, Thanks for the comprehensive reply, which I can't fail to fully adhere to.
Too often we give in to our emotions and jump to the wrong conclusion.
That said, Oly 75/1.8 is a sharp lens for good.
Peace
Felice
Didn't think Oly 45/1.2 could get to these levels of sharpness.
Impressive.
jonnieb
jonnieb Contributing Member • Posts: 615
I would have given this lens the nod until I purchased the 300 F4 Oly prime. That lens is wicked sharp.
Jonnieb
 jonnieb's gear list:jonnieb's gear list
Olympus PEN E-P5 Olympus PEN-F Olympus OM-D E-M1X Olympus E-M1 III Olympus Zuiko Digital ED 50mm 1:2.0 Macro +16 more
Albert Valentino Veteran Member • Posts: 9,770
Never used the 300 but as I recall Olympus called/marketed the lens as their sharpest lens ever 😃
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
(unknown member) Veteran Member • Posts: 4,046
It's clearly better than any lens I ever used except OM f/1.4 50 and OM f/2.8 135 but they have to be stopped down. Very sharp but not as bright the way I use them.
